Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. May 11, 2021 at 9:07 AM
    Shellshock
    Iowa
  2. May 11, 2021 at 9:40 AM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    How much lift? Are you getting vibes at certain speeds? Are they present when you accelerate and decelerate, or just one of those?
    Slashaar and CygnusX191 like this.
  3. May 11, 2021 at 11:18 AM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    Lifted about 2.5 front and 2.5 in the rear with 3 leaf AALs. Happens during deceleration mostly. As speed picks up I get a small vibration off and on. Wasn't there until I lifted the rear. I do notice a small amount of play where where the slip yoke is at. Not sure if it's suppose to be there.
  4. May 11, 2021 at 11:28 AM
    Juisebocks
    Drew
    "Stock+"
    All of that is normal. You can make it a little bit better by doing a carrier bearing spacer or an angled shim under your leaf pack. Some people are able to get it to go away completely, but it's a lot of work testing different shims and angles.
    It has to do with the fact that a Ujoint doesn't rotate at a constant speed. Since there are a number of them under there, you'd have to get all of them to be at similar angles to completely eliminate it. The stock suspension is designed to keep them all at a very similar angle making each driveshaft section essentially a really long cardan joint.
    Here is the most comprehensive guide for vibes on the site:
    https://www.tacomaworld.com/threads/vibration-diagnostics-for-all-tacomas-write-up.520607/
    TLDR: varying angles and harmonics make things go brrrrr sometimes
    Slashaar, CygnusX191 and Shellshock like this.
  5. May 11, 2021 at 11:48 AM
    M37r1c
    Rob
    Yeah I got a question up on the 2nd gen forum that didn't go far. One post I had on it showed that a guy used a spacer on the diff side that caused the vibes to go away but it's not something everyone says works. Was debating doing the same thing as it makes sense but was checking to see if anyone else had tried that before I pulled the trigger on it.
    Driving a RC I don't have the carrier bearing so can't really do anything there.
  6. May 11, 2021 at 12:00 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like axle shims are your next best bet.
  7. May 11, 2021 at 12:16 PM
    Juisebocks
    Drew
    "Stock+"
    I agree with @CygnusX191 . An angled axle shim might help. It also might only change when you get vibes. It's worth a try though, they aren't super expensive.
  8. May 11, 2021 at 1:11 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yeah, the not very expensive part is the attractive part
  9. May 11, 2021 at 2:07 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Weird thought, but if it's mostly deceleration it could be brakes, or axle wrap.
  10. May 11, 2021 at 3:28 PM
    M37r1c
    Rob
    Only happens once and a while. Usually I dont drive highway speeds but notice it when I do every now and then. I know some Regular cab guys deal with it but never could find a complete answer. Gonna give the Degree shims a try and see what happens from there.
    Juisebocks, CygnusX191 and Slashaar like this.
  11. May 11, 2021 at 3:32 PM
    Slashaar
    Josh
    Kansas City, MO
    Have you done ECGS?
    Military too.
    Sociopenguin[OP] and CygnusX191 like this.
  12. May 11, 2021 at 4:21 PM
    M37r1c
    Rob
    Yup. Ecgs was done when the lift was done.
  13. May 11, 2021 at 5:16 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You are smarter than literally everyone else
  14. May 11, 2021 at 6:14 PM
    Juisebocks
    Drew
    "Stock+"
    My truck only does it when I'm doing the AT version of engine braking/ decelerating without the brakes from 60-55mph. That's why I was asking originally. I don't know if RC trucks do a different thing.
    Do you think one of us could be getting axle wrap from deceleration? I have the factory overload leaf as well as my AAL if that matters :notsure:
    Slashaar[QUOTED] and CygnusX191 like this.
  15. May 11, 2021 at 7:59 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    :anonymous:
  16. May 12, 2021 at 12:53 PM
    Slashaar
    Josh
    Kansas City, MO
    It's possible, if the angles on your axle are funky they likelihood axle wrap on deceleration increases, but I'm no engineer so I couldn't say 100%. If you could mount a go pro under the truck sitting just forward of the carrier bearing you'd be able to get a good shot at both the bearing and the rear axle.
    CygnusX191 likes this.
  17. May 12, 2021 at 1:50 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    hmm that depends tbh my fav i dont share but if i were to say id go down to the ozarks its amazing down there
    what he said
    got any photos?
    CygnusX191[QUOTED] likes this.
  18. May 12, 2021 at 1:51 PM
    Calamity_taco
    Jacob
    haha this is great
  19. May 12, 2021 at 1:55 PM
    Calamity_taco
    Jacob
    dont have it on my truck and ive never had an issue lol
    dont worry i dont have it either lol
  20. May 12, 2021 at 1:57 PM
    Juisebocks
    Drew
    "Stock+"
    I'm relatively certain mine isn't axle wrap, but now I want to know lol
    I'm currently trying to decide on whether or not to try a ball joint replacement or just replace the whole control arm
    CygnusX191 and Slashaar[QUOTED] like this.
