KB Voodoo Crossbars for Tonneau Covers - IN STOCK!! (redesigned for RTT's!!)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KB Voodoo, Oct 28, 2016.
  1. Apr 29, 2018 at 7:08 PM
    #461
    Joshkytaco
    Joshkytaco Member
    Josh
    2016 White TRD Sport 4x4
    2 questions about the bar. When using 1 bar is it possible to fold up the factory trifold and rest it against the bar? Similarly, if the bar is removed and the cover folded up is there clearance to reattach the bar overtop?
  2. Apr 29, 2018 at 7:09 PM
    #462
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Yes and yes.
  3. May 8, 2018 at 5:43 PM
    #463
    j-utah
    j-utah Well-Known Member
    2024 Tundra SR5 Air Suspension
    The Tundra guy stopped and asked me about the rear rack I had. And here he is all set up. We’re parking buds today!
  4. May 15, 2018 at 7:59 PM
    #464
    Mauiboi84
    Mauiboi84 Well-Known Member
    Jon
    2016 Toyota tacoma sr5
    I have just one dreaded question how much total with shipping to Hawaii 96732?
  5. May 17, 2018 at 1:21 PM
    #465
    ActuallyaTaco
    ActuallyaTaco Well-Known Member
    Adam
    Raleigh, NC
    2016 Tacoma TRD OR
    @KB Voodoo question for you. I just ordered a set of hi rises, How have y’all mounted a rtt to these? Are you simple mounting them with one bolt in each corner?
  6. May 20, 2018 at 10:02 AM
    #466
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    All set up for drift boat float fishing.... Fishing rod holder and bike mounted to ride back to the put in after parking the truck and trailer downstream.
  7. May 20, 2018 at 2:24 PM
    #467
    j2k
    j2k Well-Known Member
    @KB Voodoo question for you. can you use these hi rises to attach your bed rack? I want to get more space between the oem tonneau and the bed rack.
  8. May 20, 2018 at 2:28 PM
    #468
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Noooo.........
  9. May 23, 2018 at 9:54 AM
    #469
    Mauiboi84
    Jon
    What’s up man by any chance you reme what size was the button heads you bought? Thanks
  10. May 23, 2018 at 11:35 AM
    #470
    j-utah
    They should be 3/8” and just the standard size that fits in these rail cleats. I took one of the rail cleats to an Ace hardware and got the button head bolts there... big box will not have them and not worth ordering IMO. These are the standard cleats, same spec as what comes with the cross bars:
    https://www.amazon.com/Bolt-Dropper-Toyota-Stainless-Accessories/dp/B078YD3FY6
  11. May 27, 2018 at 5:58 AM
    #471
    B00GIE
    B00GIE Active Member
    AZ
    2018 DCSB TRD OR CEMENT
    King 2.5 Front Coilover Adjustable King 2.5 Tundra Rear Shock Adjustable Icon UCA Delta Joint Icon RXT Leaf Spring Archive Garage U-Bolt Flip Kit 17 " TRD Pro Wheel BF Goodrich K02 285/70/17 KBVoodoo MAX Modular 10" Long Bed Rack CVT Mt. Shasta Summit Extended | Grey Cali Raised Bed Stiffeners TRD Pro Grill Baja Designs Squadron Fog Lights Amber WC Xenon Depot HID RetraxOne MX Tonneau Cover MESO Gas Hole MESO Ultimate Turn Signal V4 AJT Key Fob Tufskinz Carbon Fiber Grill Overlay Tufskinz Carbon Fiber Tailgate Inserts Tufskinz Foam Interior Inserts No Lux Blackout Overlay Ceramic Window Tint 20% | 3M Clearbra
    Hey, just installed my Retraxone MX on my 18 yesterday. Are the rails sitting up like a 1/2 inch? I thought it would be more flush from what i've seen on videos and pictures. Let me know if you guys need pics, i can send it out shortly. thanks in advance!
  12. May 27, 2018 at 6:53 AM
    #472
    j-utah
    Yep, they do have foam they sit on. About 3/8”. You can push down on the rails to compress the foam while tightening the cleats, but that will only make a tiny difference. Put your weight into it and push down lined up with cleat. I guess you could replace the foam with thinner foam but the height didn’t bother me. I wanted it to be more flush too though when I first installed but it seemed ok after a while.
    Daddy_Firebird and ToyoDrew like this.
  13. Jun 1, 2018 at 12:14 AM
    #473
    GhostChilly
    GhostChilly Member
    Seattle
    2018 Cement Tacoma TRD OR DCSB
    ICON Stage 9 Suspension, ICON Rebound Wheels, Nitto Ridge Grappler 33's, ATH Bed Reinforcements, Pedal Commander, LED interior lights, derped badges
    I’m really liking how sturdy these voodoo racks are for mounting a RTT and being able to off road. I was wondering how the water tightness is for this setup with a roll up tonneau like a pace edwards? Can anyone comment on that?
  14. Jun 1, 2018 at 5:36 AM
    #474
    j-utah
    I can say that the Retrax roll up has been very water tight. A bit of water can get in at the tailgate but not much from what I’ve seen. Certainly it’s not affected by the Voodoo system. The foam seals around the voodoo base nicely. The Retrax and Gator trax are the same cover, also owned by same company. These are the two best roll cover options IMO. Pictured above is the Retrax One MX. It is a high quality plastic roll up. They also make an aluminum roll up which I think is called the pro. I didn’t need that.
    GhostChilly[QUOTED] likes this.
  15. Jun 20, 2018 at 5:58 PM
    #475
    poppy510
    poppy510 Well-Known Member
    Anybody successfully mount the front rack forward of the front latch pin for the stock tonneau? You guys with the Retrax cover are getting the front rack real close to the cab, which is good for fitting bikes. The stock tonneau has a latch up there that interferes without some modification.
    BTW these racks are VERY sturdy and well made. Just exploring all my options.
    Here's why:
    I suppose I could bungee the frame down to the rear rack...
    Sm32589g and ToyoDrew like this.
  16. Jun 28, 2018 at 2:03 PM
    #476
    AltaTacoma
    AltaTacoma Well-Known Member
    2018 BRM Tacoma TRD Off Road
    Has anyone installed these with a TruXedo Lo Pro without any modifications to the cover rails or other hardware?
  17. Jul 1, 2018 at 8:25 AM
    #477
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    How much is shipping? Free?
  18. Jul 1, 2018 at 10:58 AM
    #478
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Our website will calculate shipping for you.
    TRDPro916[QUOTED] likes this.
  19. Jul 4, 2018 at 9:40 PM
    #479
    Colemillermma
    Colemillermma IG:@colemillermartialarts
    Cole
    Bonaire, Georgia
    2017 Tacoma TRD Off Road
    Legendary
    j-utah likes this.
  20. Jul 26, 2018 at 6:33 AM
    #480
    TRD_QkSnd
    TRD_QkSnd Member
    2018 TRDOR Quicksand 6 MT
    Anyone know if you can attach a basket to these racks, then attach kayak j hooks to the basket ??
    Wondering if this would allow the kayaks to clear the roof line while creating storage in the basket
