KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Feb 15, 2022 at 8:37 PM
    #4761
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    Get a wide band sensor if you're serious about monitoring the values =)
    Speaking for myself, no... unless that one member of the meetup organized the whole thing and brought all the customers in and I didn't have to lift a finger (then a fair discount would be considered). Usually tune meetups are still consisting of X number of individuals that I had to gather on my own accord.
  2. Feb 15, 2022 at 8:44 PM
    #4762
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    We use OBDFusion to monitor. Use Toyota PIDs. A/F actual.
    We monitor everything—coolant temps, trans temps, timing, load, rpm, gear, torque converter, misfires, A/F, KCLV, Knock F/B, etc.
  3. Feb 15, 2022 at 9:22 PM
    #4763
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Good info thanks. I know in aircraft engines EGT and better yet if the engine has it CHT are monitored closely, and running too lean can cause the cylinder temperatures to get too high, affecting engine reliability and could cause a failure in some cases. Unfortunately it doesn’t appear we even have EGT. Is oil temperature available as a signal? That would be better than nothing although you do have coolant temp for overall engine temperature it’s not as good as something monitoring temp closer to the cylinder/heads. I realize you have AFR but the proof in the pudding is cylinder and head temps.
    I gotta get OBDFusion one of these days, I like to know as much as I can about my truck.
  4. Feb 15, 2022 at 9:28 PM
    #4764
    PapaRee
    Kreg
    Yes, oil temp is an option in OBD fusion. I have it on my main dashboard.
  5. Feb 15, 2022 at 9:31 PM
    #4765
    davidstacoma
    David
    NC
    Very good. Now that’s an awesome screen setup I want that lol! Appreciate the response, will be considering the new 2.7L automatic tune that’s come out one of these days, after my warranty’s out lol.
  6. Feb 15, 2022 at 9:43 PM
    #4766
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I used to fly...and monitor cats temps. All good there too.
  7. Feb 15, 2022 at 9:44 PM
    #4767
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
  8. Feb 15, 2022 at 9:50 PM
    #4768
    davidstacoma
    David
    NC
    Turboprop?
  9. Feb 15, 2022 at 9:56 PM
    #4769
    Vlady
    Issy, WA
    I wish..
    Cessna 172, 152.
    Learned alot about mixture and EGT monitoring.
    Fun times.
    Set the app, get a good baseline based on you normal DD. Then you can compare stock to any tunes and spot any deviation, abnormalities, etc.
  10. Feb 15, 2022 at 10:14 PM
    #4770
    davidstacoma
    David
    NC
    Brother was a pilot as well, Cessna 172.
    Just looking around, I think my 2.7L doesn’t have an oil temperature sensor, can’t find one on Toyota parts sites or on TW search. Does have the oil pressure switch lol.
    Good idea about getting baseline data before getting a tune.
    Update: This thread shows a page from the manual indicating that engine oil temperature is “estimated”. Must be derived from coolant temp and other parameters. That’s a bummer.
    https://www.tacomaworld.com/threads...es-the-ecu-calculate-it.750722/#post-26741041
    shotgunbilly420 likes this.
  11. Feb 16, 2022 at 7:19 AM
    #4771
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
  12. Feb 16, 2022 at 10:47 AM
    #4772
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    Been running the KDMax tunes for a while now and absolutely love the way it transforms the truck. @Uscgamecock7 recently drove down to Charleston to update my tune for the new 35s and I couldn’t be happier.
    If you’re close to SC I highly recommend reaching out to Nick to get the KDMax tune. Night and day difference!
  13. Feb 16, 2022 at 11:07 AM
    #4773
    PapaRee
    Kreg
    Damn, that is one good looking truck!
    Glad you are enjoying the KDMax-Pro tune! It is a must have for heavy, lifted, big tire, modded trucks.
  14. Feb 16, 2022 at 11:28 AM
    #4774
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    Absolutely! Typically the first thing I recommend to people when they ask what's the best bang for your buck. I've ran every edition of the KDMax tune now and have to say the Pro feels excellent.
  15. Feb 16, 2022 at 12:19 PM
    #4775
    TWTaco
    TWTaco Well-Known Member
    Dave
    Chad @Beersduo came by to get upgraded from KDMAX6.0 to KDMAX-Pro. He was tuned last July was completely happy on 6.0 but starting reading all the great reviews for the Pro tune! We updated him to the Pro tune with Sport throttle. After his test drive he said it really has smoother response and the shifting was even smoother!!
    Look forward to hearing how you are enjoying the Pro tune. :D :thumbsup:
    PapaRee[OP] likes this.
  16. Feb 16, 2022 at 12:23 PM
    #4776
    greyboxer
    greyboxer Well-Known Member
    Pittsburgh
    2022 TRD Sport Army Green, 6MT
    Any risks to getting tuned this weekend despite only having 250 miles on the Odo? :D
  17. Feb 16, 2022 at 12:30 PM
    #4777
    TWTaco
    Dave
    I have tuned tuned several with less then 100 miles on them. No issue at all. You may have a problem with wiping that "SMILE" off your face!! :D:D:D
  18. Feb 16, 2022 at 12:30 PM
    #4778
    greyboxer
    Pittsburgh
    This Sunday in Monroeville (about 30 minutes East of Pittsburgh) theres a KD Max protune meet from 1-4pm. See you there.
    PapaRee[OP] and TWTaco like this.
  19. Feb 16, 2022 at 12:31 PM
    #4779
    KH86
    KH86 Well-Known Member
    Kris
    Santa Cruz, CA
    2021 Voodoo Blue DCSB OR, KDMAX Pro Sport
    TRD Pro lift
    Shout out to Pismo Beach 3G Tacos!!
  20. Feb 16, 2022 at 12:32 PM
    #4780
    TWTaco
    Dave
    Look forward to reading your review! :thumbsup:
    greyboxer[QUOTED] likes this.
