KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. Mar 15, 2023 at 4:40 PM
    #7741
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Make sure you're getting the jlt oil catch can too
    Dfpftw likes this.
  2. Mar 15, 2023 at 5:39 PM
    #7742
    TacoTwoDay
    TacoTwoDay Well-Known Member
    David
    Western PA
    2021 Tacoma TRD OR
    I (admittedly) haven't searched for test yet, but do either of you have links to info on the differences these make? I'm genuinely curious.
  3. Mar 15, 2023 at 5:47 PM
    #7743
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    OTT thread has some info on it.
    disk_55FL and TacoTwoDay[QUOTED] like this.
  4. Mar 15, 2023 at 6:13 PM
    #7744
    shotgunbilly420
    Afe throttle body spacer I think I paid $150
  5. Mar 15, 2023 at 6:14 PM
    #7745
    shotgunbilly420
    No links of test results, maybe someone else does on here . My ole butt Dyno and math calculated mpgs tell me it works
  6. Mar 15, 2023 at 7:38 PM
    #7746
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    But there’s no way, no Dyno’s no way that tunes that good…or any other product. You can’t feel improvements don’t you know!
    https://rumble.com/embed/v2aqdxu/?pub=k4cbd
    K9chita, C41n, TacoTunesday and 3 others like this.
  7. Mar 15, 2023 at 9:52 PM
    #7747
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Montana Tune Day Coming Up!
  8. Mar 16, 2023 at 4:48 PM
    #7748
    shotgunbilly420
    Well it's starting to warm up here in Washington State fuel mileage on tune is increasing power is increasing. Just Wanted report back results with warmer temps above 55°F
  9. Mar 16, 2023 at 5:03 PM
    #7749
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    I got the oil catch can too. Yes sir a Tune With TB spacer is bananas
  10. Mar 17, 2023 at 1:49 AM
    #7750
    ZippyBasher
    ZippyBasher Member
    Sean
    2022 TRD OR 4x4 SB
    SO after about 2000 miles on the newest tune 9.0 with Sport throttle I think I should chime in. 2022 TRD OR DBC 4X4
    Do I like the Tune - Yes
    Would I recommend - Yes , read below:
    Throttle Preference - On Sport, great driving and VERY responsive on road. Off-road, it is too responsive. The dip in is so slight that hitting any bumps moves my foot, ever so slightly pressing the pedal and it becomes a bit jerky.
    ECT - have not used since going from Normal to Sport! Counter intuitive I think as it essentially deletes the function, Sport on or off. Maybe I will try this tomorrow around town and on freeway and see any difference in my commute. (should be same?)
    MPG - Hard to judge with less than 12 months on the motor. Fuel, Outside Temps and less than ideal Conditions lately affect this too much to tell. Averaging 18 at best Mixed Freeway/City (Stock gear and tire/wheel)
    Shifting - it still down shifts on the highway, it does hold gears longer but dont expect to it climb hills at 75 in 6th. Still wants 4th to be happy at 3k rpm. 4.88 Gears are incoming to fix this correctly. The shifting is butter smooth though, so while it does shift a lot less it does it flawlessly and not hard or sloppy in the least
    Other add ons - Custom exhaust 2.5" through and HPS intake tube for reference.
    I think I will hit up TWTaco and see if I can change back to Normal or Normal-Lite and Sport ECT for a comparison. ( I had normal on the Pro TQ tune) I think will be necessary once swapped out to 4.88 gearing, since the dip it would be more pronounced IMO.
    I do have a TB Spacer incoming in 3 days to test; will run a tank through, compare and then see about a reflash to Normal. Its a custom machined 1" thick piece so We shall see how that helps. If it gets "More Responsive" as it claims, its gonna drive just thinking of the throttle!
    That being said, it really does change the truck and how it accelerates the most. Try it, if you dont like it, go back to stock. $.02
    StupaDazHo, TWTaco and PapaRee[OP] like this.
  11. Mar 17, 2023 at 3:12 AM
    #7751
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    I run lite it’s fine. My tuner recommended lite
    shotgunbilly420 and MiTacoTRD like this.
  12. Mar 17, 2023 at 3:47 AM
    #7752
    shotgunbilly420
    I'm running lite . I've tried all the settings and lite seems to have the all around best behavior, my opinion.
    MiTacoTRD, TWTaco and PapaRee[OP] like this.
  13. Mar 17, 2023 at 3:58 AM
    #7753
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I also prefer the Lite, it's perfect for me.
  14. Mar 17, 2023 at 9:07 AM
    #7754
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    I switched to Lite and really like it
  15. Mar 17, 2023 at 9:28 AM
    #7755
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    I’ve had Lite for some time. I’ve tried all three (I flashed myself). Make sure to change your “vote” on top of the page…
    shotgunbilly420 and Dfpftw like this.
  16. Mar 17, 2023 at 9:28 AM
    #7756
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Another vote for lite from someone that has ran tunes all the way back to beta OV Tunes in late ‘17 …not that there were options back then, but I’ve ran a lot of tunes.
  17. Mar 17, 2023 at 3:54 PM
    #7757
    Maxx
    Maxx Well-Known Member
    I tried them all and so far Sport on 87 yields the best fuel economy for me. 91 feels great but I tend to use more throttle than needed causing my fuel economy to drop pretty good. Getting 17-18 MPG on 35’s and stock gears with about 400# of added weight.
    Sna, Gmak621, shotgunbilly420 and 4 others like this.
  18. Mar 17, 2023 at 7:20 PM
    #7758
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    @PapaRee, @TWTaco
    I have a 2015 Tacoma with a 6speed manual and have been considering a tune to help it out a bit but I don't see many 2nd gen Tacomas with a tune. My truck is heavily modified (not engine or exhaust) and am wondering what a tune would do to make it more driveable? Is the rev hang removed totally or can it just be reduced? Among many other mods (including a snorkel), I have 33" tires and the truck has been re-geared to help with the larger tires and additional weight. I'm not looking for optimal performance and only run 87 fuel. Please let me know what improvements I can expect from one of your tunes.
  19. Mar 17, 2023 at 7:43 PM
    #7759
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Smoother shifting, less rev hang, aggressive linear throttle—improved drivability. You won’t be disappointed!
  20. Mar 17, 2023 at 8:53 PM
    #7760
    JAL
    Mississippi
    Every 2nd Gen I’ve tuned the customers we’re happy. The one MT was so happy afterwards nothing would do until I drove his truck to see for myself the improvement (I hadn’t drove a MT Tacoma until then).
    shotgunbilly420 and Sna like this.
