KB Voodoo Crossbars for Tonneau Covers - IN STOCK!! (redesigned for RTT's!!)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KB Voodoo, Oct 28, 2016.
  1. May 22, 2020 at 3:27 AM
    #621
    kylejp6
    kylejp6 Member
    I love it, but eventually I’ll need to upgrade the bars to a bed rack.
    The autana is about a foot too long, so it’s a huge pain but it’s a great place to hide from rain, change, and store stuff.
    I also only have space for about two peoples worth of camping and the bars with a retrax cover do not space the recommended center to center distance by tepui. It seem rather stable though.
    I bought this for the low profile, but it has its limitations. If it’s more than you and 1 other person, you’ll realize pretty quick how much space you don’t have.
    I’ll probably end up getting a prinsu roof rack and the 10” max modular sometime in the future, but this is a great starter setup.
    What pics are you looking for?
  2. Jun 10, 2020 at 9:19 AM
    #622
    DanishTaco
    DanishTaco Well-Known Member
    2019 TRD-Offroad
    I'd imagine you could just put some window/ gasket sealer around the area where u have a gap. Should do the trick!
    Papadave418 likes this.
  3. Jun 25, 2020 at 8:27 AM
    #623
    xmalachi
    xmalachi Well-Known Member
    Does anyone know what the maximum width would be for accomodating two bikes and a RTT on the crossbars? I'm looking at a Tepui Autuna 4 and I imagine it might be too wide.
  4. Jun 25, 2020 at 8:29 AM
    #624
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    They are all 48" wide when closed.
    xmalachi[QUOTED] likes this.
  5. Jun 25, 2020 at 8:36 AM
    #625
    Papadave418
    Papadave418 Well-Known Member
    I measured the distance between my through fork mounts and it’s about 60 inches between them where it wouldn’t interfere with the bike forks coming up on each side. Meaning my rack can fit about a 5ft wide tent 160FF538-9434-4BD2-952C-69C2024ED4C1.jpg
    Dryfly24 and Twins09 like this.
  6. Jun 25, 2020 at 10:43 AM
    #626
    xmalachi
    Thanks!
    Is your rack the same width as the crossbars? It seems like the max modular would easily allow for it but I also could be very confused.
  7. Jun 25, 2020 at 11:32 AM
    #627
    Papadave418
    The max modular does expand to whatever width the bed is. So I measured out where I had the bike forks on the rack which is the width it takes to sit on a taco
  8. Aug 24, 2020 at 10:45 AM
    #628
    created2kill
    created2kill New Member
    Can you have a RTT (yakima poler medium) with a thule upright bike carrier on the hi rise crossbars ?
    ***Does the yakima clamps fit into the kb voodoo hi rise ?
  9. Aug 29, 2020 at 10:23 AM
    #629
    Jlab
    Jlab Well-Known Member
    Justin
    Utah
    2020 Cement TRD OR DCSB
    Does anyone know if the Hi Rise bars will fit with the Roll N Lock cover?
  10. Oct 19, 2020 at 3:14 PM
    #630
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Not even if more than one of us want some??
  11. Jan 18, 2021 at 5:51 PM
    #631
    Sypebeast
    Sypebeast Work in progress
    Nick
    Winnipeg, Manitoba, Canada
    2016 TRD Sport 6spd Manual Shortbox
    BFG KO2, Bilstein 5100, Firestone Airbags, Blackhorn BH01 Wheels,
    To my friends North of the Border. When you ordered your KBV bed rails, did you pay any duties or taxes? Being made in the USA, they should be duty free...correct?
  12. Feb 3, 2021 at 11:27 PM
    #632
    tbraumb11
    tbraumb11 Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    In case anyone is wondering neither of these brackets will work on a 2015 toyota branded tonneau hard flip style no idea the model it is but they will not work.
  13. Feb 4, 2021 at 6:26 AM
    #633
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    They will definitely work.
    If you are having trouble with installation, contact us directly.
  14. Feb 5, 2021 at 9:15 AM
    #634
    tbraumb11
    nanaimo
    what are those?
    Confirmed they will not work, no fault of KB voodoo, I have just had no luck ordering these to work with the cover I have.
    Just a word of caution if you have a 2015 OEM tonneau the way the rail is designed it will not allow you to mount these, I need to look at a new tonneau now if I want to run these or take it off.
  15. Feb 9, 2021 at 10:23 PM
    #635
    tbraumb11
    nanaimo
    what are those?
    there were no duties.
  16. Feb 9, 2021 at 10:57 PM
    #636
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    I bought this set for my '18 Sport, all powder coated, off of another TW member who opted to go a different route. They're exactly what I wanted for my RTT setup and being able to keep my OEM tonneau cover. Perfect fit as long as you put the cross bars and mounts in locations that aren't on hinge locations of the cover. The low rise option here also tucks the RTT behind the cab which reduces a lot wind drag.
    Kudos to @KB Voodoo for an intuitive solution.
    Bkups likes this.
  17. Feb 16, 2021 at 5:21 PM
    #637
    tbraumb11
    nanaimo
    what are those?
    I need to revise this, I just got a bill for $115.00 CDN from fedex.
    pst 23.78
    gst 33.29
    advancement fee 10
    gst on advancement fee 2.77
    clearance entry fee 45.35
    no duties but a bunch of costs... gst and pst are fine but the other fees are a bit of a joke, just for information.
  18. Mar 1, 2021 at 11:25 AM
    #638
    leftfoot
    leftfoot Member
    Shaun
    05 Black DBL CAB
    KB,
    Have you had any issues with shearing or point loading with current design for the tonneau extension?
    This design spreads load and would be great to port over for the KB Voodoo rack. Admittedly it might only address the front side since the back is into the body, but seems a big improvement over the single rail locking location. I can address the shear loading a bit with a stronger bolt for now. Really want my trifold back on but have been a little apprehensive to purchase till now.
  19. Mar 1, 2021 at 11:31 AM
    #639
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There is no load on the bolt. The bolt merely holds the rack in place.
    The load is handled by the side rails of the truck.
    There have been no issues.
  20. Mar 1, 2021 at 11:35 AM
    #640
    leftfoot
    leftfoot Member
    Shaun
    05 Black DBL CAB
    Thanks. Wanted to ask you since you would know best. It’s a great system so wanted to be sure before hitting the more dynamic trails in Utah rather than Florida with an RTT up top.
