K&N intake..."bloop, bloop" noise at start up and idle???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTripn27, Mar 5, 2017.
  1. Mar 5, 2017 at 4:07 PM
    TacoTripn27
    TacoTripn27 [OP] Member
    Jacksonville, FL
    '17 WHT TRD OR 4X4 DBL CAB
    Cali Raised 30" bumper LED, CH4X4 Sasquatch switch, K&N Intake, MBRP Cat Back T409 Exhaust, Prinsu Rack w/ 30” Wraith LED, OEM TRD Skid Plate and 265/75R16/SL Toyo Open Country AT/II.
    Anyone else who installed a K&N 63 Series on their 3rd Gen 3.5 Ltr get a weird, invariable "bloop, bloop" noise at idle and start up? Guessing it is some sorta' back pressure from the throttle body? K&N told me the stock intake's reservoir was designed to eliminate this sound...seem legit? Quadruple checked to make sure everything was tighted down perfectly, hose clamps, mass air sensor gasket, etc...runs like a champ via acceleration and sounds great otherwise...but...didn't have the weird sound issue per K&N on my '05 Jeep...totally different throttle body type for sure!
    Thanks for any/all input!
  2. Mar 5, 2017 at 6:05 PM
    MarioTosh
    MarioTosh Well-Known Member
    Puerto Rico
    2016 Silver TRD Sport
    MBRP exhaust, K&N CAI, SEMA TRD wheels, Lund 5" oval curved steel nerf bars, Rugged Liner hard trifold, OEM Toyota Roof Racks, pop & lock power lock, OEM bed mat, OEM rubber mats
    Normal
  3. Mar 21, 2017 at 7:51 AM
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2012 DCSB TRD OR
    I just installed the 63 series intake on my 3rd gen. I'm getting these same noises. Almost like someone is plopping their hand over the end of an open tube or something. I took it back apart to make certain there wasn't a piece of cardboard or plastic wrap in the tube....but there's not. Everything is tight. There's a bit of a gurgle after shutting it down as well. Since everything is tight, I'm assuming this is just normal for this motor with these K&N intakes. Weird. I'm not 100% sure i'll keep it on there.
  4. Mar 21, 2017 at 8:00 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    My last Honda made the sounds when shutting off the engine. And it had a different sound then stock when driving. I didn't notice any bloop bloop sounds at idle but kinda a hiss.
  5. Jul 3, 2017 at 2:20 PM
    ModelCarsMag
    ModelCarsMag New Member
    Gregg
    2017 Tacoma 2WD
    K&N Cold Air
  6. Jul 3, 2017 at 4:09 PM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Normal. Been mentioned before up here from me and others as well. Another way to confirm is turn the ac on. Let it sit at idle and every time the compressor kicks on you'll hear it. It's when the engine goes under the initial load like when you turn and the power steering pump kicks in it sucks the air and makes the noise.
  7. Jul 3, 2017 at 9:18 PM
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    My 71 series does the same thing.
  8. Jul 3, 2017 at 10:00 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Same thing used to happen on my 92' 22re with K&N
  9. Jul 4, 2017 at 4:48 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    My 2017 3.5-L does it with the K&N. No big deal.
  10. Apr 25, 2021 at 1:54 PM
    Cam0915
    Cam0915 New Member
    2017 Silver Tacoma SR5 4x4 V6 Double Cab
    Chrome Delete, Spacer Lift, 33” Tires. LED interior lights
    thank god for this thread. Just bought a used 2017 SR5 with this exact problem and was freaking out for over a week lol. Good to hear its no big deal
    whatstcp likes this.
  11. Apr 25, 2021 at 4:19 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    It's fine mine has done it for over 100,000 mi you will be ok I have same intake
