Karr alarm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by homelicup, Apr 25, 2015.
  1. Apr 25, 2015 at 8:06 PM
    homelicup
    homelicup [OP] Well-Known Member
    homer
    Poway CA
    2015 PreRunner TrD SpOrT Entune Premium
    OEM runing board
    Hi guys just got a question about that karr alarm that i have on my taco.. Anyway i purchased it when i bought that truck anyway when i was digging under the dash there is a adjustable device that i know its part of the karr alarm that i purchase so the question is .,is that a shock sensor? That make it sensitivity for vibration?
  2. Apr 25, 2015 at 8:39 PM
    homelicup
    homer
    Poway CA
    OEM runing board
    I tried to adjust it and nothing ..lock and armed it and kick the tire, shake the car nothing
  3. Apr 25, 2015 at 8:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    its the mic for the "shock sensor"
    Lock the truck, wait 30 seconds for the system to fully arm.
    snap a door handle trying to open it, it should give you some warning beeps.
    Also DOES ANYEONE HAVE THE WIRING DIAGRAM FOR THE KARR ALARM!??!
  4. Apr 26, 2015 at 5:08 AM
    homelicup
    homer
    Poway CA
    OEM runing board
    Cool ill try that..but what i did awhile ago is i went in inside the cab and arm the alarm and switch the ignition and it fires up meaning it doesnt work imma try again if not imma go back to dealer again which waste of time
  5. Apr 29, 2015 at 5:08 AM
    homelicup
    homer
    Poway CA
    OEM runing board
    Ok got em fix , well when i went to stealership , i complain that my alarm wasnt working and they check and told me they were not installed " the chip" so i drop off the truck and go home , picked up after 5 hrs and all work now but sensitivity is max but not that sensitive for vibration i guess the position of the shock sensor is well secure...
