Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. Aug 22, 2022 at 10:43 AM
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    Crypto real estate. Genius!
    Slashaar and CygnusX191 like this.
  2. Aug 22, 2022 at 1:37 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    ahh that makes sense then because one time a week or so back i saw you follow me in and then after that it was always you leaving and me going into work haha
  3. Aug 22, 2022 at 1:40 PM
    Calamity_taco
    Jacob
    there do be a few of us in here haha
    has it really gotten that bad? i havent looked at rent cost in a few years now
  4. Aug 22, 2022 at 2:14 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yeah the ex won't go for that.
    No different than here.....
    :rofl:
    Slashaar[QUOTED] likes this.
  5. Aug 22, 2022 at 4:32 PM
    memypupandmytruck
    memypupandmytruck Well-Known Member
    Mark
    Lees Summit, MO
    About 3 weeks ago I finally bought another Tacoma. I brought it to Toyota for some recalls (one being new leaf packs however they said they were backordered) and figured I'd have them do an inspection while it was there. They failed me for the inner tie rod boot and then told me that I need a whole new rack and pinion and it would be a $1900 fix. I thought my steering was fine and haven't heard any noises or noticed any drips in my driveway so I ordered the boot/bellows and today I attempted to fix it. I have a ton of play on the inner ball joint so figure it won't hurt to replace both inner and outer tie rods on both sides (truck has 240k) however how exactly would I know if I have a seal leaking? Also, is there anything else I should replace while I have it apart (other than installing my 6112s and UCAs)? Thank you in advance.
  6. Aug 22, 2022 at 4:35 PM
    Calamity_taco
    Jacob
    i mean if your rack is leaking you are going to see fluid somewhere if not then keep an eye on the reservoir for it. if it keeps loosing fluid then its leaking somewhere
  7. Aug 22, 2022 at 4:52 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Frankly at a quarter million on a second gen if your rack wasn't loose and leaking I'd be concerned.
    Unfortunately part of that cost is the obnoxious labor of fishing all the rack parts out because it is shoehorned in there.
    T1TITAN, Slashaar and Calamity_taco like this.
  8. Aug 22, 2022 at 4:53 PM
    Calamity_taco
    Jacob
    id imagine someone would have changed it by now thou right? pretty wild to think one would last that long unless it was only driven on the road maybe?
    Slashaar and CygnusX191[QUOTED] like this.
  9. Aug 22, 2022 at 4:54 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Most people don't jump their trucks. But it's pretty common to see second gen's come into the dealership at around 220,000 or so and start having loose steering and leaking rack and pinion. I seen them as high as 265,000 before they've started having issues. I'm sure there are some out there that clear 300,000 without having issues but for the most part dealership logs them right around that 220 mark.
    T1TITAN, Slashaar and Sear87 like this.
  10. Aug 22, 2022 at 4:56 PM
    Calamity_taco
    Jacob
    hey now:anonymous: my rack works just fine thank you! now my tie rods were a different story thou lol
  11. Aug 22, 2022 at 6:09 PM
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
    Same exact situation with my 03 Corolla. Went in for inspection, had to replace the rack and pinion because there was virtually no power steering fluid left at around 250k. They thought I was nuts for saying I hadn't seen any fluid, because they said it was leaking on the ground at the shop, lol. Nothing was whining and steering was totally fine. Seriously had no clue there was an issue. Bid for it sounds about right though.
    You can add UV dye to the power steering reservoir. Drive it for a bit and crawl under with a UV light.
  12. Aug 22, 2022 at 6:39 PM
    memypupandmytruck
    Mark
    Lees Summit, MO
    My reservoir is dirty though it isn't low (I'll be doing all fluids when the weather is a little more manageable). I think the truck drives perfectly fine. They called to tell me about the $1900 fix however all it mentioned on the rejection was a torn boot so I was just gonna replace that until I actually felt an issue. They also did a courtesy inspection in which they said my air filter and cabin air filter needed to be changed even though my glove box was still off and the box for the new cabin air filter, which was already installed, was on the floor. The engine filter was clean as can be as well as I checked it when I got it and then when I cleaned the engine bay and pulled off the hardware.
  13. Aug 22, 2022 at 6:48 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I'm not in KC, but Springfield. Does anyone know a good place in SW MO to get regeared by chance?
  14. Aug 22, 2022 at 8:14 PM
    Shellshock
    Iowa
    wherever @Sociopenguin had his done is probably a good option
  15. Aug 22, 2022 at 8:34 PM
    Calamity_taco
    Jacob
    wouldnt that be far from Springfield thou?
    Slashaar likes this.
  16. Aug 22, 2022 at 8:39 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Adventure Motors.
    :rofl: I'm kidding. They're only good for selling rusty crusty lawsuit liabilities. Avoid them at all costs.
  17. Aug 22, 2022 at 8:44 PM
    Calamity_taco
    Jacob
    wish they would buy my truck lol
  18. Aug 22, 2022 at 8:46 PM
    Shellshock
    Iowa
    They would if you were an influencer
  19. Aug 22, 2022 at 8:46 PM
    Calamity_taco
    Jacob
    dang! well that and they hate me for calling them out on shit years back lmao
  20. Aug 22, 2022 at 8:47 PM
    Shellshock
    Iowa
    I guess the other option is Jim bobs gears and more but no guarantees on the installation
