KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Feb 17, 2022 at 4:04 PM
    #4801
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Regular Cruise Control-Yes
    Adaptive Cruise Control-No (not an option at the present in VFTuner)
    TWTaco likes this.
  2. Feb 17, 2022 at 4:50 PM
    #4802
    TWTaco
    TWTaco Well-Known Member
    Dave
    Brett @bcmbcmbcm Came in today with his Super clean Barcelona red 2022 OR MT. Got him tuned up with KDMAX-Pro with Sport throttle + AGM settings for his dual AGM battery setup. Also got the seat belt chimes turned off!!
    It was good meeting you Brett. Looking forward to hear how your enjoying the Pro tune!!
    :burnrubber:
    OZ TRD, tclavell and PapaRee[OP] like this.
  3. Feb 17, 2022 at 5:30 PM
    #4803
    C4vettrn
    C4vettrn Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    School me on the improved shifting. Are you able to program the trans valve body to give firmer shifts ( higher fluid pressure ) similar to the older days using shift kits in the valve body for less clutch slipping ? Also any dyno results on low octane ? Thanks!
  4. Feb 17, 2022 at 5:41 PM
    #4804
    PapaRee
    Kreg
    The shifting smoothness is controlled with torque maps in Vftuner. You can make them firmer or softer. There is not currently any settings for valve body or fluid pressure changes in Vftuner.
    The torque maps really do make a difference. The shifting transition is very smooth.
    We did do some dyno testing on earlier tunes with regular octane, but have not on our latest. It was a little better on Premium fuel, but I can't remember exactly how much--maybe 10hp
    tclavell and TWTaco like this.
  5. Feb 17, 2022 at 6:02 PM
    #4805
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    Yes, very first thing I noticed with the tune.
    PapaRee[OP] and TWTaco like this.
  6. Feb 17, 2022 at 7:41 PM
    #4806
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    Dyno numbers are great but where this tune shines is in real world part-throttle drivability. That’s what you will notice right away. Absolutely worth it.
    su.b.rat and PapaRee[OP] like this.
  7. Feb 17, 2022 at 7:52 PM
    #4807
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    I’d like to order a flash device and tune my truck but is it noticeable on a M/T truck? Heck I’m not even sure if the previous owner tuned it, I’m not dissatisfied with whatever is in there now but more is better, right?
  8. Feb 17, 2022 at 8:15 PM
    #4808
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Is it possible the tune would go back to stock after a dead battery and replacing it ?
    shotgunbilly420 likes this.
  9. Feb 17, 2022 at 8:42 PM
    #4809
    PapaRee
    Kreg
    No, a dead battery will not remove the tune. Only doing a TSB update or flashing another tune to replace it.
    TWTaco likes this.
  10. Feb 17, 2022 at 8:45 PM
    #4810
    PapaRee
    Kreg
    Once you get your software and cable, PM me and try it out. You won't be disappointed. The KDMax-Pro M/T tune is a significant improvement (unless you bought the truck with it already on it.)
    c_walters[QUOTED] and TWTaco like this.
  11. Feb 17, 2022 at 8:49 PM
    #4811
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Tuned a lady with a 2020 6m/t and she was blown away with how much smoother and how much more pull each gear had. You will not be disappointed
  12. Feb 18, 2022 at 6:12 AM
    #4812
    MrWrestlingII
    MrWrestlingII Well-Known Member
    I’ve run all kdmax versions for 11,000 miles and can honestly say the tunes are transformational when compared to the absolutely horrible stock tune.
    KDmax pro is refined and I notice no lack of torque in gears 1-4, although it’s no rocket ship.
    In gears 5-6 the lack of torque is improved, but still noticeable. In 5-6, when driving into a wind, I enable ECT and this helps quite a bit.
    The bottom line is this motor does not generate enough torque under 2k rpm and the tune can only do so much.
  13. Feb 18, 2022 at 6:43 AM
    #4813
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Yeah no tune is going to change the mechanical aspects of the engine. These motors are built to rev and running higher rpms when more overall power is needed doesn't hurt anything (other than fuel economy). That's why they guzzle gas when towing. I still wish they'd turn loose a small turbo diesel in the US in them, but it will never happen because of the EPA's stupidity. Could probably get 50mpg and tow a house...
  14. Feb 18, 2022 at 8:33 AM
    #4814
    KH86
    KH86 Well-Known Member
    Kris
    Santa Cruz, CA
    2021 Voodoo Blue DCSB OR, KDMAX Pro Sport
    TRD Pro lift
    Spots still available for the Fresno tune event tomorrow!!
  15. Feb 18, 2022 at 6:25 PM
    #4815
    PapaRee
    Kreg
    Tuned Turner from SSO @Luxxiy today. 2018--upgraded to 04a61 then KDMax-Pro.
    He was smiling from ear to ear! Sent me an awesome video of his first impressions. Hopefully he will post it up.
    TacoManOne, KH86 and TWTaco like this.
  16. Feb 18, 2022 at 6:50 PM
    #4816
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m half an hour away if you’d like to me flash the tune on your truck versus buying everything to DIY. Every MT I’ve done really wakes them up.
  17. Feb 19, 2022 at 12:10 AM
    #4817
    MrArtixx
    MrArtixx Well-Known Member
    2022 Lunar Rock OR Manual
    Ill be there myself!
    greyboxer[QUOTED] and TWTaco like this.
  18. Feb 19, 2022 at 8:22 AM
    #4818
    PapaRee
    Kreg
    When you are ready, PM me and I will get you your files.
    kibo, japjoe7, TWTaco and 1 other person like this.
  19. Feb 19, 2022 at 9:12 AM
    #4819
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Did anyone go from KDmax 6.0 to pro? looking if its something that im interested in doing?
  20. Feb 19, 2022 at 9:44 AM
    #4820
    TWTaco
    Dave
    We have many reviews from customers who have upgraded from 6.0 to the Pro tune. I think you will be very happy if you do the upgrade to Pro. :thumbsup:
