KC | 16-18 Tacoma Ditch Light Packages - Mounts and Lights - *NEW*
Discussion in 'Lighting' started by Taylor@KC HiLiTES, Aug 14, 2018.
  1. Aug 14, 2018 at 11:59 AM
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES [OP] Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
    We are very excited to announce that we are now offering a complete, out-of-the-box solution for ditch/pillar lights for 2016-2018 Toyota Tacomas! These will be full packages and will have everything you need, including the easy to install bolt-on/no-drill mounts, a huge variety of lights to fit your budget and need, and all the hardware and wiring you need. Our goal with this was to create solutions for everyone that takes the guesswork out of piecing together parts from various vendors. You can choose from a variety of lights and beam patterns to give you greater visibility out of your lighting at night.
    Ditch/pillar lights are a great auxiliary light for someone that is on a budget but still needs improved lighting, or for someone who already has lighting but needs more periphery fill in lights. When properly aimed, they will increase your field of view allowing you to see oncoming obstacles with enough time to properly navigate them and be fully aware.
    To see the link to these on our website, see below or click on any of the photos!
    FEATURES
    • 2016-2018 Toyota Tacoma Ditch Mount Light Bracket Set
    • Designed to Securely Mount and Attach KC LED Lights to Toyota Tacoma Cowl/Pillar/Ditch Locations
    • Utilizes OEM Hood Hinge Bolt Locations For An Easy Install
    • No Drilling or Trimming Required, Complete Bolt On Installation
    • Low Profile Construction To Provide Maximum Driver Visibility
    • Precision Bent and CNC Cut With Powder Coated Black Textured Finish
    Available LED Light Kits (see below for more info on these)
    • I know there's a ton of options here! If you get confused or need help, just ask! I'm more than happy to give my personal advice to help out.
    • KC C-Series C3 LED Spot or Flood Beam
    • KC Gravity® LED G34 SAE/ECE Driving or Wide-40 Beam
    • KC 4" LZR Round LED
    • KC FLEX™ LED Single Spot or Spread Beam
    • KC FLEX™ LED Dual Spot or Spread Beam
    • KC FLEX™ LED Quad Combo Beam
    PARTS INCLUDED
    • (2) Black Powder Coated Steel Ditch Mount Brackets for 16-18 Toyota Tacoma
    • (1) Performance Wiring Harness w/ Waterproof Connectors and LED Light Switch
    • (1) Pair of lights of your choosing
    OEM FITMENT ON TOYOTA TACOMA
    These high quality, US made brackets were specifically designed for OE 16-18 Toyota Tacoma Hood/A-Pillar locations for an easy LED light mount solution. No drilling or fabrication required, simply attach the brackets to factory bolts located along the hood and the cowl section of 2016-2018 Toyota Tacoma trucks. These ditch mount brackets allow you to securely mount various KC LED lights to your Tacoma.
    LED LIGHTING KITS THAT MEET YOUR LIGHTING NEEDS
    KC's Toyota Tacoma 16-18 C-Series C3 LED Spot Beam Ditch Mount Kit provide incredible forward distance and improved visibility when off roading. Using highly efficient Osram LEDs, KC C3 LEDs deliver 1,080 lumens of output per light, along with long lasting performance using on board thermal management for maximum cooling.
    KC C-Series C3 LED Toyota Tacoma 2016-2018 Ditch Mount Lights:
    KC's C-Series C3 LED lights use highly efficient Osram LEDs to deliver 1,080 lumens of output per light in a Spot Beam or Flood beam pattern. C3s feature a highly compact die-cast aluminum housing, aluminum core PCBs with thermal management for maximum cooling, and long lasting LED performance. Choose Spot Beam to deliver improved forward distance or Flood Beam to provide evenly distributed peripheral lighting. Either option is an affordable, high performance lighting upgrade for your Tacoma.
    KC Gravity® LED G34 Toyota Tacoma 16-18 Ditch Mount Lights:
    KC Gravity® LED G34 lights feature efficient Cree LED technology in SAE/ECE Driving Beam or Wide-40 beam patterns. Each Gravity® G34 LED uses KC's patented Gravity Reflective Diode system to strategically position LEDs inside precision engineered reflectors so that all light output is being carefully directed and aimed to deliver usable light. What you get is highly targeted light distribution, providing unparalleled clarity, performance and beam shape. Each light provides 2,300 lumens of raw led light output, in either a Driving Beam or Wide-40 Beam pattern. SAE/ECE Driving Beam G34 are ideal to improve distance directly in front your vehicle, while Wide-40 Beam deliver a wider area of coverage to improve side-side visibility for areas closer to your Tacoma.
    KC 4" LZR Round LED Toyota Tacoma 16-18 Ditch Mount Lights:
    KC 4" Round LZR LED lights feature KC's signature finned turbine die-cast aluminum housing design for maximum heat dissipation, LED performance and longevity. Using forward facing reflector optics, 4" LZR LEDs deliver an incredible 1,832 lumens of raw led light output in a highly usable off road spot beam pattern for improved forward distance and balanced off lighting visibility for your Tacoma.
    KC FLEX™ LED Toyota Tacoma 16-18 Ditch Mount Lights:
    KC FLEX™ LED Single:
    KC FLEX™ LED Single lights feature an extremely compact, durable and unique die-cast aluminum housing design. Inside each FLEX LED single lies powerful 10W Cree LEDs and precision injected reflector optics to create 975 lumens(per light) of immense forward facing LED light output. Their compact form factor makes FLEX™ LED singles perfect for A-Pillar/Ditch Mount locations on Toyota Tacoma vehicles. Choose from Spot or Spread beam pattern light kit options to deliver improved forward distance and peripheral visibility for your truck.
