k&n filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jyles1988, Oct 23, 2016.
  1. Oct 23, 2016 at 1:09 PM
    Jyles1988
    Jyles1988 [OP] Well-Known Member
    drop in filter taking the Charco filter out
  2. Oct 23, 2016 at 2:20 PM
    Jyles1988
    im taking my 2 filters out that are above the papper filter
  3. Oct 23, 2016 at 2:53 PM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    You can't expect people to be mind readers and not butt-holes at the same time. You didn't even ask a question.
    I have a k&n air filter. It does nothing for gas mileage in my opinion. Only advantage is you don't have to change filters as much. Again, not sure if I answered your question since you never posted a direct one.
    Sig45 likes this.
  4. Oct 23, 2016 at 3:23 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Honestly they do nothing but make noise. Save your money, and just use the paper OEM filter. This is just another one of those topics that has been beaten to death, so I'm sure searching would have brought you plenty of answers.
    Sig45 and Fitz235 like this.
  5. Oct 23, 2016 at 3:26 PM
    Pigpen
    Dan
    Northwest Montana
    Say no to the K&N. Keep the charcoal.
    Unchained 5150 likes this.
  6. Oct 23, 2016 at 3:34 PM
    Jyles1988
    thank yall i have read where it helps with fuel and horse power
  7. Oct 23, 2016 at 3:38 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Unfortunately they do none of either.
  8. Oct 23, 2016 at 3:38 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    It does neither.
  9. Oct 23, 2016 at 3:39 PM
    Jyles1988
    thank yall
  10. Oct 23, 2016 at 3:54 PM
    jsi
    jsi Well-Known Member
    native earthling
    ^^^ this ^^^
    Years ago I too bought into the hype and wasted my money on a K&N (or any other type of oiled) filter. The ONLY thing it did was to let a fine layer of grime through it. Nope, google is your friend and if you ask anyone with experience they will tell you, don't buy oiled filters.
  11. Oct 23, 2016 at 4:02 PM
    Jyles1988
    ok can i take the Secondry filter out and leave the ome in?
