Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. Sep 29, 2021 at 7:14 PM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    Here's the thing. I know all this. In fact, I agree with you that it would be a better solution with the equipment provided.
    But my brain. It knows things and it wants things. I'm historically bad at filtering through the bad ideas before I speak. Sorry :facepalm:
  2. Sep 29, 2021 at 7:23 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I like how long my CVs last. They spin dozens of times per year! Dozens!
  3. Sep 29, 2021 at 7:35 PM
    TacomaDad18
    TacomaDad18 overlanderrr asf
    1uz 2018 SR5
    Hard round things Soft round things Metal bouncy things Shifty thing Locking thing
    I’m glad you found your peace back.
  4. Sep 30, 2021 at 7:21 AM
    0xDEADBEEF
  5. Sep 30, 2021 at 9:15 AM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    You know I feel like this is just my luck with this truck these days… anytime I get close to fixing it or getting something right something else goes wrong this time it was my caliper bolt that decided (even thou it was tight and had lock tight on it) it no longer wanted to be apart of my truck…. That was a scary af instance when I was getting off the highway at 55mph and it jammed the caliper into my wheel and caused the truck to basically hop off the ground…. So now it’s at a shop for an alignment and to see if they can find a bolt for it if not they will align the truck and I’ll get a trailer and tow this heap home
    Slashaar and CygnusX191 like this.
  6. Sep 30, 2021 at 1:12 PM
    Shellshock
    Iowa
    This is what torque specs are for
  7. Sep 30, 2021 at 1:19 PM
    Sociopenguin
    Sociopenguin [OP] 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    In for @Slashaar 's comments about "torqued to 1 Grrr" ....
  8. Sep 30, 2021 at 1:25 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Manufacturer's recommended 6 ugga duggas or 2 grrrs for high use areas. Low use is recommended 1 grrr or 3 ugga duggas.
    You're lucky I provided Standard and Metric torque numbers.
  9. Sep 30, 2021 at 1:36 PM
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
    Excuse me, Grug, but how many Gruggette ugga duggas translate to 1 Grug ugga dugga?
  10. Sep 30, 2021 at 1:45 PM
    Calamity_taco
    Jacob
    it was tight and it had lock tight on it the other bolts didnt move only one did
  11. Sep 30, 2021 at 1:46 PM
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    It depends how many caveman curse words are applied to said Gruggette Ugga...
  12. Sep 30, 2021 at 2:18 PM
    Slashaar
    Josh
    Kansas City, MO
    Ah yes, the magical incantations of tight bolts. You must whisper or yell your preferred magical incantation while applying the Grrrs. These incantations also help when one injures themselves while working.
  13. Sep 30, 2021 at 2:31 PM
    Shellshock
    Iowa
    Maybe you are weak?
  14. Sep 30, 2021 at 2:37 PM
    Calamity_taco
    Jacob
    gee thanks.....
    Sear87, CygnusX191 and Slashaar like this.
  15. Sep 30, 2021 at 2:43 PM
    Slashaar
    Josh
    Kansas City, MO
  16. Sep 30, 2021 at 3:29 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I thought the number of ugga duggas were standard across all genders...moreso dependent on said ugga dugga generator. Maybe I was wrong?? Grrrs, however, are as sexist as they come.
    Slashaar, CygnusX191 and gasparic104 like this.
  17. Sep 30, 2021 at 4:07 PM
    Slashaar
    Josh
    Kansas City, MO
    It's true.
    CygnusX191 likes this.
  18. Sep 30, 2021 at 4:09 PM
    0xDEADBEEF
    I knew this was a high end area but damn
    CygnusX191, Slashaar and Sear87 like this.
  19. Sep 30, 2021 at 4:19 PM
    Slashaar
    Josh
    Kansas City, MO
    Man, if that's the case, mine must be in the realm of 10 digits.
    CygnusX191 and Sear87 like this.
  20. Sep 30, 2021 at 5:39 PM
    Juisebocks
    Drew
    "Stock+"
    "3.5 ugga duggas"
