K&N or TRD air filters. Worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymay82, Jan 20, 2013.
  1. Jan 20, 2013 at 2:51 PM
    jaymay82
    jaymay82 [OP] Well-Known Member
    '13 MGM TRD Sport DCSB
  2. Jan 20, 2013 at 2:52 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  3. Jan 20, 2013 at 3:00 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    If noise is worth it then maybe.
  4. Jan 20, 2013 at 3:03 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Depends on "worth it ". What are you expecting from a washable filter? I like them, don't mind washing them, don't have to buy another filter or remember to buy one or search for one.
    Better gas mileage probably not. More hp, probably not.
    Jim
    Rsmallw2, kystnTRD and Byb127 like this.
  5. Jan 20, 2013 at 3:12 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I have a K&N drop in and I haven't fond anything negative about it. I take it out and knock the big stuff out at every oil change and then clean and oil it when it needs it. Lot's of negative and positive on this site but as far as is it worth it to you? I don't know.
  6. Jan 20, 2013 at 3:12 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Stock filters better op unless you have a coupon to get one for cheap go for it haha
  7. Jan 20, 2013 at 3:14 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I'm thinking of buying a AFE Pro Dry S filter...
  8. Jan 20, 2013 at 3:17 PM
    MWall
    MWall Well-Known Member
    Mark
    Wichita, KS
    TRD Off Road
    Found a K&N for under 40.00, not a CAI, doubt I'd do another one of those if/when they hit the market for '12+ Tacomas'. I will buy a K&N filter once Toyota stops changing them for free!
  9. Jan 20, 2013 at 3:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fixed that for you.
    It does not filter as well as stock.
    I've seen cylinders on engines "protected" by K&N filters show severe scoring, yet the factory honing crosshatch is still visible... plenty of life left in the steel, but they have oil consumption problems because of bad air filtration. Ever wonder why you see so many relatively recent model Civic and Corolla "Ricers" that smoke like a '72 Impala? The poor filtration has destroyed the engine.
    Do yourself a favor.
    Next oil change, send a sample to Blackstone.
    On the new oil, switch back to the OEM filter. Run that filter for three oil change intervals and then send a sample to Blackstone.
    Note the difference in Silicon levels.
    That is dirt... in your oil. Dirt that has passed into the engine and past the rings on it's way into the oil, leaving scratches as it goes.
    WebberLander likes this.
  10. Jan 20, 2013 at 3:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    $40 for a drop in, and $20 for the cleaning/oiling kit.
    That's $60.
    OEM filters are $15 each and they are to be inspected at 30k, changed at 60k (unless needed at 30k).
    $60 paid for OEM filters will cover your engine for at least 120,000 miles unless you slam your filters offroading.
  11. Jan 20, 2013 at 3:21 PM
    MWall
    Mark
    Wichita, KS
    TRD Off Road
    Very interesting, do you have any sources? Where did you get the info? Thanks.
  12. Jan 20, 2013 at 3:25 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I had a '94 Toyota pickup with a 22RE that burned oil.
    Traded it in with 225k on it... it burned a quart every 3000 miles.
    I've personally seen engines opened up with scoring (I've been twisting wrenches since before we walked on the moon).
    I've sent used oil to Blackstone for analysis from my motorcycle. I'm stuck with a K&N due to the intake design (poor decision). Blackstone has commented on every sample since the intake change that I should check my filter.
    K&N filters were designed for racing vehicles that only need to "last" 500-1000 miles between rebuilds.
  13. Jan 20, 2013 at 5:10 PM
    MWall
    Mark
    Wichita, KS
    TRD Off Road
    ok, I wasn't doubting you, just asking. So in your opinion factory filters are better? What about fram's from walmart? Better than putting a K&N on it? I know my last one said it functioned better dirty and they didn't recommend cleaning it every oil change.
  14. Jan 20, 2013 at 5:25 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'd stick with OEM (and they are available inexpensively from Camelback, Titus-Will, or Toyota of Dallas, likewise for OEM oil filters at $4), but the Fram air filters are not bad filters. Fram's issue with oil filters is cheap construction and low filtration area. Their air filters are not hidden in a can, and are well-made filters.
    Personally, I'd run a Purolator before a Fram if available, but that's simply a personal thing in not wanting to support Allied's Fram division. I'd run a Fram before I'd run another K&N air filter.
  15. Jan 20, 2013 at 5:26 PM
    MWall
    Mark
    Wichita, KS
    TRD Off Road
    noted. thanks I think you just saved me forty bucks.
