KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Mar 11, 2022 at 6:37 PM
    #5021
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I've had the opportunity to setup KDMAX Pro for several 2022's this past week. Every owner was extremely pleased with their initial test drive and first few days of driving. I look forward to getting their longer term review for posting but it's crystal clear as we all know that 2016 - 2022 AT or MT all greatly benefit from this tune and what KDMAX Pro updates are providing. From stock trucks to setup overlanders, the folks I have worked with are getting the right fit!
    Thanks @PapaRee and @TWTaco for the continued team partnership, efforts, and delivering every-single-time!
    GPatriot, Cazman13, Phich and 3 others like this.
  2. Mar 11, 2022 at 8:24 PM
    #5022
    Czeleznick
    Czeleznick Well-Known Member
    Philadelphia Area
    2022 White OR DCSB
    Eibach Pro Stage 1, Bronze SCS F5’s on Falken Wildpeaks
    I have a 22 Off-road that I am so disappointed with so far because of the horrible way it drives and the gear shifting or lack their off. I am trying to schedule with someone now to get the KDMax Pro in hopes that it will turn the truck into the way I know it should be! With all the positive reviews I really have high hopes and I’m keeping my fingers crossed.
  3. Mar 11, 2022 at 8:41 PM
    #5023
    wahoobie
    chris
    Suffolk, VA
    I am confident in the outcome, let us know if you have any questions along the way!
  4. Mar 12, 2022 at 9:14 PM
    #5024
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    You’re not going to be applying a lot of pressure to the brake, just enough when you
    You’re not going to apply a lot of pressure to the brake, just enough so that when you’re coming off a rock, ledge, ect… that you’re not slamming down onto your skids or rockers. Same with crawling up, it’s just a slight about of pressure to be smooth and consistent going through difficult lines. If you don’t left foot brake caliper your reaction time to get your right foot onto the brake is a lot of times enough to slam down hard and cause more damage. You definitely don’t want to be applying a lot of force. I’ve never had a light go on and I’ve done some pretty decent trails. For sure trails you could not get a stock Tacoma through. But you also have a manual so you’re feet are going to more around a lot more than in my truck haha. I know because I also have a stock shift samurai that I only use for rock crawling.
  5. Mar 12, 2022 at 11:13 PM
    #5025
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    5000+ pages, I didn't read them all so cut me some slack if this is already been covered.
    So I just switched from another popular tune to KDMPro on thursday, same tuner, and I had a couple of issues today while out putting on miles to relearn:
    The first I was out running around town. I was stopped at a light, light turns green I start rolling out mild mannered, 1-2 shift is smooth 2-3 shift is smooth I'm still on the gas to get up to 50mph limit but still in 3rd when suddenly vroom rpms jump way up, 5k+ and I lose power, whoa wtf, it was as if It went into neutral so I get off the gas let rpms drop to about 1k get back on the gas and get up to speed without issue. This only happened the one time, I couldn't replicate it during the other 80 miles I drove.
    The second, while getting onto the highway, get up to highway speed no problem but truck wouldn't shift out of 4th, this I could replicate. This happens while being moderately aggressive getting up to speed, on two occasions I was pushing 80 & would not upshift from 4, take foot off the gas and the engine would brake I had to use sport mode to force 5th gear. This first happened after I'd put 50ish miles on so I had gotten onto the highway without issue a couple of other times, again after the 1st time I could replicate this.
    Lastly, not sure if its a prob but I very rarely saw 6th gear. Even cruising at 75-80mph I seldom saw 6th gear, TC 1/2 lock/full lock but no 6th.
    So not sure whats up hoping for some input.
    TIA!
    @PapaRee
    @TWTaco
    shotgunbilly420 likes this.
  6. Mar 13, 2022 at 5:56 AM
    #5026
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm pretty sure they are gonna recommend a reflash . This can fix these issues most of the time.
  7. Mar 13, 2022 at 6:28 AM
    #5027
    MrWrestlingII
    MrWrestlingII Well-Known Member
    Exactly the way I felt about my new 21 OR a year ago. Without the tune I would have sold the truck by now.
