KDMAX-PRO or Shift Sense Pro - V2
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Burnsie, May 6, 2022.
  1. May 6, 2022 at 2:55 PM
    Burnsie
    Burnsie [OP] New Member
    2016 TRD Off Road
    Recently picked up a 2016 Tacoma TRD Off-Road and it took only a few days to get pissed about the well documented crappy shifting. I immediately dove into the forums and discovered there a many possible fixes/improvements. Two that I have on my short list are the KDMAX - Pro tune or the plug-n-play Shift Sense Pro device. Both solutions have a lot of positive reviews and happy customers.
    Please let me hear your experience with these products - Pros & Cons
    My list.
    KDMAX-Pro: Pros - permanent solution, proven. Cons - $400-500, find and travel to a tuner.
    Shift Sense Pro: Pros - $175, solid reviews. Cons - more wires/equip. to stuff under the dash.
  2. May 6, 2022 at 3:00 PM
    Tacospike
    Two Trucks
    Welcome
    I think most people will say tune. I don’t have either though, never had shifting issues with my truck
  3. May 6, 2022 at 4:02 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I have the Shift Sense.
    Things i like:
    -it's a predictable speed based shift
    -doesn't have to have a lot of 'load' to keep it at or above 1,500 rpm
    -flex lock is not present from S1-S3
    Frito likes this.
  4. May 6, 2022 at 4:31 PM
    Lcfj60
    Lcfj60 Active Member
    2022 Tacoma AC MT 4x4 TRD Sport
    I vote neither. Change the diff gears to 4.30 or lower for a true fix. I made my way through the shift sense, then tuned, then regeared. I wasn't happy until the gears.
    2018 TRD OR
    Frito likes this.
  5. May 6, 2022 at 4:41 PM
    The_vue's
    The_vue's Well-Known Member
    18 cement
    I went back to stock tune. It is hella smooth and mpg back up in the 20's. If vf tuner allow me to add what shift sense has I'd do that instead of a custom tune. In that case if you ever want a tune u could get one.
  6. May 6, 2022 at 4:51 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You can absolutely do that with vF tuner. All you need to change are the throttle settings and leave everything else alone.
    The_vue's[QUOTED] likes this.
  7. May 6, 2022 at 7:14 PM
    Frito
    Frito Well-Known Member
    The "cons" you mentioned re: KD MAX is the price to play and worth the price of admission IMHO. I loaded the tune myself.
    The "Cons" you mentioned re: SSP are non-issues.
    Easy peasy clean install and it does a good job if you are on a budget.
    Sure, I would love to re-gear, just not in my budget and the thought of having to do this just pisses me off more..... :annoyed:
    I waded into the waters with SSP straight away and was happy for a time.
    Since then, I have been through OV Tune and and currently running KDMAX with an eye on the Overlander reviews.
    More low end TQ sounds good to me. I don't need more top end as I don't drive fast.
    My SSP could be had at a mutually agreeable price. Ping me if you are interested.
    Good luck. Apart from re-gearing this should be a pretty easy decision for anyone if they intend to keep the truck and want to like it more.
  8. May 6, 2022 at 7:39 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Dude kdmax pro for sure if that's what tune your looking at . That shift sense is garbage. All It does is mess with throttle sensitivity. The tune will do that and more. Shifting will be quietly improved and you can choose what throttle sensitivity fits you . Might take some time for muscle memory on the ole foot but you will adjust . Overall the one time tune and done will definitely be more beneficial to you .
  9. May 6, 2022 at 7:50 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage, 2017 GSXR 750, 2019 Honda monkey , 2023 klx300 , 2013 prerunner TRD off-road
    Buy a vf tuner and tune yourself. It’s actually about the same price as getting someone to tune for you THEN you can try different throttle sensitivity with an easy flash of the computer. It’s so simple even a 54 year old dude like me can do it.
    Frito likes this.
  10. May 6, 2022 at 7:57 PM
    Frito
    Are you confusing SSP with Pedal Commander.... or am I ? :notsure:
    SSP does extend shift points or holds gears longer depending on how you want to look at it, but ......
    I think it is Pedal Commander that gives you a more sensitive throttle and a sense or feeling of more power (?)
    https://www.dz-custom-innovations.com/products/shiftsense-pro
    https://pedalcommander.com/
  11. May 6, 2022 at 8:07 PM
    Frito
    NO affiliation, just spotted this in the for sale section, thought I'd pass it on..... :thumbsup:
    https://www.tacomaworld.com/threads/ovtune-vftuner-obdii-cable-kit.764140/
  12. May 6, 2022 at 8:12 PM
    oldtoyman
    Kevin
    North of Seattle
    These are vin locked so I would assume you would have to purchase credits and a license. If it were me I would just buy a new one ( latest addition) and then you know for sure it’s vin locked to your truck and will work. JMO
