K02’s, towing and trailing . Love em or hate em?
Discussion in 'Wheels & Tires' started by Davis1891, May 8, 2019.
  1. May 8, 2019 at 3:24 PM
    Davis1891
    Davis1891 [OP] Well-Known Member
    Alberta
    2020 OR DBSB
    None yet
    Im about to pull the trigger on a set of K02’s! I was going to get an e load, but I’ve been advised by some Facebook folks that 10 ply is overkill for what I want/need with lots of regret in getting them.
    I have a hybrid trailer that weighs about 3300lbs that I use every other weekend for boondock camping, a little bit of off-roading ,mostly trails and overland, no rock climbing or anything but I do drive over rockbeds that’s given me trouble on my rubber before, hence why I was going to go with the 10 ply.
    So for you folks out there that have either the c or e load with similar interests..what say you? Are you happy with your purchase? Regrets?
  2. May 8, 2019 at 4:36 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Sounds like C-load is best for you...as you know, E-load will ride way stiffer
    That said, it’s not gonna ruin your truck one way or the other. You’ll just notice it. I’ve got a Pro and can definitely tell the difference. Not sure how it would play with the already-stiff sport suspension. Might make the whole setup too stiff if you’re not gonna get the sidewall strength benefits out of the E-loads
    Whichever way you go, report back so we’ve got the data point haha
    Davis1891[OP] likes this.
  3. May 8, 2019 at 4:45 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    also, E load tires need to be monitored. Had E load KO2's, loved them, took them through hell and back. no major problems but did notice a slightly stiffer ride. I also aired down every time i off roaded, and measured the thread every month or so and messed with the tire pressure to to match the wear pattern. for example, if i noticed the sides were wearing down quicker, i would inflate to around 40-45 lbs. when i noticed the middle was starting to wear down more, i would take air out and run them between 30-35. did this every month and got around 60k out of them. probably could have gone more but i saw the SL Falken AT3W's on sale for 108 each on Amazon and couldn't resist. according to some of the local tire shops, they were amazed that i got 60k out of them since most people get around 35-45k on tacomas. still had around 5/32nds left at the lowest point too. explained how i measured and messed with pressure monthly and it made sense to them. it takes about 10 mins a month but worth it in the end.
    TLDR: Great tire, took it to hell and back many times, just keep an eye on wear pattern and adjust your air pressure to compensate
  4. May 8, 2019 at 4:57 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You don't NEED E rated tires. A set of P rated tires will carry more weight than your Tacoma is rated to carry, by about double. A C rated tire will work, just understand that they are rated to carry LESS weight than the P rated tires that came on your truck. Some tire stores won't mount tires with a lower weight rating than what came on the truck. A D rated tire is rated for the same weight as a P series tire. The biggest difference between C, D, and P rated tires is a tougher sidewall in C and D tires.
    An E rated tire is overkill as far as weight carrying is concerned. But other than cost there is very little downside. I have LT265/75/16's on my Tacoma and the ride is just as good as it was with P series tires. The secret is to find the correct air pressure. Most people running E's on smaller trucks air them up like they're driving a 3/4 ton truck with 2000 lbs in the bed. Do that and the ride will be horrible. But there is no need to do that with a Tacoma.
  5. May 8, 2019 at 6:04 PM
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    I had E load KO2'S on my 16 SR5, I ran low 30 psi and they were very stiff and abrupt. I called them slappy and non compliant!
    Went to St Maxx same size, E load and same psi, they are a big improvement in ride quality. Just my experience, plus the KO2'S were a handful in the rain.
    Paul631 and doublethebass like this.
  6. May 9, 2019 at 2:48 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I was as anti-KO2 as it gets... Made for the Mall..... Then I bought a set for a specific use... Now I love 'em.
    No issues with wet roads. In fact, pretty damn GOOD on wet roads. Quiet. Stable loaded. Picked up almost 2 of the mpg's I lost when I went to STT PROs. Tows trailer well.
    285/75r16 l.r.E.
    There's a reason why KO2s are #1 selling off road tire. And it ain't because they're cheap....
  7. May 9, 2019 at 6:17 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    How many miles you got on them? I went with Coopers because apparently ~30k miles is the threshold where KO2s lose wet grip...
  8. May 9, 2019 at 6:26 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Have 265-75x16" KO2's on the wife's '05.....
    when they're done later this year....I think P rated 16"
    Falkin WP3's are going on.....plenty of tire for her highway use
    Although the KO2's are doing good for mileage..
  9. May 9, 2019 at 6:36 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Current set is just at 1000 miles. Previous set (on my FJ Cruiser) saw 54K and no noticeable "give up" in traction.
    doublethebass[QUOTED] likes this.
  10. May 9, 2019 at 6:54 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    I just went a full 40k miles on a e load 235/85/16 on my Toyota and my wife’s F150 is running a D range tire. The tires are quiet. Like you I have punctured light weight tires, pull heavy trailers with both trucks. The stiff side wall is nice for towing and it makes for a good handling tire on curving paved mountain roads. If they had a C range in that size I would have gone that route . They have full depth sipping so the tires do well on grip.
