Kavik's She-Devil Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Kavik, Mar 5, 2012.
  1. Aug 25, 2013 at 8:35 PM
    #181
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    If anyone needs any help on how to remove the covers and how to re-install them, I will gladly answer any questions.
  2. Aug 25, 2013 at 8:38 PM
    #182
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    They do look great... nice job! I like it that you went with an OEM look instead of boy-racer seats ;)
    Did your old seats have air bags? I'd love bucket seats, but getting donor seats with air bags is way too much $$$
  3. Aug 25, 2013 at 8:43 PM
    #183
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    So were those originally airbag seats or were they closer to your year?
    What differences were there in the electrical connectors?
  4. Aug 25, 2013 at 8:47 PM
    #184
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Looks good! I figured sport seats not bolted to a truck were unicorns. Now you got me thinking of another way to not save any money for my kids' college fund.
  5. Aug 25, 2013 at 8:48 PM
    #185
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    2005 trucks didn't have side airbags in the bench seat, only the front two airbags. So luckily I didn't have to deal with that. :D
  6. Aug 25, 2013 at 8:51 PM
    #186
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    One was from a 2007 access cab and the other was from a 2008 I think??
    The electrical connectors were completely different from the bench setup, I could not find one thing that was plug and play, not even the buckle sensors.
  7. Aug 25, 2013 at 8:54 PM
    #187
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    All the mounting holes are there under your carpet, just find some tacoma sport bucket seats, cut some holes in the carpet and bam, you know have mounted bucket seats.
  8. Aug 25, 2013 at 8:54 PM
    #188
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Swap it all over from your bench. That's what I did with my SX seats.
  9. Aug 25, 2013 at 8:55 PM
    #189
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I did, that was the easiest and cheapest thing to do.
  10. Aug 25, 2013 at 8:56 PM
    #190
    Rich91710
    Rich
    Los Angeles
    08 Base
    Okay... that's what I needed to know.
    Seatbelt sensors don't bother me that much. I'd just use the original belts on the floor mounts. Someone said that the buckles themselves weren't compatible, but I have a feeling that was actually due to the difference in the year (he used 2007 seats in a 2011).
    I bought some seatbelt extenders so my wife didn't have to dig to find the buckle, and the first set that I bought were for a 2012 and they didn't fit. They plugged into the buckles with a little effort, but the channel was too narrow for the belt to fit.
    Bought the kind with a wider slot/buckle and it works fine.
  11. Aug 25, 2013 at 8:58 PM
    #191
    Rich91710
    Rich
    Los Angeles
    08 Base
    Trying to avoid that. Working in a condo parking lot. I have a small back yard, but I can't have the truck immobile for an extended period of time, and the closest I can park to my back gate is a good 500ft.
    I was hoping I could rip the bench out, install the buckets, then drive the bench over to the gate.
  12. Aug 25, 2013 at 8:59 PM
    #192
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I just used my bench seat buckles and they work perfectly with the buckets, they just aren't as cosmetically appealing.
  13. Aug 26, 2013 at 1:11 AM
    #193
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Love the seats. How much space did u lose? Can't put nothing underneath those huh. Still looks sweet, I'd throw a fat sub in the center!! And make a custome console, maybe with the sub built in. Damn so much you can do with the righ trunks he he. Oh and some seat covers he he
  14. Aug 26, 2013 at 5:02 AM
    #194
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I can't put my amp under my seat anymore plus I have to redesign my sub box to fit or do what you said and put them down the middle but that has STEAL ME all over it if I do that.
  15. Aug 26, 2013 at 5:05 AM
    #195
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    If you have your buckets good to go, you can have the buckets installed within an hour. If you have good help, it would go even faster. Actually you could do it all in a parking lot if you had too.
  16. Aug 26, 2013 at 2:07 PM
    #196
    jmarquez808
    Jess
    Hawaii
    ha ha true that forgot about damn thieves. it would look sick tho! i have to build me some custom boxes for my truck. i have two tens in separate boxes wedged in behind my seat and they make all these creaking noises when i turn since they rub the back. very annoying! lol
  17. Aug 26, 2013 at 3:50 PM
    #197
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    That is how mine was! These buckets will finally get me off my ass and redo my system and make it look flush.
  18. Aug 26, 2013 at 6:08 PM
    #198
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Check my build thread about amps and enclosure location. I mounted everything on the back of the inside cab.
  19. Aug 26, 2013 at 9:30 PM
    #199
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Will do.
    On another note.
    I am getting a weird rough idle when I am stopped at a red light, anybody have any reason why this might be happening?
  20. Aug 27, 2013 at 4:23 AM
    #200
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Putting on some Wagner Therma Quiet brakes this morning to see if that might stop the drums from squeaking as bad.
