K&N Intake problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Riggs714, Oct 30, 2022.
  1. Oct 30, 2022 at 11:56 AM
    Riggs714
    Riggs714 [OP] Member
    Kyle
    2015 Toyota Tacoma
  2. Oct 30, 2022 at 12:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Maf backwards?
  3. Oct 30, 2022 at 12:18 PM
    Riggs714
    Kyle
    2015 Toyota Tacoma
    There’s no way to install it backwards. It only fits in one way and only clips to the harness one way
  4. Oct 30, 2022 at 12:22 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Get rid of the intake.
  5. Oct 30, 2022 at 12:24 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    U didn’t leave a rag or something in there or something ?
  6. Oct 30, 2022 at 12:26 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Disconnect battery completely for a while to reset your computer.
    Geeves77 likes this.
  7. Oct 30, 2022 at 12:29 PM
    coolrunning39
    coolrunning39 Well-Known Member
    Central Park/North Aurora
    2017 Toyota Tacoma
    Does it work fine with the stock intake?
  8. Oct 30, 2022 at 12:33 PM
    Riggs714
    Kyle
    2015 Toyota Tacoma
    No
  9. Oct 30, 2022 at 12:33 PM
    Riggs714
    Kyle
    2015 Toyota Tacoma
    I left it disconnected throughout the install, didn’t help.
    Oldie2007[QUOTED] likes this.
  10. Oct 30, 2022 at 12:33 PM
    Riggs714
    Kyle
    2015 Toyota Tacoma
    Yeah works perfectly fine again with stock intake back on
  11. Oct 30, 2022 at 12:35 PM
    Riggs714
    Kyle
    2015 Toyota Tacoma
    Wow what a tremendous help you’ve been.
  12. Oct 30, 2022 at 1:07 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Your getting more air in the system
    Go through the throttle re-learning process
    Google it may be simple fix
  13. Oct 30, 2022 at 1:14 PM
    daluvian
    San Diego
    2005 Tacoma
    Long travel
    Can you snap some pics?
  14. Oct 30, 2022 at 1:51 PM
    TegoTaco
    Ontario, Canada
    :rofl:
    Steves104x4 likes this.
  15. Oct 30, 2022 at 4:59 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    This is not the place to ask questions about K&N filters - the K&N filter haters on this site are merciless.
    I would re-install the K&N making sure all of your connections are secure. Restart, and If and after it dies, continue trying (5 or 6 times). There is no reason that the truck should not run with the K&N unless there is an installation error. Contact K&N.
    Ps - Your engine won't suffer any catastrophic failure from running a K&N filter and the engine will likely last for as long as you own the truck.......(my personal experience from decades of K&N usage)
  16. Oct 30, 2022 at 5:33 PM
    TegoTaco
    Ontario, Canada
    Too much oil on the filter?
  17. Oct 30, 2022 at 5:35 PM
    TegoTaco
    Ontario, Canada
    Make sure the maf sensor harness is plugged all way in…sometimes it happens to me when I clean my MAF.
  18. Oct 30, 2022 at 5:51 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Most just hate it because of the fact that they are terrible at filtration. All you are paying for is for bad filtration, more noise, good looks, and increase wear and tear for little to no performance increase. If you want it for good looks and more noise then go for it. If you're looking for more performance increase then your not really going to see much of that at all.
    Dm93 likes this.
  19. Oct 30, 2022 at 6:44 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    What he said.
    TegoTaco[QUOTED] likes this.
  20. Oct 30, 2022 at 6:51 PM
    Waasheem
    Waasheem
    2007 xrunner
    This is a common cause of problems caused by them.
    If just enough oil is good, a little more must be better, so too much will be even better. WRONG. The excess gets sucked in the intake, the maf is right after the filter so it gets an oil shower.
    I too ran them for years, even being careful when oiling, I still managed to destroy a couple maf sensors.
    If you’re gonna use it, you could try oiling it, leave it sitting for the oil to disperse, then wrap it in paper towels overnight to wick out the excess.
