KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Nov 16, 2022 at 8:00 AM
    #7121
    98tacojunky
    98tacojunky Well-Known Member
    Upstate NY
    2019 TRDOR double cab
    You’ve ran the ott tune as well correct? I believe I’ve seen you comment on other threads you were using the ott. If so, how does the kdmax pro and ott compare? Which is better in your opinion and why?
    MN Rainier, TWTaco and drizzoh like this.
  2. Nov 16, 2022 at 8:12 AM
    #7122
    DrkYota
    DrkYota Member
    Mark
    Ohio
    2020 Black Tacoma TRD Sport DCLB
    @shotgunbilly420 Wanted to follow up on this a see if you’re still enjoying the lite throttle? Getting the tune done today and trying to decide between normal or go with lite. Thanks!
    Otterstuff and TWTaco like this.
  3. Nov 16, 2022 at 8:21 AM
    #7123
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I also like the lite throttle.
  4. Nov 16, 2022 at 8:23 AM
    #7124
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    I've always been a "lite" guy. Lite throttle control shines best in crawling/offroad situations.
  5. Nov 16, 2022 at 8:46 AM
    #7125
    James2406
    James2406 Well-Known Member
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    @FL_TRD Sport got me fixed up with the updated 9.0 tune and I'm loving it! Thanks!
    TVphotog97, JDSmith, JAL and 5 others like this.
  6. Nov 16, 2022 at 10:00 AM
    #7126
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Glad you are enjoying the tune. Was a pleasure to meet a steely-eyed missile man!
  7. Nov 16, 2022 at 10:01 AM
    #7127
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    With @shotgunbilly420 post, I have decided to flash mine from std normal throttle map, to lite. just flashed it a second ago. will need a few days to feel it out, and report back but, I am on it! Ski
  8. Nov 16, 2022 at 12:04 PM
    #7128
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    I also have switched to Lite throttle for the last half tank and now on a second full tank. I’m normally a “Normal” throttle guy and have talked about what I think are benefits to it. With Normal it’s lite pressure to get it to tip in and very light pressure to maintain. I’ve alway felt this contributed to better mileage as it required less skinny pedal modulation.
    My first half tank on Lite I saw a slight drop in mileage but to be fair part of that tank was against a strong north wind moving South as I headed to North MS over rolling hills.
    After fill up and a strong northerly tailwind as I returned South I had as high as 23.9 mpg readings and finished the 111 miles after fill-up at 22.7 mpg. As I’m nearing the halfway mark of this tank I’m currently reading 21.7 mpg. That’s with a lot of stop and go traffic in town.
    So we’ll see as time go on. It definitely is smoother at tip in!
    updated: I didn’t mention this is on a lifted truck with additional 300# of sliders, lift components weight difference, winch and winch bumper. I’m still at the moment on stock tires and wheel but will have news ones on by early next week. I’m trying to stay as close to stock tire and wheel weight but going up to 33”.
  9. Nov 16, 2022 at 12:13 PM
    #7129
    ivan5105
    ivan5105 Member
    ivan
    San Juan, PR
    2016 Off Road Tacoma 4x4
    KDMax tuning,BP51,TRD intake and exh.,5.29
    I love the lite throttle(wife tip in)!!!!
  10. Nov 16, 2022 at 1:58 PM
    #7130
    termaesam
    termaesam Active Member
    Lite as well here...very smooth from start to stop
  11. Nov 16, 2022 at 3:24 PM
    #7131
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Negative just lite throttle . I know some run wife tip in
    Otterstuff likes this.
  12. Nov 16, 2022 at 3:28 PM
    #7132
    shotgunbilly420
    What do you normally get for mileage on a half tank of gas? Are you on regular or premium gasoline?
  13. Nov 16, 2022 at 4:04 PM
    #7133
    DrkYota
    DrkYota Member
    Mark
    Ohio
    Hey all! So just got updated to the 9.0 by @bulldogppas here in Ohio and man this tune is so much better than the last one. I went with lite throttle since I’ve seen a few people saying that’s what the went with and liked it and I definitely recommend going with lite or trying it. Feels so smooth starting from stops and the power is there if you need to get up and go. Also the gear shifting is incredibly smooth and holds the gears extremely well. Very impressed so far with this tune but I’ll have to test it more over the weeks and see how it is but first impression it feels amazing. Thanks @PapaRee & @TWTaco for making this amazing tune and tweaking it to make it better and better. And thanks again to @bulldogppas for tuning my truck for me! Super awesome guy!
    Otterstuff, Scotty33, JDSmith and 5 others like this.
  14. Nov 16, 2022 at 5:12 PM
    #7134
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Sounds like when I upgrade to 9.0 I need to switch to lite. Not sure I understand how lite would get less mpg than normal.
  15. Nov 16, 2022 at 5:57 PM
    #7135
    PhogDog
    20 MGM Sport
    I did not get any better mpg's on normal
  16. Nov 16, 2022 at 5:57 PM
    #7136
    shotgunbilly420
    It doesn't get worse and I've only heard one member say that on here . I'm getting almost summer time mpgs in our colder months
    Edit: ok 2 people
  17. Nov 16, 2022 at 9:42 PM
    #7137
    JAL
    Mississippi
    @shotgunbilly420 normally I don’t judge a tank at the halfway mark as my experience is it normally fall off near or just after the last quarter mark. I was only stating what it was currently showing at the half tank mark.
    On my way to church tonight I noticed some discrepancies in the dash cluster gauge that read “Tank Average mileage” and the head unit mileage reading?
    The cluster gauge was showing 21.5 mpg and head unit 19.5 3 mpg difference?
    In the pass theses have been relatively close, within .2 or so. Not off like this. So I’m not currently sure what my actual mileage is. I normally do a hand calculation and it is also normally .3 - .5 less the gauge readings.
  18. Nov 17, 2022 at 2:41 AM
    #7138
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Quad State Tune will be in Scranton, Pa. this Saturday 1:00 pm. Hit me up if you’re interested.
    Kevin
    Otterstuff and PapaRee[OP] like this.
  19. Nov 17, 2022 at 3:43 AM
    #7139
    shotgunbilly420
    I was just curious I get about 200 to 225 miles a half tank kdmaxed . If I try I can squeeze 250 miles on a half tank .
  20. Nov 17, 2022 at 5:54 AM
    #7140
    ivan5105
    ivan5105 Member
    ivan
    San Juan, PR
    Yes,I used to run wife tip in but now I run the lite.
