Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. Sep 8, 2020 at 4:53 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    ah i gotcha man
    Slashaar likes this.
  2. Sep 8, 2020 at 4:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The reason I added it is because I loosened my drain plug playing in the rocks. Partway through a day of wheeling I noticed the axle was wet and sure enough, it was gear oil. It was a non issue since I carry extra fluids, but I lost almost a quart of oil. I got lucky that I noticed it and don't want to risk that again.
  3. Sep 8, 2020 at 5:01 PM
    Calamity_taco
    Jacob
    ya makes sense man no reason to risk it again if its a simple fix
  4. Sep 8, 2020 at 7:08 PM
    Dex__43
    Dex__43 Well-Known Member
    Sam
    KCMO
    09 DCSB TRD OR 4x4 Swap
    4x4 Conversion 2.5 inch lifts with 33's Sliders Skids Front Runner racks Satoshi grill Patches and Stickers BAMF hybrid front HC tube rear Light bar 2 Hella's behind the grill Pioneer media player and subs Sleeping platform with lower storage for the bed
    Lucky! I have been trying to find a used diaper. Think I'm gonna have to break down and buy new.
    Slashaar[QUOTED] likes this.
  5. Sep 8, 2020 at 7:09 PM
    Dex__43
    Sam
    KCMO
    Do you weld?
  6. Sep 8, 2020 at 7:16 PM
    Dex__43
    Sam
    KCMO
    I'm planning to drive the beater Honda Accord in the winter months. 4 banger 5 speed with low compression in one cylinder, but at least she has a stick shift and VTEC so she still goes.
  7. Sep 8, 2020 at 7:20 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sometimes I read a thread from the end backwards and really get confused. :laughing:
  8. Sep 8, 2020 at 7:21 PM
    Dex__43
    Sam
    KCMO
    :rofl::rofl: What can I say I'm cheap and I'm gettin old! Lol im talking about a rear diff skid if anyone else was confused
  9. Sep 8, 2020 at 7:28 PM
    Dex__43
    Sam
    KCMO
    What about the drain and fill plugs that are smooth with an allen hex in the middle? I'm thinkin about switching to those.
    Calamity_taco[QUOTED] likes this.
  10. Sep 8, 2020 at 7:33 PM
    0xDEADBEEF
    This weather needs to be more decisive. All this toying around with gray sky and wind has got to go.
  11. Sep 8, 2020 at 8:05 PM
    Shellshock
    Iowa
    based on my current experience with Allen drain plugs, not a chance. The front diff fill plug is enough of a pain in the ass already..
    CygnusX191 and Slashaar like this.
  12. Sep 8, 2020 at 8:27 PM
    Dex__43
    Sam
    KCMO
    Very true, wow never mind, thank you
  13. Sep 8, 2020 at 9:26 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    SMKYTXN likes this.
  14. Sep 8, 2020 at 9:27 PM
    0xDEADBEEF
    I wonder if once could weld the drain plug shut and then just pump it out the fill hole. Or, add a drain on the back cover.
  15. Sep 8, 2020 at 9:30 PM
    Slashaar
    Josh
    Kansas City, MO
    Just shave your diff. :anonymous:
  16. Sep 8, 2020 at 9:51 PM
    Dex__43
    Sam
    KCMO
    I was thinking smaller more flush to the diff so rocks wont touch. I'm kinda thinking about welding a piece on the skid like @EatSleepTacos welded on his diff. You do change your diff fluid right eatsleep?
  17. Sep 9, 2020 at 3:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ve seen that done as well. Weld the hole shut, and then replace one or two diff mounting studs with Allen key bolts. The draining is just a slow process I imagine.
    Yes I change the fluid lol it’s just a few tack welds, so it’ll just get cut off.
  18. Sep 9, 2020 at 5:21 AM
    Sociopenguin
    Sociopenguin [OP] 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    I'm the same with DP, only out if it has to be....
  19. Sep 9, 2020 at 5:26 AM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Nope!
    But I want to. :welder:
  20. Sep 9, 2020 at 5:50 AM
    JBone25
    JBone25 Well-Known Member
    Doing a cross country trip to Moab / Canyonlands / Needles / Dead Horse National Park. My tacoma is only stock lift, but slightly aggressive tires. Per the reviews / travel books it calls for "high-clearance" 4x4 to traverse for most of the driving trails. I understand usually High Clearance is 3+ inches. Does anyone have experience with driving stock lift around that area on any trails as some would state that is the preferred method.
    Slashaar and jeff b like this.
