K&N or AFE?
Discussion in 'Performance and Tuning' started by scott20054, Oct 4, 2010.
K&N or AFE?
  1. K&N Aie Filter
    239 vote(s)
    31.6%
  2. AFE Pro-Dry S Air Filter
    443 vote(s)
    58.6%
  3. Other
    74 vote(s)
    9.8%
  1. Aug 1, 2011 at 11:24 AM
    #61
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    What does rpm have to do with your air cleaner? Your transmission and rear end control the rpm/mph.
    There is no reason your rpm would be higher with one filter over another unless somehow your torque converter isn't locking up with one for some reason?
  2. Aug 5, 2011 at 2:07 PM
    #62
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    :popcorn: lol
  3. Sep 7, 2011 at 9:54 AM
    #63
    jastampke
    jastampke Member
    jason
    texas
    08 4dr trd long box
    blhm,3" pro comp lift, afe pro dry drop in, dynomax super turbo exhuast, debadged, aux jack added to radio.
    does either filter help with mpg. should i go with the entire cold air system or just a filter for better mpg?
  4. Sep 7, 2011 at 10:03 AM
    #64
    worthywads
    You won't get better mpg with a different air filter, or cold air system.
  5. Sep 7, 2011 at 10:13 AM
    #65
    Big R
    Big R Member
    James Gibbs (randy)
    Litchfield Park
    2006 PreRunner Leather trim.avic 110bt stereo
    Leather,airaid,avic110bt,kappa speakers front rear,jl w3 10 inch sub,angel eyes front lights ,azzel rear lights,sport hood and a few more to come
    I like Airraid. :)
  6. Sep 15, 2011 at 1:35 PM
    #66
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    I realize this thread is old as dirt, but K&N is not difficult to clean or oil IMHO. The whole process takes 5 minutes (plus time to dry before oiling). I've no complaints with K&N and I'm on my 4th vehicle with K&N now and still using the same recharging kit.
  7. Sep 16, 2011 at 6:45 PM
    #67
    COBOUNDTACO
    COBOUNDTACO Well-Known Member
    Denver
    2014 DCLB 4x4 TRD Sport Pyrite Mica
    I've always run KN in everything. The box says clean every 100,000 miles and that build up in the filter helps filtration. I know dusty/offroad conditions warrant cleaning more often, but over cleaning is bad for the filter. Did I read it wrong?
  8. Sep 17, 2011 at 6:38 AM
    #68
    friction
    Charleston, SC
    '08 4X4 RC SR5
    I don't think you want to clean it too often. My approach is clean it religously - which is to say, only when I think of it. ;) That works out to about twice a year.
  9. Sep 18, 2011 at 1:15 PM
    #69
    Sanders17
    Sanders17 Well-Known Member
    Reed
    Livingston, TN
    Black Sand Pearl 08 TRD Offroad
    AFE definitely
  10. Sep 20, 2011 at 4:41 AM
    #70
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    even tho i am an amsoil dealer, i use afe. tired of the oil mess and problems which can result therefrom.
  11. Nov 13, 2011 at 11:29 AM
    #71
    rubberduckytaco
    rubberduckytaco Well-Known Member
    nicholas
    sumter sc
    09 prerunner dc sb
    running boards, backup camera, yellow fogs, camo interior
    would there be a difference in just putting the afe filter in oem box vs putting a afe filter on a CAI? im new to this so dont yell at me :help:
    p.s. can someone provide a link to buy such items please and thanks
  12. Nov 14, 2011 at 4:43 AM
    #72
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    i just bought the are and put it in the stock box. google are air filter and you'll get bunch of online stores selling them. i don't remember the name of the place i bought from. but it was 55 bucks shipped. by the way, according to my ultra gauge, my mileage did increase. when a motor doesn't have to work as hard to pull air in, up goes efficiency.
