K&N vs TRD air intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rdcar, Aug 1, 2010.
Which air intake is better?
Poll closed Aug 31, 2010.
  1. K&N
    30 vote(s)
    30.3%
  2. TRD
    57 vote(s)
    57.6%
  3. Other
    12 vote(s)
    12.1%
  1. Aug 1, 2010 at 7:57 PM
    rdcar
    rdcar [OP] Well-Known Member
    07 tacoma
    Which one would you prefer. K&N or TRD air intake
  2. Aug 1, 2010 at 7:59 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    Trd
  3. Aug 1, 2010 at 8:00 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  4. Aug 1, 2010 at 8:00 PM
    adammikolon
    adammikolon Well-Known Member
    Adam
    Doylestown, PA
    03 PreRunner 3.4L V6
    K&N Fuel Injection Performance Kit, JBA cat-back exhaust
    Dunno anything about the trd intake but I put a K&N in my PreRunner around a month ago and I love it
  5. Aug 1, 2010 at 8:06 PM
    rdcar
    07 tacoma
    I know it's much cheaper. which one do you have 63 or 77. I heard that there's no difference.
  6. Aug 1, 2010 at 8:39 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    true dat!!! no probs with those:D
  7. Aug 1, 2010 at 8:42 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    The truck comes from the factory with a "cold air intake"...putting anything else on is just for sound and bling, performance gains will be minimal if at all.
    With that said, I have had a TRD intake on my truck and it sounded great. But if I had it to do all over again, I wouldn't have wasted the $300!!
  8. Aug 1, 2010 at 8:45 PM
    jjw1
    Jesse
    really??? y???
  9. Aug 1, 2010 at 8:50 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    the TRD and Afe stage 2 are the ONLY cold air intakes equivalent or superior to the stock cold air intake... everything else is worse (ie warm air intakes)
  10. Aug 1, 2010 at 8:53 PM
    rdcar
    07 tacoma
    Oh and does either even help the MPG:confused:
  11. Aug 1, 2010 at 8:58 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    On the contrary, there is much more to intake design then cold air vs warm air.
    An intake alone will have marginal gains that part is correct, BUT when paired with an exhaust, or used in a system that requires moving tons of air. An aftermarket intake will be far superior.
    That inlet comes with a cover from the factory. You can have it open or closed. Closed it functions just the same as the TRD, open will allow more air to be available when needed... say at 10lbs of boost at the track. ;)
  12. Aug 1, 2010 at 8:58 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    closed element is best.... k&n gets heat soaked.
  13. Aug 1, 2010 at 9:04 PM
    jjw1
    Jesse
    ive heard k&n is pos cuz they leak n cause problems with ur engine n brain!!! what bout volant???
  14. Aug 1, 2010 at 9:04 PM
    xroller
    X-roller
    1 hp mod
    You my friend are not aware of re-calibration..... The difference it makes is actually quite big if done correctly.... if you are sucking in all that extra air.... it has to get out quick too..... I installed my TRD intake and well it made quite a big difference.... I hate when people say that they don't gain anything off of these because it has been DYNO proven to show results.... If installed correctly....
    The intake is well worth the money in my opinion... all my friends notice the difference it made... especially my buddy in his s2k....... we ran them before and then about 2 weeks later after the install ran em again.... what do you know... I won the second time..... :)
  15. Aug 1, 2010 at 9:07 PM
    jjw1
    Jesse
    not to thread jack but is it possible to buy a trd exhaust n put a aero turbine on it???
  16. Aug 1, 2010 at 9:07 PM
    jjw1
    Jesse
    n have a trd cai on top of that???
  17. Aug 1, 2010 at 9:19 PM
    xroller
    X-roller
    1 hp mod
    recal is letting the ecu relearn everything.... unplugging the battery is a good start but that doesn't give it the recal.... it literally can take up to a month depending on how often you drive the truck for it to learn itself... this is normal driving not racing and all that stuff.... if you don't give it time then it won't learn it's new airflow....
  18. Aug 1, 2010 at 10:16 PM
    bud3ll
    bud3ll Well-Known Member
    vic
    Hawthorne, CA
    05 prerunner
    K&N 63 series intake, Magnaflow exhaust, Debadged, Bilstein 5100's all around set @1.75, Toytec 1.5 rear add a leaf, BHLM, Color matched grill, Stock trd wheels painted black w/ FJ center caps, BFG A/Ts, JVC KD-HDR40 head unit
    I think the trd intake is so overpriced..just went with the k&n 67 series. Absolutely love it.
  19. Aug 1, 2010 at 11:27 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    False. I have had the K&N since I bought the truck. 155,000 miles and no problems with it or the filter.
  20. Aug 1, 2010 at 11:31 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 :thumbsup:
    Or the URD True CAI...but the gains just aren't sufficient enough for me to wanna spend 300+ dollars!
