KB Voodoo Bed Rack
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KB Voodoo, Feb 4, 2016.
  1. May 7, 2017 at 8:47 PM
    #481
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    Are the new ones still a matte coarse finish and the holes are cut awkwardly? Debating on what rack to replace this old one with. Like the first series you made, old.
  2. May 8, 2017 at 3:59 AM
    #482
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Everything we do now is laser cut.
  3. May 8, 2017 at 11:20 AM
    #483
    AZ_Overlanding_Paul
    AZ_Overlanding_Paul Active Member
    Paul
    West Michigan
    2014 blue tacoma TRD OFF ROAD
    Kbvoodoo rack, icon stage 3 lift, Nitro 5.88s gears, SCS RAY 10s.
  4. May 8, 2017 at 11:22 AM
    #484
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I think the offset version will suffice for both tall and mid height racks.
    We don't have any immediate plans to do anything with Softopper.
  5. May 8, 2017 at 11:25 AM
    #485
    AZ_Overlanding_Paul
    Paul
    West Michigan
    How would you like to proceed with testing/buying?
  6. May 8, 2017 at 11:28 AM
    #486
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We will post them on our website when they're available. It'll be a few weeks.
  7. May 8, 2017 at 11:41 AM
    #487
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I wasn't able to open his part file, so I designed these myself.
  8. May 8, 2017 at 1:18 PM
    #488
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I wasn't able to open it, so I made my own.
  9. May 8, 2017 at 5:49 PM
    #489
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    I also would want them to sit flush, or as flush as possible. What about making them flush but with spacers if you want them offset?
  10. May 8, 2017 at 6:33 PM
    #490
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    See build thread
    Whats the timeline like for the next racks with the new stuff?
  11. May 8, 2017 at 6:45 PM
    #491
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Couple weeks or so.
    the_dau likes this.
  12. May 12, 2017 at 8:51 PM
    #492
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    hopefully I get my grant check soon!
  13. May 17, 2017 at 12:24 AM
    #493
    turbosmitty
    turbosmitty Well-Known Member
    Vegas
    2017 Tacoma TRD OR
    Ended up re-mounting my tred pros this weekend. Found that using the center holes in the boards it didn't turn out as sturdy as I hoped for. Moving the brackets in a vertical position with a metal backing plate ended up being a more solid configuration. I had to drill a few extra holes in order for this to work. I'm hoping the RTT will fit as long as it opens towards the passenger side. Will post another pic at the end of the month with the results.
    FullSizeRender 27.jpg IMG_2401.jpg FullSizeRender 28.jpg IMG_2402.jpg FullSizeRender 29.jpg
    mcharfauros and LamzTaco like this.
  14. May 17, 2017 at 1:21 AM
    #494
    turbosmitty
    Vegas
    2017 Tacoma TRD OR
    Anyone using a rear swing out bumper with the midlevel rack? I'm wondering if the Mt Rainier tent (extends about 8-10 past the bed) will clear the rear tire.
  15. May 18, 2017 at 5:40 PM
    #495
    DHSteeze
    DHSteeze Member
    Justin
    2017 Inferno DCSB Off Road
    Just want to confirm - the 10" above the bed side rail caps listed on your website for the mid-height rack, is that measured to the bottom edge of the top rack bars when installed? Looking at your rack to hold an RTT, and trying to gauge whether my mountain bike rear wheels will fit under the rack/RTT when hanging over the tailgate!
    Also, what's the lead time on a mid-height short bed rack, or do you have any in stock?
  16. May 18, 2017 at 5:53 PM
    #496
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    10" from the top of the rack to the top of your side rail caps.
    Yep, mid height short bed in stock.
  17. May 18, 2017 at 6:14 PM
    #497
    DHSteeze
    DHSteeze Member
    Justin
    Ah ok, thanks for the quick reply!
    The top bars look to be around 2ish" in height, so I'm guessing I'd have roughly 8" from the top of the bed rails to the bottom edge of the top bars? If that's the case, then I should have about 27" of clearance from the bottom of the bed to the bottom edge of the top rails.
    I may be cutting it close with that height, but I'll take some height measurements this weekend to know what my minimum needs to be.
    Thanks again for the quick info! :thumbsup:
    KB Voodoo[OP] likes this.
  18. May 18, 2017 at 6:16 PM
    #498
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You'll have about 8.5" of clearance under the top bars.
    DHSteeze[QUOTED] likes this.
  19. May 20, 2017 at 6:24 PM
    #499
    Jamma
    Jamma Well-Known Member
    2017 MGM TRD Off Road
    Any updates on the mid rack height extenders??
  20. May 20, 2017 at 6:35 PM
    #500
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Just installed the prototypes today. They're sweet!!
    Wallbright likes this.
