K&N intake kit?
Discussion in 'Performance and Tuning' started by jwhelan, Sep 25, 2009.
  1. Sep 25, 2009 at 9:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It means alot of dirt was getting thru the intake, into the engine. I tested 3 different Gauze type filters, The K&N, AFE, and AirAid.The AirAid was the only filter that had oils samples show "High" levels of silica. The other 2 had silica levels maxed out. :)
  2. Oct 2, 2009 at 7:54 PM
    warren_454
    warren_454 Member
    Adam
    Ky
    02 TRD Tacoma
    TRD cat back, K&N cold air intake.
    I just put on my 3.4 and I love it. It sound better and better throttle responce, it seems it has more power in the higher RPM.
  3. Nov 9, 2009 at 11:36 PM
    rzaucha
    rzaucha Big Member
    Sacramento
    If it ain't broken, I'll fix it.
    Rancho RS66901R9 upfront, Emu Leaf Pack in rear, 285/70/R17 BFG TKO 2's, Snugtop, TRD CAI, TRD Exhaust System, Thule Rack, JL Audio Stealthbox, Focal Access 165A1 SG, Pioneer AVH-X5500BHS, JL Audio XD500/3
    Here is the thing with after market air intake kits advantages or disadvantages argument; we have a little thing here in America called the FTC. If a company makes false claims or uses false advertising, they would be subject to class action law suits. If for instance, K&N guarantees HP gains, and they do, they must be held to that claim. A company as large, as reputable, and as successful as K&N doesn't get that way by duping consumers like us into buying a product that would take away from stock performance. If everyone felt that the product wasn't helping, someone (many) would be out there proving it and demanding their money back. Ever hear of Airborne?? So you have to look at it logically. In basic terms, engines are effected with how efficiently they breathe in and out. You either believe K&N when they say their product helps your engine "breath" in more efficiently or you don't. Until an ASE Certified mechanic that has the knowledge, and the facts to back the case that K&N is lying to me, I choose to go with the company and their claims and not taking the opinions on blogs or forums for facts. Just my two cents...
  4. Nov 10, 2009 at 7:30 AM
    Lichen
    Lichen Well-Known Member
    Scottsdale, AZ
    1997 Tacoma 2008 FJ
    Lifted, ARB bumper, Warn winch, IPF lights, CB, front locker, camper shell, roof rack
    I'm going to remove mine and put the stock set-up back in. The thing never has fit right. Duct tape around all of the connections. Big waste of money.
  5. Nov 10, 2009 at 7:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is not nessesarily the case. Manufactures HP claims say "Up to", or "On test vehicle", they more often do not clarify what the test vehicle is. I have tested alot of things that have "claimed" to give more HP, and found them to do nothing. The manufactures have plenty to hide behind preventing a lawsuit.
  6. Nov 10, 2009 at 8:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2. And they never state the conditions to which the test was performed.
  7. Nov 10, 2009 at 8:21 AM
    rzaucha
    rzaucha Big Member
    Sacramento
    Some companies/products may be able to "hide behind" unknown discrepancies (for example the medical field); however, things are more cut and dry in this regard. In this case, K&N does state exactly what their applications and outcomes are for each vehicle and product they test. For example:
    "Run Title: Stock 01 Tacoma 3.4L,auto 2WD2G Run Notes: Stock as delievered 11569 miles Run Date: 6/28/2001 11:51:48 AM Stock.001: 86.89 °F, 29.14 in-Hg, SAE: 1.03
    Run Title: FIPK 01 Tacoma 3.4L,auto 2WD2G Run Notes: 57-9015 FIPK installed 11569 miles Run Date: 6/28/2001 12:41:44 PM FIPK.002: 88.33 °F, 29.13 in-Hg, SAE: 1.03"
    This information is pulled directly from their company's official website. They state all the necessary factors that would produce a true and fair testing result.
  8. Nov 11, 2009 at 10:45 AM
    scriber007
    scriber007 Well-Known Member
    I thought K&N was originally made for dirt off roading, but it can't filter dirt. It does not make sense. Also no gains maybe because there are two kinds of intake pipes the plastic one and aluminum. So the metal one will absorb more heat.
  9. Nov 11, 2009 at 10:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They dont include "everything", as I have dynoed these (as well as other people) Installed on a few different trucks, and have seen very little, if any, gains. In a couple situations, even a loss was shown.
