K&N Oil Filters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joey B, Oct 5, 2011.
  1. Oct 5, 2011 at 3:40 PM
    Joey B
    Joey B [OP] Member
    California
    06 Tacoma Reg.Cab 2.7L
    Pioneer deck 2 JL 10' subs Pair of JL speakers and tweeters 700 watt 4 channel & 300 watt 2 channel interfire amps 4pc grille set flowmaster muffler K&N air filter NGK Iridium Spark plugs 18' chrome DZ wheels 3' drop blocks in the rear
    Hello everyone I was gonna do an oil change soon and was thinking of using a K&N oil filter this time. I was wondering if there is anything special about these oil filters like if they give better gas mileage or hp or anything at all. Any comments are much appreciated thanks.
  2. Oct 5, 2011 at 3:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I havent heard anything good about K&N oil filters but the fact that they are pricey. I've always used the Toyota OEM filters.
  3. Oct 5, 2011 at 3:46 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Since when do oil filters give horsepower or better gas mileage? Like just throwing anything with a K&N logo onto your truck will do that?
  4. Oct 5, 2011 at 4:24 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Anything that says K&N will automaticall add 15hp as long as you put on the sticker.
    On a more serious note...the only good thing is the nut at the top. Thats it. OEM are the best quality
  5. Oct 5, 2011 at 4:55 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I read on another Toyota website that moving your oil filter to the other side of the motor helps it stay cooler, easier to change, and lets you run a bigger filter for better filtration. It is kinda like the air box/battery swap for 22RE motors.
