Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. May 30, 2022 at 3:45 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R, 2022 tracer 9 gt
    just a couple of things tbh
    I can’t say for sure it is but hopefully that’s all it is! That’s way cheaper then an engine so it’s something to look into
  2. May 30, 2022 at 3:47 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    There are ways to check the head gasket by testing the antifreeze and oil as well
    CygnusX191 likes this.
  3. May 30, 2022 at 3:48 PM
    Calamity_taco
    Jacob
    That’s true as well
  4. May 30, 2022 at 4:39 PM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    That may be another test. From what I was told though this guy was saying in order to pull the heads the engine would have to come out. Is that true? I can't imagine it being that way but I'm not sure.
  5. May 30, 2022 at 4:41 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    That makes no sense. Only vehicle I know of where you need to pull the engine in order to pull the head is a subaru
  6. May 30, 2022 at 4:44 PM
    M37r1c
    Rob
    One of the other things was when he had his camera in the motor he couldn't find anything that looked stuck or bad really. They spent some time looking for something to say was wrong. Mechanic was saying possible stuck valve but I wouldn't really know.
  7. May 30, 2022 at 4:46 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Sounds like it might just be a bad headgasket if they can't find anything wrong in the engine
    Juisebocks and CygnusX191 like this.
  8. May 30, 2022 at 4:50 PM
    M37r1c
    Rob
    It's what I was thinking once they said that they couldn't find anything that looked like the inside is damaged. Truck still runs. It just ticks and obviously can't make pressure in cylinder 1. I was having oil consumption issues as well but not very severe.
  9. May 30, 2022 at 4:53 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    The oil consumption seems to be a common issue in the 2.7s also. Don't know if there's a fix for it. But if it does get worse you'll definitely have to look into either a new engine or get the current one rebuilt
  10. May 30, 2022 at 5:02 PM
    M37r1c
    Rob
    Was never really bad. Just made sure it was always topped off. Maybe needed a quart after 3k or so.
  11. May 30, 2022 at 7:32 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Bunch of Volkswagens and BMWs are like that
    Sociopenguin[OP] likes this.
  12. May 30, 2022 at 7:38 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Ew
    CygnusX191[QUOTED] likes this.
  13. May 30, 2022 at 7:39 PM
    Sociopenguin
    Sociopenguin [OP] 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Most exotics probably require a motor pull for almost anything if you think about it.
  14. May 30, 2022 at 8:08 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Exactly.
    Except for high end Mercedes trucks, pretty sure they're designed to stay in.
    Old school Range Rovers and Land Rover Defenders too, since those aluminium V8s were GM designed
  15. May 31, 2022 at 5:35 AM
    M37r1c
    Rob
    I may end up going to another guy for another opinion. There is someone in St. Joe that helped a friend with his Tacoma when his motor blew. I'd like to find someone that can give a good answer in whats needed to fix it but its gonna be pain in the butt if I gotta load it up on a trailer, take it somewhere, then all I get is "I think...".
  16. May 31, 2022 at 5:47 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's too bad you're not on the east side of the state. We got a whole crew of guys that haul crap around for each other.
  17. May 31, 2022 at 1:24 PM
    Calamity_taco
    Jacob
    what? that dont sound right at all! i know my buddy told me its a long job to do a head gasket but he didnt mention removing the motor!
    CygnusX191 and M37r1c[QUOTED] like this.
  18. May 31, 2022 at 1:42 PM
    M37r1c
    Rob
    That's what I was thinking. I've had head gaskets done on other vehicles before and never had to have the motor removed. Getting ready to take this truck to another shop and see what they say. A buddy says the mechanic likes to work on Toyotas so I'm curious to see what he says.
    Started the truck up today and noticing also white smoke come out every now and then when it's reving down.
  19. May 31, 2022 at 1:46 PM
    Calamity_taco
    Jacob
    ya id go to another shop man! that place either doesnt know or is trying to make it seem worse!
  20. May 31, 2022 at 1:55 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If you're blowing smoke don't keep starting and running the truck. Unless you absolutely have to
    Slashaar likes this.
