KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Apr 5, 2022 at 5:17 PM
    #5241
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Sounds like you will love the KDMax-Pro+ and if it needs to be adjusted, we can make it hold gears longer if you want.
    JDSmith, Otterstuff and TWTaco like this.
  2. Apr 5, 2022 at 5:20 PM
    #5242
    grooverider
    grooverider Well-Known Member
    So we can hard-set shift points and that will survive any of the learning behaviour?
    shotgunbilly420 likes this.
  3. Apr 5, 2022 at 5:25 PM
    #5243
    PapaRee
    Kreg
    As far as I know. Mine still shifts at the same shift points where I set them. I have never had any bad learning behavior. My tune has always stayed the same and learned in a good way.
    JDSmith likes this.
  4. Apr 5, 2022 at 5:27 PM
    #5244
    grooverider
    Ok, interesting
    I've used the following tunes, where the shift points immediately degrade:
    OVtune
    Overlander
    Can anyone else comment on this behaviour?
    Within 2 day of getting the tune, the shift points are terrible: like 4th@25mph (the truck just LOVES to cruise at 1000rpm which I hate).
  5. Apr 5, 2022 at 5:36 PM
    #5245
    PapaRee
    Kreg
    Do you have VFtuner to flash your own truck?
    If so, PM me and we can let you try it out on your truck.
    JDSmith likes this.
  6. Apr 5, 2022 at 5:41 PM
    #5246
    grooverider
    I do not, but I may consider getting it so I can resolve this issue.
    PapaRee[QUOTED][OP] likes this.
  7. Apr 5, 2022 at 5:43 PM
    #5247
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I’ve been running a KDMax tune (6 & Pro) for about a year. The shift points are still where @PapaRee put them. I told him what speeds I wanted the shifts to happen and it all worked out. Still going strong a year later.
    wahoobie, JDSmith, japjoe7 and 4 others like this.
  8. Apr 5, 2022 at 5:44 PM
    #5248
    grooverider
    Ok, amazing!
    I wonder why with these other two tunes I have this issue?
  9. Apr 5, 2022 at 5:56 PM
    #5249
    wiljayhi
    Jim
    3G, Tuned
    They might be set to shift at too low a rpm. Mat himself once said that he couldn’t make his tune to shift at the correct rpm because too many thought it might be too high. KDMax Pro is just about perfect in that regard.
  10. Apr 5, 2022 at 7:00 PM
    #5250
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    I’m so glad I decided to pop on TW for the first time in awhile, I just flashed the new PLUS tune with Lite tip in and holy shit it’s amazing! I can’t express how important this tune is for the Tacoma, if you want one end-all-be-all upgrade, this is the mod to have! Thanks @PapaRee for the amazing work you do!
  11. Apr 5, 2022 at 7:08 PM
    #5251
    BraveNewTaco
    BraveNewTaco Member
    2020 Cement Tacoma TRD Off-Road
    First day on TW and thankfully got turned onto the KD Max Pro tune for my [new to me] 2020 4x4 TRD OR!
    Located in Orlando and wanted to see if @HCFR TACO22 or @G8R_Taco would be able to help me out with a tune and direction on which "flavor" to pursue.
    JDSmith, xLOGREx, TacoManOne and 2 others like this.
  12. Apr 5, 2022 at 7:12 PM
    #5252
    PapaRee
    Kreg
    Oh yeah! I am sure they will. Send them a text or PM
  13. Apr 5, 2022 at 7:46 PM
    #5253
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I've had my KD Max Pro + normal tune for a couple of weeks now and my shift points have not changed since getting it. If anything it is only shifting smoother during learning. It shifts at different speeds now, which I like. On stock tune I was getting 3 shifts to third before 30 mph and rpms were dropping to 1000. That is entirely too low. Now I don't hit 3rd till 35 or 36 mph and rpms only drop to 1300 or so leaving you with more power after shifting. I haven't even tried the ECT or S Mode yet as I haven't needed them. The other real noticeable difference is that I don't have to wait on a downshift after making a turn. The tranny and throttle stay connected for a smooth downshift, if needed. Many times RPMs stay high enough that a downshift isn't needed. I believe it is the transmission changes combined with eliminating the throttle lag that make the tune successful. It is not much money to give it a try.
  14. Apr 5, 2022 at 8:15 PM
    #5254
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    So i got tuned in September of last year. Is there an updated tune out now?
  15. Apr 5, 2022 at 8:19 PM
    #5255
    TWTaco
    TWTaco Well-Known Member
    Dave
    Yes we released KDMAX Pro November 2021.
  16. Apr 5, 2022 at 8:22 PM
    #5256
    TWTaco
    Dave
    I will be In San Diego this Saturday. Let me know if you want to meet up.
  17. Apr 5, 2022 at 8:25 PM
    #5257
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    PM inbound....:burnrubber:
  18. Apr 5, 2022 at 9:04 PM
    #5258
    TWTaco
    Dave
    I will be in San Diego this Saturday National City area early from 8am to 10am.
    If anyone is interested PM me for a meetup. I can also make stops on my way back into Orange County anywhere off the 5frwy.
    :cheers:
  19. Apr 6, 2022 at 5:55 AM
    #5259
    sebooher95
    sebooher95 Well-Known Member
    Mississippi
    ‘18 MGM Sport 6MT 4x4 KDMax6.0 XT
    KDMax6.0 XT Tuned
    Any tuners near Memphis? Looking to upgrade to Pro from 6.0 XT
    Otterstuff likes this.
  20. Apr 6, 2022 at 7:06 AM
    #5260
    TWTaco
    Dave
    Wouter covers the Memphis area give him a PM he will take good care of you.
    Tennessee:
    - Nashville @dutchcontractor (Wouter)