  16. Jan 21, 2013 at 6:40 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    K&N's can and will filter as well as anything when its kept CLEAN and OILED properly. The oil is what catches the fine particles. If the oil gets over-penetrated with dust/dirt...it can't filter properly anymore and thus allowing dust to get past it. I've owned K&N's in several vehicles. I've washed them twice a year to keep them properly cleaned. Any oiled filter will act the same way....they're not something you can throw in your truck and expect it to work for long periods without maintaining and cleaning. If you over-oil them, can also cause problems.
    So - theoretically....if you leave the K&N filter in your truck too long without cleaning it, it will allow dust past it. You can't blame K&N for that.
    If you can't regularly maintain a K&N - then perhaps people shouldn't buy one. And yes...I stopped buying them because I don't want to clean it every 6 months. I bought an AFE and I clean it once a year.
    JeancoLunarTaco likes this.
  17. Jan 21, 2013 at 6:50 AM
    XXXX
    sKiP
    05 Prius
    Just wait..... you will see negatives sooner then later
    X2.....
    Install one and then clean your intake after the filter. You can see visually the difference of dirt the K&N lets in.
    I was running K&N's for over 20 years until this year. I have always followed the directions and cleaned them regularly. K&N actually states the dirtier they get the better filtration they provide so not so sure about your theory.
    I never had issues in the past running them on quads, dirt bikes, and my other vehicles but I also did not drive them in the dusty conditions I drove my Tacoma in.
    I have no scientific evidence that K&N's allow more dirt to pass, but I have physical proof. The difference between a K&N and OE type Wix paper filter is very evident should you ever clean your MAF/intake.
    Once I saw all the dirt getting by last year I decided to change over to Wix OE type filters. Since then my #6 cylinder has developed horrible scoring and the engine is now FUBAR. While I cannot blame the failure on anything specifically until I tear it down I do believe running the K&N on a truck with a snorkel in very dusty conditions did have a hand in the failure.
    So to all out there...if you want no issues stick with stock. It's tried and true.
  18. Jan 21, 2013 at 7:13 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    It's very simple filtering vs. flow, can't have both.
    Oiled cotton gauze filters (K&N, TRD, etc.) have been shown by many independant tests (some "company" sponsored, some not) to definitely flow better, but that they do not filter the finer dirt as well as paper or even oiled foam. Also oiled gauze filters, from these tests, show that they actually do filter better the dirtier they get, up to the dirt holding limit, whereby they stop flowing too. IOW, a clean oiled gauze filter flows best, but filters worse, while a dirty filter flows worse, but filters better.
    Some searches will find several tests done, and some time on BITOG will prove out the increased silica levels when using oiled cotton gauze filters.
    BTW, from the research I've done, the aFe dry filter is a bit of an outlier here. The oil analysis data that I've seen shows an initial small increase in silica, then it levels out (after the filter gathers a bit of dirt) and holds. I would assume it holds until the filter is washed out anyway. I haven't seen any independant tests that included the aFe dry type filter.
  19. Jan 21, 2013 at 7:27 AM
    Janster
    Jandy
    Lancaster, PA
    I would doubt their own theory *dirtier they get the better filtration* as that just goes against all air filter common sense. Besides that - you probably won't see them advertise a dirty filter will give you the same airflow as a clean one, which....defeats their claims on both ends.
    K&N's are for horsepower & more airflow (theoretically) and probably not a good idea for dusty conditions anyway.
    I never saw dust past my filter when I cleaned it every 6 months. The dustier the conditions...the more often it should be cleaned. That's my story anyway, and I'm sticking to it. :p
    Everyone else can make their own decisions based on the positive and/or the negative feedback.
  20. Jan 21, 2013 at 7:44 AM
    miniceptor86
    Jim
    McGregor,IA
    More fuel for the fire!
    I put the TRD CAI on my Tacoma almost as soon as I bought it new. 85K miles on it now. Just yesterday I did a little preventative maintenance, cleaned the filter, pulled mass air flow sensor, pulled the tube to the throttle body. Did the white glove test, actually white paper towel, on the front of the throttle body clean as a whistle, mass air flow sensor (never been cleaned) bright and shiny.
    I have a K&N in my '86 500 Interceptor, been there since around 18K miles, now at 45K still is with in factory compression specs, no problems related to intake air dirt, air box is always clean, changed out carbs for the larger '84-85 versions at 42K, old carbs and intake boots clean inside. This on an engine that is very fragile compared to the GR1-FE and runs about close to a 1000 rpms per 10 miles an hour in 6th with factory final drive gearing.
    160K on my '92 Ranger 4.0 K&N no engine problems related to dirt getting past the filter. 8 paper air filters in that mileage = reasonable=at least $80. $40 something for the K&N=I'm ahead if I don't look at my labor to clean and the minimal amount of oil.
    Sorry your results varied.
    Jim
