K & N replacement filter question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackat, Aug 12, 2016.
  1. Aug 12, 2016 at 3:51 PM
    Blackat
    Blackat [OP] Well-Known Member
    Bryan
    Colorado
    99 Tacoma SR5
    TRD Stat, TRD Supercharger, TRD Headers, TRD Cat-back, slight lift.
    So I called Auto Anything to order an oil free filter(dry filter) AeF to be exact.
    They told me I can't replace the cone filter part with an AeF filter because the K & N rep said it won't work right.
    I'm calling BS.
    Am I right? If I measure my existing filter and replace it with the same size it shouldn't matter?!
    Anyway, I'm tired of oiling the filter hoping I have enough oil but not too much that the MAF gets blow by oil.
    I've had the K & N since I put the SC on back in 1999.
    What say ye?
    TIA
    Bk
  2. Aug 12, 2016 at 4:20 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    doesnt matter what brand the filter is. the rep just didnt want you going to a superior filter of another brand.
  3. Aug 12, 2016 at 5:00 PM
    Blackat
    Bryan
    Colorado
    99 Tacoma SR5
    Thanks. Thats what I thought too.
  4. Aug 13, 2016 at 12:36 PM
    1997tacomav6
    Denver
    I have the same setup with supercharger, and yes oiling it is a pain and if you put to much oil the MAF gets messed up.
    I have 500,000 on my K&N and I just use the pre oiled filters from them and replace the filter every
    50,000 miles with road use. I have zero issues with there setup.
