K&N Fell Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Love My Taco, Dec 27, 2010.
  1. Dec 27, 2010 at 1:02 PM
    Love My Taco
    Love My Taco [OP] Active Member
    Justin
    Ohio
    05 TRD Sport xtra cab
    K&N CAI, 110 outlet in cab mod, ARE Cap, Yakima Racks, Stainless Bull Bar, tailgate lock
    :eek: I was just changing my oil when I noticed my K&N CAI air filter was laying in the "cold air well" unattached to the CAI! Great, last time I was under the hood was about 2 months ago(I've been busy), so who knows how long I've been running filter free. After further inspection, the MAF sensor screws had backed way out and it was about to fall off too! I guess my question is, does anybody know of anything I can do to try to clean out all the crap that probably got in the engine. Anybody with these filters, check that thing regularly. My guess is that with the cold,hot,cold,hot, they can work themselves loose. I guess I just can't have nice things.
  2. Dec 27, 2010 at 1:29 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Thanks for the heads up, I check mine when I check my oil level. I give everything a good shake.
  3. Dec 27, 2010 at 1:32 PM
    gpend5.7sport
    gpend5.7sport Well-Known Member
    Gabe
    Houston
    2010 Toyota Tundra TRD Sport
    too damn many
    the filter has a hard time staying on the tundras as well i got a buddy who used a zip tie to hold the filter on lol a year later and the system is still working lol as far the screws backing out go get some loc tite from your local hardware store and put it around the screws
  4. Dec 27, 2010 at 1:36 PM
    Blue07Taco
    Blue07Taco Well-Known Member
    Nick
    Iowa
    Its blue
    TRD intake/ exhaust
    Mine fell of my Tacoma too. I put it back on and all is well. Im sure yours is fine too. Just make sure its on tight, and try not to get the front tires off the ground......
  5. Dec 27, 2010 at 1:39 PM
    Delrivpilot
    Delrivpilot Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    I just had mine put on last week and I am getting a loud rattling noise under the hood. I think it is the pipe that goes through the fire wall is vibrating. I'm not lovin it so far. I might try moving the filter away from the wall just a bit.
  6. Dec 27, 2010 at 1:41 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you still have the charcoal filter that should have blocked most of the larger stuff (not sure if you have to eliminate with the k&n fipk or not). If the trucks' still running fine.. I wouldn't fret too much just keep an eye on it. I try to (not always but more often than not) check my oil level every oil change... also helps give a quick once over while I'm there. It's a wise 40 second investment that's already wasted waiting on the pump.
  7. Dec 27, 2010 at 1:55 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    I have the exact same issue. It rattles against the box. I was going to try to put something under that area to control the vibration.
    I dont care for it either yet. The service rep at the dealer had ordered the wrong one for another truck so he sold it to me and installed it for $100 so it was hard not to take it. I think without doing the exhaust at the same time you wont see much if any gain in HP or gas mileage.
  8. Dec 27, 2010 at 1:56 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    sounds like stock is the best option.
  9. Dec 27, 2010 at 2:31 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Damn, at least I'm not the only one with the problem. I bought mine on ebay for $160. I am going to tweek it a bit, but if I can't fix the rattling issue, I am going another route. I'll let you know if I fix the problem
  10. Dec 27, 2010 at 5:08 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    You can't have nice things if you don't have 1 MINUTE every week or two to look under your hood
