KD MAX Tune?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Big Mort, Jul 25, 2022.
  1. Jul 25, 2022 at 6:09 PM
    Big Mort
    Big Mort [OP] Member
    Craig
    Tacoma long bed
    4" lift, larger rims and tires
    Anyone know of any professional tuners in NE Ohio. I have checked and don't see any very close.
  2. Jul 25, 2022 at 6:24 PM
    JCGarfunkel
    JCGarfunkel Well-Known Member
    Peter
    VA
    2016 Silver Tacoma TRD OR DCLB
    Check this guy out:
    Bulldog Tuning Group - Jim
    Jim Miracle
    740-361-1974 Serving central Ohio from Interstate 70 North and across to Indiana and Pennsylvania North.
    PapaRee likes this.
  3. Oct 4, 2022 at 7:39 PM
    Zarksniper
    Zarksniper Member
    TRD Pro
    Westcott lift, 33' Wildpeaks, Body Armor Bumper, Rough Country light bar
    Jim did my tune last night. Great guy and the difference is night and day from stock.
    One suggestion for the KDMax guys. You should really consider having all 3 maps available once installed.
    What I mean is...On my 10th Gen Civis Si, I was able to have access to all 3 maps (TSP Stage1) via steering wheel selection. Press and hold the Cruise "Cancel" button for 3 secs, the tach would point to 1000rpm(indicating map#1) then just select which map you want....toggle up to 2(map#2) or 3(map#3). Press and hold the Cancel button again....done! Then we could select the map best for the driving conditions we are planning that day.
    ClassyTacos likes this.
  4. Oct 4, 2022 at 7:54 PM
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    The software developer VF Tuner didn’t have that functionality available for custom tuners to play with at this time. You can have two throttle settings by having “Lite”, “Normal” throttle as your daily driver choice and then ETC set with “Sport” (other tunes have different names) for when you tow or feel wild.
    Zarksniper likes this.
  5. Oct 4, 2022 at 8:01 PM
    Zarksniper
    Zarksniper Member
    TRD Pro
    That's a great idea. So you are saying, If I have the Normal tune installed, the ECT can actuate Sport mode tune?
    I did get Sport installed and it's probably going to be a little "Spicy" when I'm offroad. Going to try it out this weekend.
  6. Oct 5, 2022 at 5:25 AM
    JAL
    Mississippi
    Yes, if you choose “Normal” as your throttle choice the ETC button is already set to “Sport” plus a noche or two more. That way you have two throttle settings.
