KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Dec 25, 2021 at 10:52 AM
    #4021
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Are there any tuners in Wichita, KS? (Asking for a friend)
  2. Dec 25, 2021 at 11:35 AM
    #4022
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I'm with you. Been considering the KDMax Pro for weeks but can't get past the "what happens if I have a major drivetrain issue under warranty and they start poking around the ECM" issue. I had also read that the adaptive cruise control doesn't work if you get a tune? Is that correct?
  3. Dec 25, 2021 at 11:46 AM
    #4023
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    I can tell you first hand I just had a major repair done under warranty and no questions ever came up about the tune.
    Had a check engine light for a popped code that wound up being a bad head seal on the #5 cylinder.
    A compression test and exhaust leak test was performed and after confirmation a complete head replacement and #5 exhaust valves.
    And yes the Adaptive cruise still work after the tune.
    Cruise just works better in normal mode though.
    Wixo, Phich, MiTacoTRD and 4 others like this.
  4. Dec 25, 2021 at 11:47 AM
    #4024
    termaesam
    termaesam Active Member
    Adaptive cruise works as it did without the tune.
    TWTaco, PapaRee[OP] and FL_TRD Sport like this.
  5. Dec 25, 2021 at 11:52 AM
    #4025
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Thanks. That's exactly the kind of thing I was afraid of since I had the exact same thing happen at 200 miles on a 2018 Jeep I had, except is was the #1 cylinder.
    PapaRee[OP] and TWTaco like this.
  6. Dec 25, 2021 at 11:53 AM
    #4026
    TWTaco
    TWTaco Well-Known Member
    Dave
    MERRY CHRISTMAS!!! TO ALL!!!
    :santa::santa2::santa::santa2:
    kibo, PapaRee[OP] and Chunk like this.
  7. Dec 25, 2021 at 1:11 PM
    #4027
    EvoRescueVehicle
    EvoRescueVehicle Active Member
    Eric
    Vegas, NV
    2020 Cement Tacoma TRD Off Road 4x4 M/T
    20211220_150701.jpg Wanted to post up another MT review since I know a majority of the manual driver's were also interested in the new KD Max Pro Tune:
    My truck is a manual 2020 TRD 4x4 Off Road that I picked up back in October of 2020. The factory tune/throttle response was atrocious and kind of a big let down when I first picked up the truck and it actually almost got me in a t-bone collision as I was trying to make a left turn through an intersection during a flashing yellow arrow that would've normally not been an issue with a cable driven throttle pedal. My other vehicle is a 2006 Mitsubishi Evo 9 with an "old school" cable actuated throttle and that thing is super sensitive to inputs and what I've become accustomed to driving so driving the truck completely threw me off, haha.
    I researched into what would be possible in getting that fixed and I came across the OV Tune 2.0 files. Those were solid in helping to wake up the truck and finally I was able to enjoy driving it! I didn't have any major issues with the OVT 2.0 but came across this thread about the KD Max 7.0 tune and figured I'd give that a shot and it was a noticeable improvement over the OVT 2.0 tunes to my surprise. Then fast forward a couple months and the announcement of the KD Max Pro came out and I wanted to see what improvements were made with this revision. It wasn't a huge difference difference like it was from OVT 2.0 to KD7.0 but it was noticeable in the fact that it felt a little bit more refined than KD7.0.
    I installed the KD Max Pro tune earlier this month right before I took off on a road trip from Indianapolis to Vegas for the holidays. I immediately noticed that the slight part-throttle jerkiness of the KD7.0 would sometimes have in parking lots in 1st gear was gone so that was a welcome improvement. During the trip across country I used the standard cruise control and it worked just fine but sometimes would feel like it reverted back to the OEM map but I just figured it was still in its learning phase and didn't pay much mind to it. Every time after refueling (huge fan of the 87-93 octane learning capability over having to switch/load in separate regular or premium maps), I would make sure to give it a good 2nd or 3rd gear full throttle pull through the on ramp to get up to the speed of traffic and help with the relearning since I decided to clear the values before the tune. The power delivery from 2,000RPM all the way to about 7,000RPM is great and that weird "VTEC" power increase that used to be there right around 3,000-3,500 is completely gone. Instead it's a solid torquey start down low and then it carries power all the way to red line. City driving is great with the near instantaneous throttle response and toque delivery and the revised fuel/timing/etc makes the truck feel way quicker than it did coming from the factory. While out here in Vegas I've also managed to try out the tune on the trails. There was one section I hit where I used 4LO and the response and power is as great as it is with normal 2WD street driving but I'm new to taking a truck through trails so I can't really get into detail about how it would be different from the factory tune/OVT 2.0/KD Max 7.0/etc.
    Overall, the KD Max Pro tune has been fantastic and I haven't noticed anything with it that has been an issue, major or minor and I thoroughly enjoy driving the truck every time I fire it up. If you're going from the factory tune to the KD Max Pro, it's going to be a world of difference in how the truck behaves and you'll appreciate the work the KD team have put into improving our vehicles!
  8. Dec 25, 2021 at 1:16 PM
    #4028
    TWTaco
    Dave
    Thanks Eric appreciate your review! Glad you are enjoying the Pro tune!!
