k + N cold air intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gaert09, Jul 19, 2008.
  1. Jul 19, 2008 at 8:16 PM
    gaert09
    gaert09 [OP] Member
    Hurlburt Field Air Force Base
    07 Tacoma
    Window Tints, Eyebrow Tint, Bug Deflector, Rain Deflector on windows, K+N Air Filter, under cover over bed,
    I just installed the k + n cold air on my 4cyl tacoma....Im noticing while im in D at a red light or a stop sign, my truck seems to rumble from left to right and it sounds like its going to stall out....Does anyone know why that would happen? Please reply it will be great to find out why this would happen
    thanks alot
  2. Jul 19, 2008 at 10:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you double check to make sure the maf sensor is plugged all the way in?? if so.........give it a little time to adjust to the new air flow, it will go back to normal, computer just has to relearn the new mix.:)
  3. Jul 19, 2008 at 10:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It could also be a vaccume line came loose or disconected. If these symptomes persist, check your lines. :)
  4. Jul 19, 2008 at 10:55 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    is it a rattle noise ??? maybe the heat sheild???
    if its a rumble then check ur lines... if its a rattle re-adjust ur filter and play around with it a little and find a area that wont make it rattle
