K&N filter + dusty roads good or bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Sep 16, 2010.
  1. Sep 16, 2010 at 11:17 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    im basically looking for a second opinion other than my own. I'm getting ready to go hunting next week, and the mountains in california this time of year are really dusty. I have the K&N drop in filter with the deckplate mod. I know that it is a high flow filter, but would I be okay just screwing on the deckplate? or should i go down to autozone and pick up a stock air filter and use the deckplate with the stock filter
  2. Sep 16, 2010 at 12:56 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i'd just get a stock filter and put in the deck plate, just to be safe
  3. Sep 16, 2010 at 1:54 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I think you'll be fine. Just clean it before you go, if you haven't for a while, and when you get back to get all the dust out. As long as you dont go crazy with the oil so all the dust sticks to it.
    Pretty much every trail out here is very dusty, specially when following someone else. With my cold air/open style air filter, I haven't had any issues with it and dust. Just a little cleaning after for my own peace of mind, but it really didn't need it.
    If it makes you feel better though, put in a cheap air filter, but I doubt its going to filter the air as well. Good enough for everyday driving, sure, but for driving through dust clouds... I dont know. The dust particles should be big enough that it shouldn't matter. If you're expecting the K&N to get clogged up and a cheap one not to, that means all that stuff that clogged up the K&N went through your engine with the cheap one.
    I think I'd put the deckplate on in either situation though.
  4. Sep 16, 2010 at 2:29 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    well ive done some research on TW and most poeple say to get a stock paper filter because they filter better, especially for dusty conditions, i use my K&N all the time but that is just everyday driving
  5. Sep 16, 2010 at 2:33 PM
    vantaco
    generally stock filters actually do filter and flow better....atleast in the VW world they do
    K&N filters are for show and sound for the most part
  6. Sep 16, 2010 at 3:04 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    thats kind of what i was looking for, i think i will go with the stock filter just for mountain driving, i just dont like the idea of high flow filters in dirt.
  7. Sep 16, 2010 at 3:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Put the deckplate in and you'll be fine. Clean your K&N regularly.
    I used to clean mine about twice a year.
  8. Sep 16, 2010 at 3:11 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    I got a aem cone filter and I have driven behind a some socal TW buddies that have dust my whole truck and no problems
  9. Sep 17, 2010 at 8:38 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    As long as the K&N air filter is cleaned and oiled you should be fine.