  13. Nov 14, 2011 at 8:26 AM
    #73
    worthywads
    Your ultra gauge isn't precise enough to tell one way or the other, but strict laboratory testing using precise repeatable test loops say they don't increase mpg.
    http://www.fueleconomy.gov/feg/pdfs/Air_Filter_Effects_02_26_2009.pdf
    Pretty simply, the filter is not the restriction that is causing the motor to "work hard to pull air in" as you say. Under anything but wide open throttle, the throttle plate restricts the intake, that is how a gas motor is controlled. At any cruising speed the throttle is only slightly open, this causes the restriction and it doesn't matter if the air filter is more or less restrictive as the throttle plate is by far the biggest restriction. With no filter the throttle plate may open slightly less for the same speed, with a nearly clogged filter the throttle plate opens slightly more for the same speed but the mpg stays the same and the total restriction stays the same.
    A restricted air filter may produce slightly less HP at wide open throttle and at 4-6000 rpm, but at part throttle it doesn't matter.
    But throttle response, that another story. :rolleyes:
  14. Nov 22, 2011 at 3:24 PM
    #74
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I just added an old used KN cone filter to the end of my oem intake arm. No significant gains over drop in amsoil filter. Just better throttle response on take off.
  15. Nov 22, 2011 at 7:34 PM
    #75
    Unzapato
    Unzapato Well-Known Member
    Randy
    Texas
    My 3rd Tacoma
    Blank slate - brand new!
    I guess it depends on your maintenance desires since the AFE is winning the poll. I've used K&Ns on my bikes and trucks for many years and never minded cleaning them. The manufacturer's data alone is enough to make me stick with K&N. The purpose IS to increase air flow after all.
    AFE PRO DRY AIR FILTER = 416 CFM
    K&N = 706.3 CFM
  16. Nov 22, 2011 at 8:09 PM
    #76
    worthywads
    If the engine can't use it, it doesn't matter.
    CFM = CID X RPM X VE / 3456 (3456 = 12" X 12" X 12" X 2 revs per CID)
    CFM = 242CI X 5500RPM X 90% / 3456 = 346 < 416 < 706. Even 100% volumetric efficiency is less than 416 cfm
    You aren't increasing air flow just because the filter can flow more.
  17. Nov 23, 2011 at 6:59 AM
    #77
    Unzapato
    Randy
    Texas
    My 3rd Tacoma
    :rolleyes: Under perfect conditions where zero dirt exists that is true (even though that math is way beyond anything I want to figure out), but the fact is there will always be dirt in the filter. Given the same amount of crud build-up in both filters, the less restrictive filter will give better performance. Again, individual maintenance preference matters more, as they are both great filters. I'll stick with the K&N. They are cheaper anyway.
  18. Nov 23, 2011 at 7:18 AM
    #78
    worthywads
    The point is the engine doesn't need a high flow filter if it doesn't flow that much air anyway. You can't get better performance if the filter can outflow the engine.
  19. Nov 23, 2011 at 11:22 AM
    #79
    Unzapato
    Randy
    Texas
    My 3rd Tacoma
    Point taken.
    My point is dirt in the filter will restrict airflow. If not, why do you ever have to change/clean it? The less restrictive filter will remain the less restrictive with the same amount of dirt packed into it. If you are saying there is no point at which a clogged filter restricts airflow then you are dreadfully wrong. By your logic one should never have to change the factory filter.
    Anyway, find a paper element filter with factory specs that is cleanable/reusable that is cheaper than both and I'm in there like swimwear.
    Otherwise: 1x $54 K&N > 1x $57 AER > Many x $24 Fram filters over the lifetime of the truck.
  20. Nov 23, 2011 at 11:57 AM
    #80
    worthywads
    After reading the link that I provided on post 77 I have decided to go 60k miles interval before changing the filter for me. They found no change in MPG but reduction (7%) power with filters that are 2-3 times more clogged than a filter with 30k of use. A dirty filter actually filters more, which is a good thing. No argument a very dirty filter will reduce peak power, but not with your typical 30K interval.
    With my 2.7L I don't care if I lose a few HP at 5500rpm, I don't see that engine speed anyway. I picked up 3 oem filters at the dealer for $14.99 each, that's 240k for $45 including the original.
