K&N mpg impact?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachtacomaFL, Jul 19, 2008.
  1. Jul 19, 2008 at 2:47 PM
    beachtacomaFL
    beachtacomaFL [OP] Member
    I have the I4 engine in my truck. Has anyone out there installed a K&N intake on this engine, and if so, did it hurt the mpg?
    Thanks, oh, and Tacomas are SO much better than Dodges its unreal.
  2. Jul 19, 2008 at 3:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!!:)
    actually, people are having alot better luck with removing the secondary air filter and instalkling an afe pro dry s filter.................this is a filter you clean, but its good because its non oiled. plus, it catches more dirt/debris than a k&n.
  3. Jul 19, 2008 at 4:37 PM
    beachtacomaFL
    thanks, I appreciate the help
  4. Jul 19, 2008 at 5:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no problem man!:)
  5. Jul 19, 2008 at 7:56 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I personally would (and did) stay away from oiled filters. IMO, it's old technology and there are better filters out there.
  6. Jul 19, 2008 at 8:06 PM
    davz45
    davz45 Member
    Middle Alabama
    07 PreRunner
    Typical chrome,tool box,steps,tint...
    So..could you tell me more about this filter??? is it a system? or just a filter? and ?? $$$ and where'd you get it? paaaleeezeee??:D:D;)
    Dave
  7. Jul 19, 2008 at 8:29 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
  8. Jul 19, 2008 at 8:50 PM
    missileman125fw
    missileman125fw Well-Known Member
    OK, I've got a real stupid question. I bought my Tacoma with the Borla exhaust. With the exhaust came a 100,000 miles before replacement filter. It didn't come with instructions and I'm all about following the instructions!!! How do you clean the filter? It is a dry filter, if that matters. Thanks....
  9. Jul 19, 2008 at 8:54 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Depends on the brand. With the AFE, you can tap it, vacuum it, or wash it. Each method gets it progressively cleaner, obviously. I know with the AEM Dryflow (had one on my Altima), you use a cleaning kit.
  10. Jul 19, 2008 at 9:11 PM
    missileman125fw
    So I could take it to work and use compressed air to get it clean?
  11. Jul 19, 2008 at 9:13 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I would never use compressed air on a filter.
  12. Jul 19, 2008 at 9:31 PM
    missileman125fw
    Oh shit! I was about to do that Friday night.
    Do you think about 90 psi would mess it up?
  13. Jul 19, 2008 at 9:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if its a paper type filter.....you can use compressed air on it, just dont keep a steady stream of air in one spot, or it could tear up the filter.
  14. Jul 19, 2008 at 9:49 PM
    missileman125fw
    Thanks, I'll take care of it Monday at work. I've noticed a drop in MPG and I figured it's got to be the filter.
  15. Jul 19, 2008 at 9:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey mm, is yours an actual paper filter,or is it one of those cotton gauze type filters??
  16. Jul 19, 2008 at 10:09 PM
    missileman125fw
    Ya know, I've only looked at it once. And I couldn't tell you. How do you know the difference?
  17. Jul 19, 2008 at 10:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    one thing you can do is drop a bit of water on the filter and see how it reacts to the filter. if its the paper type, it'll soak in more than likely, but if its the cotton gauze type, the water should sit on top and not soak in right away. at least thats the way i'd try it. or another way.............does the filter have a mesh type screen all over the entire filter??
    eithewr way though........you can used some compressed air(blow out the side the air comes in), just dont put alot of pressure on it.
  18. Jul 19, 2008 at 10:18 PM
    missileman125fw
    Sounds like a wiener to me! Thanks, oh and go check out the MM thread. I posted a goodie!
  19. Jul 19, 2008 at 10:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    10-4....im on it:D!!
  20. Jul 19, 2008 at 10:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dry filters can be cleaned with comprssed air, just spray it from the inside, out. I have cleaned about a million filters this way. :)