  8. Mar 13, 2022 at 7:05 AM
    #5028
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    I'm experiencing the same issue on the top end myself. Doesn't seem to do it if keeping a light throttle, but moderate throttle merging into traffic of the hi way it does it. Running the Pro sport tune for roughly 3k+ miles
  9. Mar 13, 2022 at 7:15 AM
    #5029
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    A reflash won't do anything. The data does not get corrupt during the flash process.
  10. Mar 13, 2022 at 7:32 AM
    #5030
    shotgunbilly420
    It's not that it be corrupt .I'm sure @PapaRee would agree to try a reflash before going any further. I've had issues where old habits of Toyota tune would mess with shifting or laggy throttle response. Reflashes have most of the time fixed any issues with tunes. This is my experience . I'm a tune hoe
    oldtoyman and wiljayhi like this.
  11. Mar 13, 2022 at 7:33 AM
    #5031
    shotgunbilly420
    I change tunes like my everyday socks lol
    Chunk likes this.
  12. Mar 13, 2022 at 7:46 AM
    #5032
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    A reflash of the same tune will change absolutely nothing though...
    2015 TRD Sport likes this.
  13. Mar 13, 2022 at 7:54 AM
    #5033
    K9chita
    K9chita Well-Known Member
    Jeff
    21037
    2022 TRD Sport Tacoma
    Bilstein 5100’s PolyPerformance UCA Prinsu Cab and Cap Rack Falken Wildpeak AT3W LEER 100XL
    Is there any options in Maryland? I see @wahoobie in Suffolk, VA - 4 hour drive. TIA if I missed the answer in here.
  14. Mar 13, 2022 at 8:04 AM
    #5034
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    I agree with that. I tried reflashing mine twice with the same tune, and issue is still there
    ktbell444[QUOTED] likes this.
  15. Mar 13, 2022 at 9:37 AM
    #5035
    rgvaggie11
    rgvaggie11 Well-Known Member
    2017 Quicksand TRD 4x4
    A little early, but I just got the Pro Sport Tune yesterday and immediately felt like a rocket! A few issues I noticed, ans wanted to see if it's just me, but speeding up slowly from zero, its jerks pretty noticeable when touching gas pedal, then I feel it noticeably Jerky if acceleration is very slow. For example, slowly driving in parking lot. Is this a characteristic of the "sport's tune? I let tuner know, he said he can swap to the ''city" tune if it just feels too aggressive. Highway speeds feel good, anything above 30 mph feels good. But in city and stop and go traffic it's pretty jarring.
  16. Mar 13, 2022 at 9:37 AM
    #5036
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    We have had a few trucks that had weird shifting after a flash on the same tune that another truck did not. This has not happened often. So the first step was to try re flashing. It has worked for me and and it has worked for others. The only explanation that I can think of is that the flash is incomplete.
    I know re flashing the same tune does not seem like it should do anything, but it has fixed the few trucks that had this.
    I will work with you and your tuner to make sure this is what you need.
    The only other time that I have seen weird things after a flash is when a reset of the ECU and trans is done. After a reset, you will see weird shifting and some irratic thottle.
    Let me know if I can help.
    Anderson5290, TWTaco and 4x4spiegel like this.
  17. Mar 13, 2022 at 9:43 AM
    #5037
    PapaRee
    Kreg
    I am going to PM you to figure yours out.
  18. Mar 13, 2022 at 9:45 AM
    #5038
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    Had the same issues with mine on KDM Pro. It would get hung up in 4th gear on a regular basis and I would have to switch it over to S mode to manually shift it back up to 5th. I also rarely saw 6th gear on the freeway unless it was downhill or perfectly flat, and even then the slightest throttle input would cause it to downshift back to 5th. Unfortunately a reflash didn't solve any of the issues for me.
  19. Mar 13, 2022 at 9:49 AM
    #5039
    PapaRee
    Kreg
    The Sport tune is not for everyone. You can test drive all three throttle choices to see the difference.
  20. Mar 13, 2022 at 10:04 AM
    #5040
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    Contact Dave @dave5623 , he’s located in Maryland.
    K9chita[QUOTED] likes this.
