K&N Intake vs AFE Intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Corndawg, Jun 14, 2012.
What do you Have on Your Tacoma ?
Poll closed Jul 14, 2012.
  1. All you K&N fans
    10 vote(s)
    25.6%
  2. AFE
    29 vote(s)
    74.4%
  1. Jun 14, 2012 at 9:11 AM
    Corndawg
    Corndawg [OP] Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    What is your guy's Opinion on the two
    ive been considering K&N but am New to AFE
    so what do you think or Run
  2. Jun 14, 2012 at 9:23 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    K&N aren't a good application for our trucks, the oil from the filter will gunk up your MAF, the AFE is a dry washable filter, no oils to get anywhere, I've got the AFE and have had no problems with it.
  3. Jun 14, 2012 at 9:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Between those 2, I'd pick the AFE stage 2 Si but both are a waste of money if you're expecting performance gains. The K&N pulls hot air from inside the engine bay so you'll be drawing hotter air than the stock intake. The stock intake already pulls from the fender so it's pulling cold air as is. Save some money and get a good drop in filter unless you want more noise.
  4. Jun 14, 2012 at 9:24 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Didn't see OP was talking about full intakes...
    Yeah, just get the drop in AFE, it's really the best option.
  5. Jun 14, 2012 at 9:57 AM
    Japes
    Japes Member
    Calgary, Canada
    11 TRD Double Cab Short Box
    I don't know much about the k&N for the truck but I am running the afe and I love it.
    I'm going to be switching to the dry filter here shortly. great sound and I've noticed some MPG gains as well.
  6. Jun 14, 2012 at 5:16 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Hard to beat the AFE..had mine waiting for the day I picked up my truck!!!
  7. Jun 14, 2012 at 5:31 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  8. Jun 14, 2012 at 5:31 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    That's somewhat right and somewhat wrong.
    Over oiling is the issue. If you oil a K&N properly you will have zero issues. I ran my truck for 80k on a K&N without issue, but I have also been using K&N filters for over 15 years so I know how to do it. The rookies over oil and have issues.
    That said K&N filters suck in silica so if your in a dusty environment they are no good IMO. That's the only reason I changed after so many years.
    After much research ALL of the re-usable filters fall short when filtering. I have chosen to go back to OE type for max filtration.
    Wix air filters are $12 per and you can get a case here http://www.discountfleetsupply.com/wix46888.html
  9. Jun 14, 2012 at 5:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A stock filter and intake pipes will flow more air then you engine could ever use if you like noise use any aftermarket that is the only thing you'll gain except for a little more dirt.
  10. Jun 14, 2012 at 7:19 PM
    Deercantseeme
    Deercantseeme Well-Known Member
    Massachusetts
    Afe power magnum force intake. Works pretty good for me.
  11. Jun 14, 2012 at 7:41 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Neither intake is beneficial (i.e. gain less than 1 hp) until you go forced induction.
    I think money is better spent elsewhere on the truck.
  12. Jun 14, 2012 at 7:49 PM
    KenLyns
    Belly of the Beast
    Have there been trustworthy dyno charts published showing before and after results?
  13. Jun 14, 2012 at 7:57 PM
    buddyfixit
    buddyfixit Well-Known Member
    Jon
    DFW Texas
    2012 4x4 SR5 Avid Lightbar "super taco"
    TRD air filter, Predator Step Bars, WeatherTech Floor Liners, Avidoffroad Lightbar, B.A.M.F. lightbar, Rearview Mirror Bracket, Console Organizer, CH Holster in dash, More to come...
    I put a TRD oiled filter in when I purchased my 2012 new. It was so over oiled out of the pack that it actually seeped out and dripped onto my pipes and burning. wasnt happy but continued to use. Any recommendations on another, or just go back with stock filters?
  14. Jun 14, 2012 at 8:04 PM
    Blacktacoma23
    2011 Mall Crawler
    X2
  15. Jun 14, 2012 at 8:24 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    X2
  16. Jun 15, 2012 at 5:10 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I had a K&N "CAI" Now I'm running a AFE Stage 2 Si. Also if you want a K&N "CAI" mine is for sale.
  17. Jun 16, 2012 at 3:39 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    This ^
    Just get a AFE Pro Dry S Filter if you feel the need to MOD your air intake. :cool:
    I ran the drop in filter and my MAF went bad...not sure if it was related to the filter but I went back to a Toyota filter. Its to damn dusty out here anyway to let any dust through. OEM Filters are the best IMHO but wanted to see what all the hype was about with the drop in filters....wasn't impressed and saw no gains
    Anyway back to the poll...I vote AFE
  18. Jun 19, 2012 at 9:48 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I've been running K&N CAI on my vehicles since the mid 90s and the applications for the Toyota Tacoma is the worst I have ever come across. Even though I did try to find an old TRD CAI system, I went ahead and bought a new TRD and threw away my K&N. I got tired of sucking hot air into the engine...
  19. Jun 19, 2012 at 10:12 AM
    stowayman
    stowayman Well-Known Member
    Gary
    Monterey, CA
    08 DC 4X4 TRD O/R - Debadged
    Kenwood DNX9980HD Nav - BT - Sirius - backup camera, Weathertech digifits, maglite mod, 14" billet antenna
    Both are a waste of time and money... keep the stock intake and save your cash
