KC HiLITES gurus- dim driving light question
Discussion in 'Lighting' started by dwcfastrice, Oct 29, 2022.
  1. Oct 29, 2022 at 6:01 AM
    dwcfastrice
    dwcfastrice [OP] Bacon makes everything better.
    David
    Southeast PA
    2007 Silver Mica DCSB
    So far: 2.5" Icon Lift, Steel Front bumper, steel rear bumper, Cali Raised Bed Stiffener, 12Volt.Solutions remote start, Stereo upgrade, A Pillar Ram Mounts, BAMF Behind the grill light mount with Sylania 20" bar; KB Voodoo Max 22" Rack, CVT Awning, Decked drawer system, pod lights
    Greetings all!
    Looking for some advice from driving light experts out there.
    I have some KC HiLites driving lights mounted on my bumper and one of them has gone significantly dimmer than the other.
    You can see here the one on the passenger side is throwing off more light.
    Here are some closeups of the one that is dimmer.
    It looks like a ton of moisture has gotten into this light.
    Question is, would taking off the front cover and drying out the light help?
    What would you all suggest for sealing up the light again.
    Has anyone replaced the LED bulbs inside of them? What's involved? Where would I source parts, etc.?
    Thanks in Advance.
    Dave
  2. Oct 30, 2022 at 5:55 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Drying it out might help, but it's probably not going to fix it completely. The driver circuitry may be damaged by water intrusion. Silicone is not a good idea to reseal it, as RTV offgasses as it cures and will leave a layer of film on the inside of the lens and the reflectors. The reflectors may also be damaged/corroded by the water. Try Gently blowing them off, and you may be able to clean off any visible residue by carefully sloshing the reflector around in a bowl of warm distilled water and simple green. If the driver board is damaged not much you can do unless you're handy at reflow soldering.
    Too Stroked and dwcfastrice[OP] like this.
  3. Oct 30, 2022 at 6:03 AM
    dwcfastrice
    David
    Southeast PA
    Oy..... I'll crack them open today and see what i can do. Both of them have water in them.
    Thank you so much for the advice.
    Sounds like I might be looking at a set of new ones in the near future.... :rolleyes::rolleyes::rolleyes::rolleyes:
  4. Oct 30, 2022 at 7:04 AM
    SYTY
    SYTY Member
    Contact KC and see if they are still under warranty
  5. Oct 30, 2022 at 8:16 AM
    dwcfastrice
    David
    Southeast PA
    Thought about that but these are pretty old.
  6. Oct 30, 2022 at 8:26 AM
    Twins09
    Twins09 Well-Known Member
    Dave
    Dutchess County, NY
    2019 MGM TRD Sport, 02 WS6 vert
    Vent visor, hood protector, door sill protector, next up eibach,SCS Ray 10s to be installed next week...
    Cant hurt to ask worst they say is no.. They are a good company thats been around a while.
  7. Oct 30, 2022 at 9:24 AM
    dwcfastrice
    David
    Southeast PA
    true
  8. Oct 31, 2022 at 6:06 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I think you're going to find that they're toast and even drying them out and resealing them isn't going to help. If they're out of warranty, you might want to look at the thread below before you decide what to replace them with. Although it mainly deals with fog pattern pods, I think you'll find that the driving beam versions of the same pods end up about them same way. Lots of good choices out there.
    The LED SAE J583 Fog Pod & Fog Light Review | Tacoma World
    Toy_Runner likes this.
