KB Voodoo Crossbars for Tonneau Covers - IN STOCK!! (redesigned for RTT's!!)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KB Voodoo, Oct 28, 2016.
  1. Feb 28, 2020 at 5:55 AM
    #581
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You would have no issues.
    These are in stock and ready to rock.
  2. Feb 28, 2020 at 7:11 PM
    #582
    Little Grey
    Little Grey Member
    BC, Canada
    2019 DCSB TRD Off Road
    Excellent, will be placing order this weekend!
  3. Mar 2, 2020 at 9:34 PM
    #583
    Chip_311
    Chip_311 Well-Known Member
    Brian
    NJ
    2017 DCSB OR
    BFG KO2s Pro Grille Pro Skidplate Pro Fox Suspension DShackles F & R CaliRaised LED Bumper Baja designs S2pro / S1 CaliRasied Off-road Sliders Waterport R4T Arm Skids RCI Skids Weather tech Visor Front Camera SCS Wheels Rear Bumper Covers Maxtrax Recovery Meso Gas Hole/Turn Signals Pop n Lock Kit Extended Rear Breather Expedition Essentials TPAM Midland USA Comms Clazzio Leathers Victory 4x4 Mollie Garmin Tandem Mountain Hatch Bestop2 Thule Evo Rack
    Bakflip mx4
    KB Voodoo[OP] likes this.
  4. Mar 2, 2020 at 10:49 PM
    #584
    mkn177
    mkn177 Well-Known Member
    2017 White Tacoma TRD off road
  5. Mar 3, 2020 at 4:19 AM
    #585
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
  6. Mar 3, 2020 at 5:40 AM
    #586
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    My lid relocates my rails lower so I can use this mounts.
    Chip_311 likes this.
  7. Mar 3, 2020 at 5:56 AM
    #587
    Papadave418
    Papadave418 Well-Known Member
    I currently have the Alumax rack with tonneau brackets over my Diamondback cover and it works so well. Previously I had high rise bars and I can attest they work great! Quality stuff for anyone on the fence as I have hundreds of off road miles with these set ups holding my gear. :thumbsup:
  8. Mar 3, 2020 at 2:41 PM
    #588
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Does anyone have a picture of their bars with a hi-lift jack attached to the cross bar towers? I'm thinking about picking a jack up but would like to see how it mounts there, first. Wondering if I could still deploy my RTT if I mount it to the side that swings open or if the hi-lift base sticks up too much.
  9. Mar 13, 2020 at 11:21 AM
    #589
    QuadCop
    QuadCop Member
    @Papadave418 When you were running your original KB crossbars (pre alu-max), I see you carried an MTB on them next to your RTT. I've got that set-up but the bike isn't fitting well next to the tent. Were you having to remove the pedals, or, was your tent pushed a few inches to one side rather than being centered? Just curious how you made it work. Thank you sir.
  10. Mar 13, 2020 at 11:25 AM
    #590
    QuadCop
    QuadCop Member
    @KB Voodoo With the hi-rise crossbars, I've currently got my RTT attached using the "clamp" type method where I've got the two bolts into the t-nut rail of the tent, then extended on either side of the crossbars. Basically the way you'd attached a tent to any style of rail... my question is, since your crossbars have the slots in them, can I run the bolt from the tent t-slot through the crossbar to another t-nut (or washer/nut)? I'm not sure if that puts too much force on it. Hopefully this makes sense. Thank you sir.
  11. Mar 13, 2020 at 11:36 AM
    #591
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Yes, you can do that.
    QuadCop[QUOTED] likes this.
  12. Mar 13, 2020 at 11:40 AM
    #592
    QuadCop
    QuadCop Member
    Excellent, can you tell me which size t-nuts slide into them, or am I better off running a washer and nut up there?
  13. Mar 13, 2020 at 12:06 PM
    #593
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You want to use a washer and nut.
  14. Mar 13, 2020 at 2:57 PM
    #594
    Papadave418
    I had a Yakima M size tent and the pedals would just clear under the tent
  15. Apr 29, 2020 at 7:01 AM
    #595
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Anyone know (or @KB Voodoo) what duties are like to Canada on these? Also say if you upgrade to a larger truck in the future, can you just buy a longer top bar?
    Hayron84 likes this.
  16. May 2, 2020 at 2:40 PM
    #596
    tbett56
    tbett56 Well-Known Member
    2015 Toyota Tacoma TRD Sport
  17. May 2, 2020 at 3:07 PM
    #597
    siniquezu
    siniquezu Well-Known Member
    Anyone try these on a Lomax?
  18. May 2, 2020 at 9:53 PM
    #598
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    Are there any options where I can have the ability to open the panels on a Diamondback?
  19. May 5, 2020 at 8:52 PM
    #599
    kylejp6
    kylejp6 Member
    Didn’t really get the distance I wanted between the bars when mounting with a retrax and 3 man tepui. Tepui recommended 32-48 inches apart and mine are sitting at 30 inches end to end.
    A little curious if the the uprights would have fit next to the canister. Sort of automatically assumed they wouldn’t so I will be looking at it sometime tomorrow to see.
    TacoNesian likes this.
  20. May 5, 2020 at 9:38 PM
    #600
    jgthomas
    jgthomas New Member
    I emailed KB Voodoo a few days ago with the same question. They said it wasn't compatible.