    MERRY CHRISTMAS!! :santa::santa2::santa::santa2:
  9. Dec 25, 2021 at 2:39 PM
    #4029
    tclavell
    Troy
    Phoenix, AZ
    G70
    Merry Christmas @PapaRee and @TWTaco
    Thank you for what you do for this community!
    :fistbump:
    TWTaco and PapaRee[OP] like this.
  10. Dec 25, 2021 at 2:43 PM
    #4030
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Thanks Troy! Same to you and your family!
    tclavell[QUOTED] likes this.
  11. Dec 25, 2021 at 3:10 PM
    #4031
    TWTaco
    Dave
    Thank you Troy. Appreciate all your support!
    Merry Christmas!! :santa: :santa2:
  12. Dec 25, 2021 at 3:29 PM
    #4032
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Don’t trust him! His a Trojan hworse!
    tclavell and TWTaco[QUOTED] like this.
  13. Dec 25, 2021 at 3:36 PM
    #4033
    tclavell
    Troy
    Phoenix, AZ
    G70
    TWTaco, PapaRee[OP] and Chunk[QUOTED] like this.
  14. Dec 25, 2021 at 5:18 PM
    #4034
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    The Dealership had my truck for a month trying to get the AC to stop dripping inside the cab. They had to drive it extensively and I bet they really enjoyed the KDMAX tune it has on it. Never a mention of any issues with the ECU. I had the same fear to lose my warranty but they can't tell via the computer screen the tune has been done. My month-long repair proves it.
  15. Dec 25, 2021 at 6:02 PM
    #4035
    JAL
    Mississippi
    I’ll add they had my truck for 31 days also. Now did they test anything that was ECU connected, don’t know? But they had time to if they had doubts.
  16. Dec 26, 2021 at 2:36 AM
    #4036
    Montana_Actual
    Montana_Actual ;)
  17. Dec 27, 2021 at 8:55 AM
    #4037
    chrisc33
    chrisc33 Member
    Austin
    7BB069A5-A0C5-4068-92E7-95E775F88596.jpg Kdmaxx Pro tune review/comparison
    I have a 2021 Trd pro I picked up brand new in march and since then have put about 19k miles on it. The truck has a wescott lift and 285/75/16 geolanders tires. At around 6k miles I had the truck Ovtuned on 91 octane tune.
    First off I would like to thank Chris P located in San Antonio for the tune, amazing service, very informative and smooth process.
    The first 2k miles after I bought the truck I noticed something just didn’t feel right. The engine and trans felt unresponsive and unpredictable. Driving around town was fine but on the hwy the truck would gear hunt on steep inclines like crazy. Seriously thought something was wrong with the truck until I googled and seen this is a common issue. After installing a lift and tires, the problems I had with the truck were only amplified so I looked for tuning solutions. Went with Ovtuned on 91 octane map. The tune was Ok. Wasn’t thrilled but felt improvement in responsiveness around town. I felt an increase in throttle sensitivity coming from a stop and the truck held gears longer on the hwy but the gear hunting was still an issue. Ran OVtune for about 10k miles and decided to hit up chris and give kdmaxx tune a try.
    First drive I notice the truck wants to jump out and go. You can have the throttle sensitivity decreased but I dont mind a touchy throttle. I immediately noticed the truck drove so much better than ovtune and stock its not even close to a comparison. Before, if I needed to increase speed on the hwy, the truck would always drop to 4th to gain speed, Now it just holds 5th most of the time and accelerates. Acceleration is more linear. Before the tune, the truck would race to 6th where it had no torque, then you would have to bury your foot to get it to downshift to keep up with traffic. The truck now holds those lower gears keeping the truck in the powerband.
    MPG: Right after tune I drove about 150 miles hwy and got about 19mpg going 70-75. 3000 miles later I can squeeze about 17mpg if I keep it below 70.
    Cruise Control: Adaptive Cruise control is still useless it still gearhunts like crazy on the slightest incline or overpass on the hwy.
    Regular Cruise control holds 5th better. There are still issues with it though. For example if the truck drops 1mph for more than a second the truck downshift to 4th instead of giving the truck time to catch up while still in 5th gear. I think if we give the truck a 5mph window before downshifting this will help alot.
    Gear lock: Cool feature, fun offroad. Main reason I wanted it was to lock it in 5th and set the Cruise control to keep it from hunting but the cc overrides the gear lock and forces a downshift when going up an incline so my plan was foiled lol. Gearlock really exposes just how little torque these motors have. Foot to the floor the truck just wont budge going 70 into a good headwind or incline lol but its cool to have. Ive yet to tow with so we will see how it goes.
    Overall a massive improvement over stock and Ovtune. Highly recommend. Thanks
  18. Dec 27, 2021 at 9:56 AM
    #4038
    Underdonk
    Underdonk Well-Known Member
    Thank you kindly sir or ma'am!
    PapaRee[OP] likes this.
  19. Dec 27, 2021 at 9:59 AM
    #4039
    Underdonk
    Interesting, so when you say a little more throttle do you mean throttle response? Also interesting is has separate maps, but makes sense for towing. Thank you!
  20. Dec 27, 2021 at 10:04 AM
    #4040
    PapaRee
    Kreg
    ECT has a little more throttle response, yes.
    In VFtuner you can adjust throttle response--percent of throttle for the angle of the pedal.
