Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. May 10, 2022 at 6:29 PM
    Sociopenguin
    Sociopenguin [OP] 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    If necessary. Had the 300 pistol last night with
    Tac-light....
  2. May 10, 2022 at 6:32 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    :quickdraw: Pew pew. Will make them yotes less comfortable around your property.
    Sasquatch3153 and CygnusX191 like this.
  3. May 10, 2022 at 6:36 PM
    T1TITAN
    T1TITAN Well-Known Member
    Kansas City
    2008 ACLB aka Treehugger and 2005 ACLB Treehugger 2
    Treehugger- soon to have 80 series axles front and rear with dual rf1a tcases Treehugger 2- Bilstein 6112/5125 jba ST High Caster UCA OME Dakar Heavy leaf packs with Fireastone RideRite bags
    I'll bring out my rifle with the ecotrigger and stack 8's on the cheeky bass turds
  4. May 10, 2022 at 6:50 PM
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    As much I hear them every night, I'm surprised I've only seen one coyote remotely near my house in almost eight years
  5. May 10, 2022 at 8:30 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    thats rare to see one just get comfy they are very skittish so they usually run away
  6. May 11, 2022 at 5:18 AM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    Man i can't go on a vacation without something wrong happening. Was towing the trailer on the way to Montauk state park for some trout fishing and R&R the truck got a random misfire between Hamilton & Chillicothe. The good thing is I had a buddy following me in his expedition so he ended up towing my camper when i was on the side of the road but I had to hobble to a O'Riely's. Guy there said the code that came up was a misfire on cylinder 1. Changed the Coil pack and spark plug for cylinder 1 but no dice. Had to leave the truck there at a family members place. Still was able to get our forester to Chillicothe and from there went to Montauk but gotta pick up the truck and see what happened. Hoping it isn't too big a deal. Any ideas?
    Slashaar and CygnusX191 like this.
  7. May 11, 2022 at 5:20 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    More than welcome. I'm very slightly familiar with the wiring of the inverter as well...should be free this weekend if ya wanna come by.
  8. May 11, 2022 at 5:56 AM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    Dude, you have my luck when I'm not having it.
    Are you 4 cyl? 2TR-FE?
    Did you check the plugs for spark?
  9. May 11, 2022 at 6:10 AM
    airforceb2cc
    Don
    KCMO
    Check for spark.
    If spark looks good, make sure the injector harness is plugged in completely.
    While at oreillys, borrow a compression tester and see what your compression is on #1.
    Check your oil and see if it is milky.
    Check coolant levels.
    Suck, squeeze, bang, blow. As long as you have these components, you should be firing all cylinders.
    Slashaar, CygnusX191 and Juisebocks like this.
  10. May 11, 2022 at 6:11 AM
    M37r1c
    Rob
    Didn't really check. Yea running the 2TR-FE. When you got a family of 5 waiting in a vehicle with kids you try to work fast and I just threw parts at the local O'Reilys thinking it would perk back up quick and go. Honestly I don't have a lot of confidence in their Import direct stuff either but its all they had at the time. Its something to check for sure.
  11. May 11, 2022 at 6:12 AM
    Juisebocks
    Drew
    "Stock+"
    @M37r1c This what what I was going to recommend next, but I would have worded it way worse
  12. May 11, 2022 at 6:15 AM
    M37r1c
    Rob
    Pretty much what I'll try when I can pick it up. As always, hoping it isn't something worse. Still moves but just clanks around like an old diesel engine.
  13. May 11, 2022 at 9:03 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Import direct is so hit or miss with their quality.
    Slashaar likes this.
  14. May 11, 2022 at 12:20 PM
    Calamity_taco
    Jacob
    I use to work at oriellys years ago and I couldn’t agree more about this! I saw import direct come back a lot
    Slashaar and CygnusX191[QUOTED] like this.
  15. May 11, 2022 at 1:27 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    My experience with them is that all of their little things, relays, switches etc are complete junk. But their higher end stuff, like CV axles and whatnot are pretty decent.
  16. May 11, 2022 at 3:46 PM
    Slashaar
    Josh
    Kansas City, MO
    Could be head gasket has a small break in it. That's what happened to my 99 grand am, I was getting misfires until the gasket fully gave.
    CygnusX191 likes this.
  17. May 11, 2022 at 4:19 PM
    Juisebocks
    Drew
    "Stock+"
    That should show up under a compression test, the coolant is low, or the oil milky
    Mmmmm... milky oil...
  18. May 11, 2022 at 6:24 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    :drool:
  19. May 11, 2022 at 7:44 PM
    T1TITAN
    Kansas City
    You free sunday? Saturdays are usually reserved for the Mrs. I'm sure if Jessy was going to be around she'd be ok with it.
    I was about to say I've never been able to totally kill one of their CV's, but electrical components and bearings i usually stick with bigger names like Bosch, Denso or Dorman
    CygnusX191[QUOTED] likes this.
  20. May 11, 2022 at 7:51 PM
    Calamity_taco
    Jacob
    They are okay I saw them come back a lot when I worked there
