Kansas City Tacoma Crew - 816/913
Discussion in 'Mid West' started by Sociopenguin, Nov 5, 2017.
  1. Jan 22, 2021 at 8:29 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
  2. Jan 22, 2021 at 8:30 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    you know mom has said that before but who is ed?
    Slashaar likes this.
  3. Jan 22, 2021 at 9:00 PM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
  4. Jan 22, 2021 at 9:09 PM
    Juisebocks
    Drew
    "Stock+"
  5. Jan 22, 2021 at 10:16 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    He did say "09 + "
    Slashaar and Juisebocks[QUOTED] like this.
  6. Jan 23, 2021 at 3:21 AM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Up to the 15 models. I don't know what else you would need for it besides wiring. I think it is. I haven't read that far into it. I just know that 09+ off road models with Atrac and VSC (don't know what that is) are the only years with that kind of master
    Slashaar and CygnusX191 like this.
  7. Jan 23, 2021 at 11:17 AM
    Juisebocks
    Drew
    "Stock+"
    So I dove down that rabbit hole last night and I found out nothing useful, but some interesting things came to light.
    It's not practically feasible to do the electro-hydro ABS swap in my case. Even among my generation of Tacos, my specific setup, the famously lame 4cy AT 4wd, seems to be nearly identical across trim levels. For example, I have an SR5 version of that build and there is no SR5 designation in the parts catalog for my year. That just means that all 4cyl AT 4wds are mechanically equal and a lot of stuff does trade over to the sport and Pro. That's good to know. But almost nothing of the individual processing units or the brake booster are shared with the OR.:deadhorse:
    However, I DO think it's possible to use an external microcontroller and the wheel speed sensor signal in coordination with the ABS actuator solenoids to create a muuuuuuch more awesomer ABS traction control. The biggest hurdle in a standalone system like that for my application is that the main ABS unit would need upgrades to allow longer run times than 4 seconds. Not an insurmountable issue, but the ABS actuator/controller unit has it's own processor that communicates with the greater CAN system. When it starts to read a certain amount of suspect signals coming from the wheel speed sensors and the solenoid, it will throw codes and lights start turning on.
    So again, I'm kind of stuck just learning what each system expects and doing the bare minimum to spoof the signals...? maybe lol:notsure:
  8. Jan 23, 2021 at 12:49 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Jesus you really did dive in the rabbit hole :anonymous:
    Slashaar, CygnusX191 and Sear87 like this.
  9. Jan 23, 2021 at 2:46 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    And that's why we love him :thumbsup:
  10. Jan 23, 2021 at 8:01 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Damn right
  11. Jan 24, 2021 at 8:11 AM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Championship Sunday! Let's go, Kansas City!
    Slashaar, Juisebocks and M37r1c like this.
  12. Jan 24, 2021 at 8:59 AM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    Hoping for KC vs GB Superbowl!
  13. Jan 24, 2021 at 9:40 AM
    ResearchMonkee
    Derrick
    KCMO
    So I swapped out my tails for roommates, right. His flash faster than my originals did. They were also spliced to use pod lights as reverse lights. Would that splicing be causing the fast flash? The splices are still on but the wire for pod lights is cut.
    I don't believe it's a bulb problem, but I can always change those out if need.
  14. Jan 24, 2021 at 12:38 PM
    Juisebocks
    Drew
    "Stock+"
    It's possible if they are LED lights. Sometimes the LEDs use voltage levels to change the rate of how a timing capacitor works. I don't know how the empty splice would change that without maybe causing a short though. Do they flash at a different rate than the front or the dash light?
  15. Jan 24, 2021 at 12:47 PM
    Shellshock
    Iowa
    Sounds like there is LEDs installed that’ll hyper flash. You can either swap them or add a module for like $10
  16. Jan 24, 2021 at 1:14 PM
    ResearchMonkee
    Derrick
    KCMO
    Right on, I will get some bulbs later. The hyper flashing is a bit annoying.
    Everything hyper flashes since the new lights.
  17. Jan 24, 2021 at 2:50 PM
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
    Same. We'll see if GB can pull through last minute. Fingers crossed.
  18. Jan 24, 2021 at 3:19 PM
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    My tacoma is officially part tundra...
  19. Jan 24, 2021 at 3:22 PM
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Did a 26 minute oil change today. New personal record
  20. Jan 24, 2021 at 7:00 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    o_O
    Slashaar and Sociopenguin[OP] like this.