    KC FLEX™ LED Dual:
    KC FLEX™ LED Dual lights feature an extremely compact, durable and unique die-cast aluminum housing design. Inside each FLEX LED single lies 2 powerful, 10W Cree LEDs and precision injected reflector optics to create 1,950 lumens(per light) of immense forward facing LED light output. Their compact form factor makes FLEX™ LED singles perfect for A-Pillar/Ditch Mount locations on Toyota Tacomas. Choose from Spot or Spread beam pattern light kit options to deliver improved forward distance and peripheral visibility for your truck.
    KC FLEX™ LED Quad:
    KC FLEX™ LED Quad lights feature an extremely compact, durable and unique die-cast aluminum housing design. Each FLEX™ LED Quad delivers 3900 lumens of of raw LED light output from 4, highly efficient, 10W Cree LEDs in a combo, spot and spread beam pattern. What you get is an incredibly powerful, balanced output for improved forward distance and peripheral illumination. Their compact form factor makes FLEX™ LED Quads perfect for A-Pillar/Ditch Mount locations on Tacomas.
    ChadsPride, Biscuits and TacoTacoma16 like this.
  2. Aug 21, 2018 at 7:17 AM
    Leonardskeonard
    Leonardskeonard Active Member
    2017 Tacoma TRD Sport 4x4 6MT
    Ordered a set of these with the G34. Looking forward to testing them out
  3. Aug 23, 2018 at 5:14 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Awesome! Post up some pictures when you get them.
  4. Aug 23, 2018 at 5:49 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    You offer this stuff for the 2nd Gen as well?
  5. Aug 23, 2018 at 8:33 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
  6. Sep 6, 2018 at 3:41 PM
    Leonardskeonard
  7. Sep 7, 2018 at 8:40 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Nice!! It looks awesome. Those G34s are such a great fit for ditch lights. I still want to do those on my own truck one of these days!
  8. Oct 1, 2018 at 10:57 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Leonardskeonard likes this.
  9. Oct 1, 2018 at 11:43 AM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Do the gravity lights have a yellow or Amber cover available
  10. Oct 1, 2018 at 12:18 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Which Gravity lights? The Gravity lights is kind of an over-arching term/collection of the Pro6, the G4 fogs, and the G34s that you see on the ditch brackets. The G4s are available in amber, and the Pro6 lights have a snap-on amber cover. The G34s currently do not have an amber option.
  11. Oct 2, 2018 at 8:10 AM
    solscooter
    Brian
    Minnesota
    Sorry. I meant The g34 on the ditch brackets
  12. Oct 2, 2018 at 10:16 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Those do not right now. But, you can go with the FLEX Duals in a spread beam and install our amber covers on those.
  13. Oct 29, 2018 at 6:14 PM
    vipersmack
    vipersmack Well-Known Member
    2018 TRD Off-Road
    I have the 4" LZR kit ordered, actually posted on the 2nd gen thread about these as well accidentally. I will be posting up pics as soon as they get installed. I have the gravity g4 amber fog lights already installed so I am thinking they will be looking good!
    @Taylor@KC HiLiTES I still need one of those hats man! (Referring to my accidental post on the second gen forum). Pics will follow within the next week or so hopefully!20181028_182435.jpg
  14. Oct 30, 2018 at 8:35 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Awesome!! I'm definetly going to need photos of them when installed! As far as that hat goes, it's no longer unfortunately. We stopped making those and no longer have any in stock, but we are actually working on some other hat designs right now.
    vipersmack[QUOTED] likes this.
  15. Oct 30, 2018 at 9:39 AM
    vipersmack
    2018 TRD Off-Road
    I will definitely get some pictures posted up for you. Bummer on the hat, but I would be interested on the new ones for sure. Quick question is there room for the security nuts you guys sell on ditch brackets? (Space between the hood and bolt enough to get the nut fastened).
  16. Oct 30, 2018 at 11:45 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Hm, I did not try. I have a set of the LKZ in the garage, let me look later today. I do know that you would have to install the lights onto the brackets first (the security socket is way too big to fit in between hood and bracket) AND THEN install the entire assembly onto the truck. That's why I didn't do it... I didn't have an extra pair of hands to help hold stuff and it would have been more difficult to do by myself while filming lol.
  17. Oct 30, 2018 at 12:22 PM
    vipersmack
    2018 TRD Off-Road
    That is what I was worried about, it would be hard to install them in that situation. I'll probably hold off on them unless I can figure something out. If you happen to try them out though keep me posted.
  18. Nov 5, 2018 at 2:13 PM
    vipersmack
    2018 TRD Off-Road
    20181105_164424.jpg 20181105_164433.jpg@Taylor@KC HiLiTES
    Finally got them on today. Waiting for dark for final adjustments.
  19. Nov 5, 2018 at 6:00 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Damn, that looks good! I love how it matches with all of the other black accents on your OR truck. Let me know how the aiming goes and if you need any help.
  20. Nov 6, 2018 at 7:13 AM
    vipersmack
    2018 TRD Off-Road
    Thanks man, I thought it turned out really good as well. Aiming was pretty easy I used my local walmart wall at night to adjust them lol. I do have a question though, the lights came with two round black pieces of plastic, any idea what they are for?15415171345165995612444437740036.jpg
