KB Voodoo Powder Coated Side Rail Caps for 3rd Gen Tacoma's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KB Voodoo, Apr 25, 2017.
Will these be used with a Tonneau Cover?
  1. Tonneau Cover
    99 vote(s)
    54.7%
  2. No Tonneau Cover
    82 vote(s)
    45.3%
  1. Apr 25, 2017 at 4:35 PM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We have our 3rd gen side rail caps designed and prototyped. Everything fits like a glove and looks great, so we're ready to order a big batch of them from the laser cutter.
    Since there is a factory option for a tonneau cover for 3rd gen Tacoma's that will require its own side rail cap design, we need to get an idea of what to order.
    Will you be using these with the factory tonneau cover? (either way, please answer poll)
    So, if you plan on purchasing these at some point, please take our poll to help us order the correct quantities.
    Thanks!!
    PS: There will obviously also be a package deal with our 3rd gen tailgate caps.
    Now, here's pictures:
    SilverII, ScottyR, awood211 and 8 others like this.
  2. Apr 25, 2017 at 4:41 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    I wonder how hot these would get in PHX?
    Skydvrr and ChadsPride like this.
  3. Apr 25, 2017 at 4:44 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    No hotter than any of the other black parts of the truck.
    Roxanne16 and ChadsPride like this.
  4. Apr 25, 2017 at 4:47 PM
    SuperTan
    SuperTan Well-Known Member
    Beach Cities, Cali
    17 TRD OR DCSB MGM 4x4
    Looks good. How is the thickness compared to oem rails?
    ChadsPride likes this.
  5. Apr 25, 2017 at 4:56 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    These are 1/8" thick steel, so about the same.
    Except these are 20x stronger......because steel is real.
  6. Apr 25, 2017 at 5:13 PM
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    but, they'll likely be a couple orders of magnitude better at transferring that heat to your arms when you reach over them. and hold more heat energy, so they won't cool down as quickly while searing flesh.
    some parts of living in az aren't glamorous...
    tacoguy88, Skydvrr, Heepspo and 10 others like this.
  7. Apr 25, 2017 at 5:15 PM
    SuperTan
    Beach Cities, Cali
    Would I need to add any type of barrier to the bed rail? Between painted surface and rail. I know from another owner when I swapped rails from purchasing a tonneau cover, the plastic rails scratched the paint.
    Probably unnecessary for some, but some people like myself care.
  8. Apr 25, 2017 at 5:17 PM
    .jake
    .jake Ex-Lion Tamer
    That's what i was thinking, too. Can you imaging trying to reach for another beer in a cooler in the bed, in August?
    9TRDTCO and ChadsPride like this.
  9. Apr 25, 2017 at 5:37 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We will be supplying the caps with 1/16" thick foam tape to eliminate metal to metal contact.
  10. Apr 25, 2017 at 5:48 PM
    SuperTan
    Beach Cities, Cali
    Great, definitely interested now
  11. Apr 25, 2017 at 5:56 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  12. Apr 25, 2017 at 6:14 PM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    Back ordered
    Those look awesome.
  13. Apr 25, 2017 at 6:17 PM
    angryskittle
    angryskittle Active Member
    Matthew
    PDX
    2017 Inferno DCLB OR
  14. Apr 25, 2017 at 6:22 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Probably not. The last time I put stake pocket holes in the side rail caps, people freaked out.
  15. Apr 26, 2017 at 12:12 AM
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    Interested because it would be another way to make my revolver x2 more water tight. I think it seal much better if it had something to lay flat against vs the texture patterns on the stock set
    89hatcher, 0210, ChadsPride and 2 others like this.
  16. Apr 26, 2017 at 12:23 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    How come your making these in steel but make the tailgate cap with aluminum?
  17. Apr 26, 2017 at 12:26 AM
    MrFurious43
    MrFurious43 Well-Known Member
    2017 TRD OR DCSB Quicksand Tacoma, 2023 TRD OR DCSB Lunar Rock Tacoma
    Interested to cause I have the X2 as well.
    Do these sit flush with the interior bed as opposed to the plastic cap which protrudes out a bit?
  18. Apr 26, 2017 at 1:13 AM
    mauidogg
    16 DCSB TRDOR
    Because of the added weight to the end of the tailgate. Makes it swing down too fast
    Edit. I did something about this on my own. I have a aluminum L piece with a magnet attached. I leave it in the bed, when I load my bed I place it on the inside edge of the tailgate to protect it.
  19. Apr 26, 2017 at 4:44 AM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Subbed
    Need these because my KB Voodoo tailgate cap sits lower than the side plastic, creating a small gap where the Diamondback HD cover seals the tailgate.
    These would even that out.
  20. Apr 26, 2017 at 4:47 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You are correct. With our side rail caps and tailgate cap, it's a perfectly flat surface all around.
