Kazoo Wind Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redrckgal, Dec 27, 2013.
  1. Dec 27, 2013 at 6:07 PM
    redrckgal
    redrckgal [OP] New Member
    New Mexico
    13 4WD
    I have seen a few posts about this issue...In a crosswind or interstate driving I get a horrible kazoo like noise in the cab...anyone willing to share their fixes with me?? I would love to hear if the dealership fixed it and if so, how. Mine is a 2013 double cab. Thanks!!
  2. Dec 27, 2013 at 7:39 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    Some one had a fix for that. Hopefully they will show up
  3. Dec 27, 2013 at 8:35 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    There is a TSB about the windshield needing proper resealing. Fix is find the air leak add sealant retest
  4. Dec 27, 2013 at 8:52 PM
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    There's 2 TSB's out for the issue. One being the front grille. And one being the windshield itself.
    I had the grille one done, which didn't fix it on my 2012. Then they tried to reseal from the outside of the windshield and caused a disaster leak. Finally they completelty removed the window and re installed it.
    It went from being a constant whistling noise at highway speeds, to once or twice in a year. So I consider it fixed now. Unless I can narrow it down to a set of circumstances no point going back to a dealer. They'll just cause more problems then they solve.
  5. Dec 27, 2013 at 8:58 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If it goes away when you push hard on the windshield (next to the rear view mirror) it's the windshield seal.
  6. Dec 28, 2013 at 11:02 AM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I have a 12 and was able to eliminate whistle by placing 1/4 inch drip tube in front seal. Try a search here for something like 2012 whistling sound identified or fixed, there was a good write up with pics by member Applejax or something close to that, should be ez to find as it was discussed a lot last year. Mine was obviously not from windshield or this would not have worked.
  7. Dec 28, 2013 at 12:49 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That's what I did too. I read about it here and never had it happen, except one time.
    Last season, while the truck was in the hot sun, I had it on the highway and the windshield began to buzz... just like a kazoo. I pushed on the windshield and it went away. I released the pressure and the sound continued.
    I haven't had it make that sound since, but I don't consider it fixed though.