  10. Nov 11, 2009 at 10:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They all seem to suck in hot air from the engine compartment. Maybe as the vehicle is moving, they may show an air temp closer to ambient, but at low speeds, or idle, air temp is 10 to 30* hotter than OEM.
  11. Nov 11, 2009 at 11:36 AM
    rzaucha
    rzaucha Big Member
    Sacramento
    They (K&N) use the word "stock" which would mean a production line, no mods truck. Therefore they are including "everything" by choosing to use that word to describe their control vehicle. For the claim that you have installed them in different trucks with different results means nothing. If you don not use a stock truck with no mods, test with the same testing equipment as K&N, and test while under the exact same atmospheric conditions, there is no possible way to say if their product is in any way worse or better than what they claim. It is just not in any way factually or scientifically comparable. Again, just my two cents...
  12. Nov 11, 2009 at 12:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I understand what your saying, but if performing a mod to a vehicle, and getting a "Before" and "After" dyno sheet that shows no gains,little, or none, what other proof is there?
  13. Nov 11, 2009 at 12:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Another example....Throttle Body Spacers....100's of people have dynoed these, and have had no gains, other than a whisteling sound.....
  14. Nov 11, 2009 at 2:17 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    @ chris4x4 and rzaucha, you are both debating with very valid points.
    Will we always gain what was advertised? No. WAYYY too many variables that are uncontrolled. To sum up an entire product line based on a couple poor examples isn't really fair. Not everybodies motor will respond the same to the same mod.
    I personally dropped a .5 second in my 1/4 mile time going from stock to K&N intake and URD catback. Intakes will ALWAYS perform better when mated with an exhaust that matches airflow.
    Do I believe that I will gain 15hp from a K&N intake? Not really.
    Is it capable of adding that much power? Absolutely. Just in what scenario? Boosted truck with and without an intake will vary up to 30hp difference (that i've seen first hand on a TRD boosted truck).
    At the same time, our ECUs must relearn itself after installing a new mod. You can add an intake and very well see a loss in HP if the ECU isn't fueling right. Which is why its bad practice to run one right after the other.
    K&N is an open filter kit, so it is more prone to heat soak and idle and low cruising speeds. But in those conditions how much HP your making is completely irrelevant. it doesn't take long (in our trucks) for the IAT to drop to near ambient. The benefit of a closed filter is it gets there faster.
  15. Nov 11, 2009 at 2:18 PM
    #35
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    This is 100% correct. But using a TBS on our trucks is pointless, because we use ACIS to control the intake plenum runner length. So you are actually altering those lengths by adding a TBS. If toyota had more power moving that further away, they would have done so.
  16. Nov 11, 2009 at 11:08 PM
    #36
    rzaucha
    rzaucha Big Member
    Sacramento
    Because without comparing to the control, the before and after doesn't mean much as the equation has changed. So for you to give input that your truck or others didn't improve or that it lost power and therefore CAIs aren't a good mod is completely unfair to someone who most likely has a stock truck and is just looking for advice on a product (apples to oranges). Just trying to point out that I think CAIs are a great addition to Tacomas, and it seemed to be the only positive opinion in the thread, which I felt needed to be addressed.
  17. Nov 11, 2009 at 11:15 PM
    #37
    rzaucha
    rzaucha Big Member
    Sacramento
    Okay, so after re reading the thread there were others out there with positive opinions about CAIs, but way out numbered...
  18. Nov 12, 2009 at 5:00 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have tested them on stock trucks....Ok. Follow me here. You take a truck to the dyno shop. To get a baseline and see what the power is. Then, I have installed a "CAI", or whatever, then, 3 runs were done with the mod. Therefore, I had a correct baseline, for the conditions where I am at, then, dyno runs to see if a gain was made.
  19. Nov 12, 2009 at 5:12 AM
    #39
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Correct me if I am wrong.. Our stock intake (4.0 V6) is a basic 'CAI'. Cheaper to just buy a filter then to spend $250+ on the same product with a different sound.
  20. Nov 12, 2009 at 5:20 AM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. In fact, the OEM Intake is collecting air in a High Pressure area of the fender. Where as these "Cold Air" intakes are collecting air from a dead zone in the engine bay.
    In all the years I have been around these engines, I have YET to see a dyno sheet that mimicked the claims from these manufactures. I have found only 2 CAI that have shown gains. The TRD/AFE (as it pulls air from the OEM location, and the URD intake. Though I have not personally tested the URD Intake, Gadget has been doing this for a long time, and many of the dynos I have done in the past, have reflected the same gains he has found, so I have NO reason to doubt his claims.
