KB Voodoo Crossbars for Tonneau Covers - IN STOCK!! (redesigned for RTT's!!)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KB Voodoo, Oct 28, 2016.
  1. Feb 11, 2018 at 7:08 PM
    #381
    Taco_Zombie
    Taco_Zombie Member
    Zach
    2018 cement 4x4 off road
    I haven’t seen any of these mounted with the Diamondback covers but I’m pretty sure they would work. Has anybody been able to put a horizontal mount between the brackets on the side of the car, or something to mount a highlift or shovel? Do you think there’s enough space?
  2. Feb 11, 2018 at 7:09 PM
    #382
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Boswell and Taco_Zombie[QUOTED] like this.
  3. Feb 13, 2018 at 10:21 PM
    #383
    j-utah
    j-utah Well-Known Member
    2024 Tundra SR5 Air Suspension
    Here is my Voodoo cross bar install with retrax cover and rocky mounts :thumbsup:image.jpg
    KB Voodoo[OP] likes this.
  4. Feb 14, 2018 at 9:54 AM
    #384
    kingluke
    kingluke Well-Known Member
    Will
    I'm sorry if its been asked on the thread already. How easy is it to remove the cross bar? 5-10 mins?
  5. Feb 14, 2018 at 9:55 AM
    #385
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    90 seconds.
    kingluke[QUOTED] likes this.
  6. Feb 15, 2018 at 8:32 PM
    #386
    Taco_Zombie
    Taco_Zombie Member
    Zach
    Has anyone been able to mount anything to the side of their truck using these?
  7. Feb 15, 2018 at 8:44 PM
    #387
    Papadave418
    Papadave418 Well-Known Member
    Do you mean attaching something to the outside of the bracket? I’ve wondered if I could put a RTT on the bars and then work out a way to put bike mounts on the outside of the upright bracket, on the outside edges of the tent.
  8. Feb 15, 2018 at 8:57 PM
    #388
    Taco_Zombie
    Taco_Zombie Member
    Zach
    I was thinking about a mount on the sides of the brackets, not on the cross bars. Those 3 lazer cut holes on the brackets make me want to use them!
  9. Feb 15, 2018 at 9:25 PM
    #389
    j-utah
    A tube for a fishing rod would be pretty cool.
    Rhino8541 likes this.
  10. Feb 15, 2018 at 9:58 PM
    #390
    Papadave418
    That’s EXACTLY what I was thinking. With a short 1x1 square tube I want to cut like 6” length that sticks straight out from the bracket (using those holes) that I can put fork mounts on and maybe voodoo’s rear bike tire tray to have a bike mounted on the side
    (Yeah I drew that myself **not to scale)
    Jobr likes this.
  11. Feb 21, 2018 at 7:49 AM
    #391
    h5863emtmatt
    h5863emtmatt Well-Known Member
    San Diego
    17' TRD OR 4x4 DCSB
    Method Vex311, Toyo Open Country AT, 2.0 Fox Performance Coilovers/Reservoir, Total Chaos UCA, Pelfreybilt, Prinsu Cabrac
    Would this work wth the BackFlip MX4? The bed rails are about 1.5” lower or 6.5” from the top of wheel well.
  12. Feb 21, 2018 at 7:50 AM
    #392
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Moving the rails makes it not work.
  13. Feb 21, 2018 at 7:52 AM
    #393
    h5863emtmatt
    San Diego
    17' TRD OR 4x4 DCSB
    Hey Chad good morning. Do you have any bed rail mounts that work with the BakFlip MX4 or just the bed rack which is very nice.
  14. Feb 21, 2018 at 7:54 AM
    #394
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Unfortunately no. Bakflip covers are extremely difficult to work with.
  15. Feb 21, 2018 at 7:56 AM
    #395
    h5863emtmatt
    San Diego
    17' TRD OR 4x4 DCSB
    Bummer ok.
  16. Feb 21, 2018 at 5:04 PM
    #396
    j-utah
    I had the same issue and had been looking at the Backflip when I purchased my truck a few months ago. I had actually ordered it. Sent it back and got the RetraxOne MX. This is their roll up version that is not aluminum. That version is more expensive and I think is called the mx pro. I decided I liked the pros of the roll up and did not like the cons of the backflip. The roll up locks nicely. There was some discussion about how some of the flip covers can be slightly pried open and unlocked. Mainly I just needed the convenient access to all portions of the bed while the cross bars are still in place and weather protection. I decided that if I need to use the full bed, like for landscaping or firewood, large items or something, that I’d just use a trailer. That was my process but just want to throw out there that I love the roll up covers. Pricey but it’s a long term item so I went for it.
  17. Feb 24, 2018 at 9:53 PM
    #397
    j-utah
    ***Update the rocky mounts I show here don’t work as installed. Too much flex. Read thread here: https://www.tacomaworld.com/posts/17472687/. ****. I going to look for a different bike attachment to use with the voodoo bars.
    Finally had a chance to take a better photo of my retrax and cross bar setup.
  18. Feb 26, 2018 at 4:12 AM
    #398
    LtPeteMitchell
    LtPeteMitchell Well-Known Member
    2018 TRD OR
    This is exactly what I want to do with my Retrax! Looks so good. Any issues with the Retrax after the mount install? Really curious if it remains water resistant.
  19. Feb 26, 2018 at 6:19 AM
    #399
    j-utah
    B7F3FB78-452A-4884-A229-64F135B9D326.jpg FD77BF4D-CBD7-4CCD-815A-6CA25745E1F3.jpg
    ***update: no issue with the retrax and voodoo setup, but the rocky mounts are not working for me. I will look for a different bike attachment. See thread here: https://www.tacomaworld.com/posts/17472687/ *****
    No issue! When I was bolting in the clamps to the bed rails, I pushed down on the top of the retrax channel, compressing the foam seal under the channel. The foam is thick enough and good quality, maybe 3/8 thick. The retrax channel is strong, no bowing that I could see. Foam wraps right around the cross bar brackets. Cross bars are as far apart as they will go, I don’t see a adjusting them again. Also a word on the drain tubes that are part of the retrax. Looks like you’d have to drill holes in the bed to get those out. I have one of those thick OEM rubber mats. I just tucked the drain tubes under that. Any water drains under the mat onto the bed channels. Probably ok. I might look at the tube placement maybe get it to line up better with existing drain holes, use bed as gutter. Definitely dry on the mat. Water should stay on channels on bed. Not much rain here but car washing totally dry.
  20. Feb 26, 2018 at 7:34 AM
    #400
    LtPeteMitchell
    2018 TRD OR
    Thanks so much for the extra pics.
    I saw that Retrax has a new bed rail coming out: https://youtu.be/LvoAsmMZhOY
    I emailed Retrax and they said they’d be available in the summer. But I prefer the Voodoo.
