KC HiLiTES LED Equipped Tacoma 4WD
Discussion in 'KC HiLiTES' started by KC HiLiTES, Apr 24, 2014.
  1. Jan 24, 2016 at 3:48 PM
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    Any KC led fog lights?
  2. Aug 13, 2016 at 10:43 AM
    pogoface801
    pogoface801 Well-Known Member
    Sam
    Salt Lake City
    2009 Toyota Tacoma TRD
    How did those tires fit with your set up? I would like to get the same tired but I worry about rubbing. Did you do any cutting or wheel spacers?
  3. Aug 15, 2016 at 11:31 AM
    KC HiLiTES
    KC HiLiTES [OP] Manufacture Representative Vendor
    Running the extended travel coilovers and uni-ball upper control arms we have had no issue. We did some minor plastic trimming that you can not even tell was done, but other than that it is great. Daily driver, mildly offroaded, no rubbing at all. The correct offset wheel is important, ICON has their own now that really put the wheel where it needs to be for the best clearance possible.
    Reach out to @icon_rep, I'm sure they can give you even further information in further detail!
  4. Aug 16, 2016 at 7:10 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    X2. What did you guys give up on this???
  5. Sep 16, 2016 at 3:21 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Aren't they on the KC website?
  6. Sep 16, 2016 at 3:46 PM
    lpfe42
    Kenny
    20 DCSB CEMENT
    5100/887 Icon uca
  7. Sep 16, 2016 at 4:18 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    OK cool. Thanks. They don't fit my truck though
  8. Oct 12, 2016 at 6:47 PM
    Tacomalx4x4
    Tacomalx4x4 Well-Known Member
    Corey
    Wv
    07 6spd DCSB silver
    3inch ultimate, straight exhaust, XD's 285's, grill, lights, fog mod, jvc unit. Rear cam mod, pioneer 3ways
    Do they fit 05-11?
  9. Oct 13, 2016 at 8:31 PM
    lpfe42
    Kenny
    20 DCSB CEMENT
    5100/887 Icon uca
    12-15
  10. Oct 13, 2016 at 8:32 PM
    lpfe42
    Kenny
    20 DCSB CEMENT
    5100/887 Icon uca
    They do need to be at least 20watts not a bright as I was hoping for:(
  11. Nov 4, 2020 at 6:28 PM
    Roscopico
    Roscopico Well-Known Member
    Noel
    Augusta GA
    Toyota Tacoma SR5 2018
    lift 3" in the Front and 2" in the rear, topper, 20in rinms
    any one can tell me where can i go to see how you can connect kc hillites cyclone lights from the bed of the 2018 tacoma to the cargo switch.......
