KB Voodoo Fabrications - Online Ordering PROMO Codes
Discussion in 'Deals & Coupons' started by KB Voodoo, Feb 3, 2015.
  1. Feb 19, 2021 at 10:22 AM
    #401
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    @KB Voodoo or anyone: Any idea of the spacing necessary on the rails for mounting a 23 Zero Walkabout 62, on a 2019 off road DCSB?
    I will actually be going to pick up the tent directly from manufacturer in SLC, Utah after I receive the bars from KB Voodoo. Would be nice to have them mounted as close to where they need to be as possible before I get there to help ease the process...
  2. Feb 19, 2021 at 10:23 AM
    #402
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Don't sweat it. The bars are super easy to move.
    Dryfly24[QUOTED] likes this.
  3. Feb 19, 2021 at 10:24 AM
    #403
    Dryfly24
    George
    NM
    Cool, Thanks... :cheers:
  4. Feb 22, 2021 at 12:47 PM
    #404
    clock11
    clock11 Well-Known Member
    Aaron
    Southern California
    2020 White TRD Off Road
    Deaver Stage III, Icon Stage 3 (minus Icon leafs), BFG K02s, Prinsu roof rack, Diamondback HD, CaliRaised Ditch lights and Brackets, Clazzio Seat Covers, Rearseat 12v Power & USB, Bed cubby 12v Power & USB, Interior LED bulbs, Toyota OEM tailgate lock.
  5. Feb 22, 2021 at 12:51 PM
    #405
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The ALUMAX is really useful if you have a truck other than a Tacoma, but you don't need the extra expense if mounting it to your Taco.
    PM'd about the promo code.
  6. Feb 22, 2021 at 12:58 PM
    #406
    clock11
    Aaron
    Southern California
    Awesome, thanks!
  7. Feb 22, 2021 at 1:37 PM
    #407
    igon370
    igon370 Member
    Johnson City
    2021 TRD Off Road
    Toyota Tacoma Hi Rise Crossbars, for use with tonneau covers (fits years 2005 and up) Looking to spend some tax monies. Any discount code?? Thank You
  8. Feb 22, 2021 at 1:52 PM
    #408
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    PM'd
  9. Feb 22, 2021 at 6:35 PM
    #409
    savin yours
    savin yours Well-Known Member
    Bryan
    SE Tx
    2018 TRD Off Road
    I can measure mine tomorrow if you want?
  10. Feb 22, 2021 at 7:43 PM
    #410
    Dryfly24
    George
    NM
    I appreciate it, but don't go through any trouble. Heard back from KB Voodoo and they said not to sweat it cause they’re pretty easy to adjust. :fistbump:
  11. Feb 28, 2021 at 6:50 AM
    #411
    nordic333
    nordic333 Member
    2006 Tacoma Access Cab 4WD SR5
    @KB Voodoo I am looking into the Max Modular 10” Tacoma Bed Rack and was looking for some additional insight before taking the plunge.
    First and foremost, should I go with 10” or 14”..? I’d like to keep the setup aerodynamic, but would also like to preserve visibility through the rear window while also maintaining access to the storage area in the bed itself... 14” sounds like it may be getting a bit high..?
    Also, I currently have a bolt-in “Access” Tonneau cover and the original accessory bed rails have been removed. The goal is to keep the cover and reinstall the accessory rails in order to mount the rack. Can this all be accomplished without the tonneau adapters..? It looks like the base of the rack could pass between the bed rails and cover in order to access and mount to the accessory rails. Does this make sense..? If this doesn’t work as envisioned, can I simply add-on the adapters at a later date..?
    Lastly, once everything is decided is there any chance you can provide a promo to assist with making the purchase..? Any assistance is greatly
    appreciated..!
    Peace..!
    https://www.max-modular.com/shop-max-modular/max-modular-10-high-toyota-tacoma-bed-rack
  12. Mar 1, 2021 at 9:10 AM
    #412
    ParadigmShifter
    ParadigmShifter Well-Known Member
    Ian
    Scottsdale, AZ
    2020 Tacoma TRD Off-Road - White
    About to pull the trigger on the 10 in bed rack and maxtrax mounts to replace my hi rise crossbars. Are you still running any promos?
  13. Mar 2, 2021 at 6:33 AM
    #413
    valdark
    valdark Well-Known Member
    Looking to buy the hi-rise crossbars (got a backflip cover) but curious about # of bars - two seems plenty for a cargo basket, mountain bike, RTT, etc. Any reason you'd need 3? Guess I could always order more. Also, if theres any promos, would love a code!
  14. Mar 5, 2021 at 5:02 AM
    #414
    N8diggity
    N8diggity Well-Known Member
    DFW, TX
    ‘20 DCSB OR Silver
    @kbvoodoo I’m having a bit of a hard time doing math this am. Tonneau cover brackets plus 18” rack equals how much total height? I want to be able to be able to put a canoe on the bed rack that lines up with a cabin rack.
    Also- any recommendations on a cabin rack that lines up and looks good with your bed system?
  15. Mar 5, 2021 at 5:04 AM
    #415
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    About 28 inches. I have the 62.
  16. Mar 5, 2021 at 5:15 AM
    #416
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The tonneau brackets add 2.5” to the height of the rack.
  17. Mar 5, 2021 at 7:56 AM
    #417
    Dryfly24
    George
    NM
    Thanks, already got the rack on, picking it up Monday. Now I kinda wish I had gone with the higher rack like yours for more room to mount shit. I went with the lower racks to keep the center of gravity down.
    plus I really dig those awnings and the annex I bought along with the tent would work better a little bit higher off the ground.
    baldridge[QUOTED] likes this.
  18. Mar 5, 2021 at 10:45 AM
    #418
    baldridge
    Bart
    Auburn, AL
    I had a mid height and had plenty of room. I just added a fridge so needed a taller for extra clearance since I have a decked system.
    Mid Height
  19. Mar 5, 2021 at 12:53 PM
    #419
    Dryfly24
    George
    NM
    Sweet set up! Fridge is in the works for me too. How are you liking the tent overall?
  20. Mar 5, 2021 at 7:00 PM
    #420
    baldridge
    Bart
    Auburn, AL
    Love it. Had it for about 3 or so years. Had mine before they came out with LST.
