K&N Intake VS Factory Intake (AFE Filter Resonator Removed) **My Observations**
Discussion in '4 Cylinder' started by JEA86, Feb 11, 2011.
  1. Feb 11, 2011 at 7:17 AM
    JEA86
    JEA86 [OP] Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    well first off i want to say that i have a 2010 Reg Cab 4x4 5 speed
    and second i would like to say i am no dummy whenever it comes to intake systems on newer vehicles (i built intakes for the newer model civic si's)
    This truck had some major suffering in the hills here in WV and i was constantly having to gear down to make it up them whenever i should have been able to at least stay in 4th. (that was my main complaint)
    So i want to say first off i bought a K&N intake for a great deal from a member on this forum,
    K&N first impressions, i think they did a good job with the design and fitment of this intake system, a complaint i had was that you can not fit the filter flush with the heatshield as the vibrations and noise will drive you crazy, so i can see where there would be some engine compartment air that would make its way into there.
    Driving, the K&N took a little bit to adjust on my truck and still never ironed out the idle issues, and i think it solely has to do with the MAF placement VS where its placed on the stock box, its too far downstream, Also when at a stoplight for a long period of time the truck would idle and then drop down to where it almost died out and then would kick back up (keep in mind everything was installed correctly)
    Upon hitting the gas i realized the truck did in fact rev much more free. And the sound inside the cab past 3k RPM's was very loud. Could i tell a performance gain... possibly more of a placebo effect of the noise being so loud. However one thing i did notice was that the Truck was now able to go up hills without downshifting, so i knew there was a difference made somewhere. i was also able to hit 159.2 miles before the truck dropped below 3/4 of a tank (this was driving very very slowly and easy) and pulled of 23.5 miles per gallon.
    Now i have since switched back to the Stock airbox, Secondary filter Removed, AFE Pro Dry S drop in filter, and the Fender resonator Removed.
    Now i can honestly say this made the biggest difference in the truck, The truck is alot more peppy even over the K&N intake what i did lose was the annoying loudness at higher RPM's
    The truck is able to pull through the revs just as easy as when the K&N was on, Removing the fender resonator i feel helped out alot because i am able to pull hills just like before with the K&N intake installed, Truck just drives the way it should have from the beginning,
    Sound is similar to stock with a little bit more grunt but nothing annoying at all, you do hear the air wooshing in at crusing speeds though, more neat sounding than annoying.
    Final Impressions,
    spend the 38.99 for the AFE drop in remove the secondary filter and the fender resonator and you will have a better performing intake than the K&N IMO, i have yet to run through a full tank on the Stock/AFE setup so to be fair i dont know if gas mileage will improve as with the K&N, But the benefits are this,
    Stock box has the pelinum still in tact over the motor
    Stock box has the Correct MAF readings in place for the ECU
    Resonator, Secondary filter, and Stock filter are about the only restrictions to the stock intake and with this they are out of the picture.
    Overall i am just confirming what everyone else has said save your money buy the AFE drop in and spend a little time removing the restrictions that your factory intake has.
    Keep in mind the secondary air filter is for emissions (but we dont have that testing in WV) the Fender resonator is for nothing but sound deadning.
  2. Feb 11, 2011 at 7:21 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    This is the 2TR-GFE engine we're talking about, correct?
  3. Feb 11, 2011 at 7:58 AM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    i know on my 4 cyl it made a big difference.
    and i am not sure exactly the engine code of the 2010 toyota tacoma but 2TR sounds about right
  4. Feb 11, 2011 at 10:34 AM
    tencrawler
    tencrawler I'm a lover not an expert
    Wes
    Petaluma
    1985 Pickup 4x4 SCLB 22R 5SPD Manual
    Only 55K Original Miles in Spring of 2018
    What part of the intake is the fender resonator? pictures or descriptions would be helpful. I'm currently running a K&N drop in w/ secondary removed, and interested in removing the fender resonator. Thanks for the help in advanced.
  5. Feb 11, 2011 at 10:49 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Here's a thread that shows the resonator. It's from a 4 banger, so I don't know if the v6's are the same or not.
    http://www.tacomaworld.com/forum/4-cylinder/71559-2-7l-filterbox-mod-pics.html
  6. Feb 11, 2011 at 11:01 AM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    Good to know, i have 07 dc automatic w/ 4.0. I had no problems with the the install, or tone. like jea said, i did have to remove part of the top cover but im not getting any vibration from it or where the air filter is placed. Maybe i just dont notice due to it being on there so long..
    Most of the mods done to any motor that are simple bolt ons, really only compliment a built motor. yes you can free up a few ponies but at most you will probably only see 15-20 hp. ie: headers, full exhaust, cai, and a tune.
    Those mods really shine when you start boring, porting and poishing, adding fuel, supercharging, and turbos. best thing to do imo is gears.
    JEA nice comparison.
    California emisions suck!!!!! Your lucky man..
