KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. May 1, 2021 at 5:49 AM
    #1181
    mhornco
    mhornco Well-Known Member
    Three questions on KDMAX6.0 LT for @PapaRee and @TWTaco. First off the tune is great. It shifts really well and has increased my long trip fuel economy close to 1mpg. I wanted to wait until I ran it for a while before I had any comments. I did a long trip Colorado to Arizona this past week. With 10-11 hours in the truck each way and a lot of different terrain I had a great opportunity to try a bunch of different things. I have two questions from all this. Both relate to shifting. I sent them this as a conversation as well, but am never sure I get that right. Was also hoping to hear the broader group as a whole
    The first is the truck tends to delay wanting to go back to fifth after a long pull in fourth. Normally if I accelerate to pass the truck hits fourth if need be, then bumps back up through fifth and sixth. However, if I have a long grade where it is in fourth for several minutes (Verde Valley up to Flagstaff), you really have to work at it to get the truck to jump up to fifth. It will get there, but similar to pre-tune, I crest a hill, am losing elevation, but have to lose a lot of speed lifting my foot off the gas to get the truck to upshift. Again, this only happens on long pulls, regular in and out of fourth and fifth for short duration is really good.
    The second question concerns cruise control. Again, CC is about 100 times better than stock so maybe my question is moot. If the truck really needs it will drop to fourth on a hill. However, it can at times not want to go back to fifth and stays in fourth for quite a while once I hit level. Here is where it gets interesting though. The first time it did this I decided to give it a little gas as I was getting ready to disable cruise. Foot just taps gas pedal and truck instantly upshifts to fifth. Thought maybe it was just ready to shift anyway so I tried this a few more times. Every time it worked. When it appears CC wants to hang in fourth for a bit a gentle throttle tap produces an immediate upshift. The only thing I can think that might cause this is as soon as I hit the throttle, I am bypassing the CC logic and am assuming the shift logic programming for the gas pedal is different than that of the cruise.
    Hopefully someone has a couple bits of insight here. These are not really issues, but I was just wondering if others have noticed this.
    One final question is the SLT version doing any shift logic changes other than throttle tip in. I like the way LT shifts, but tend to spin tires a lot in the dirt from a takeoff. I imagine in winter this might create a few surprises.
  2. May 1, 2021 at 6:23 AM
    #1182
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    My experience. To make it shift to 5th in an incline after going 4th gear to pass someone, lighten your foot on the pedal and it will go to 5th. At keast mine does . I have the premium performance tune kdmax 6.0. pedal was touchy at first but my foot learned to adapt and now after 1400 miles it's perfect.
    Edit. My bad, you're talking of cruise control. Wrong answer.
    rdvm1972 likes this.
  3. May 1, 2021 at 9:15 AM
    #1183
    TK11
    TK11 Well-Known Member
    Tom
    N. CA
    2019 TRD OR MT
    Bilstein 6112 / 5160, 275/70/17 BFG KO2, Caliraised Sliders, SSO bumper, Warn winch
    Thanks for posting your experience. I've been looking for more manual transmission reviews. Just a matter of time until I get this tune!
    I can definitely relate to the throttle issue on downshifts. Prepare for downshift, clutch in, shift while simultaneously mashing the throttle to the floor while hoping the revs will be high enough to match the lower gear. Not ideal.
  4. May 1, 2021 at 9:33 AM
    #1184
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I responded to your PM.
  5. May 1, 2021 at 10:50 AM
    #1185
    Dr. Cornwallis
    Dr. Cornwallis Well-Known Member
    Flarrrrrrrida
    2016 Super White TRD Offroad 4x4 AC
    Going off the dyno numbers in another thread and my limited ability to perform maths, this tune has these trucks making over 300hp at the crank?
  6. May 1, 2021 at 10:57 AM
    #1186
    PapaRee
    Kreg
    I have never Dyno'd my truck nor was I at the Dyno shops when they were done.
    But, I think that is about right even on stock.
    The tune is about Performance and Drivability.
    The difference can be felt on the road driving. The best way to test the tune is to drive it!
  7. May 1, 2021 at 11:16 AM
    #1187
    Dr. Cornwallis
    Flarrrrrrrida
    I agree. If I get bored I may have mine dyno’ed as I’m just curious. Going off of the the fact that these engines are nudging at 300hp from from the factory, make over 300hp (NA) in other applications and the way my truck feels before and after the tune it feels like it’s at or above 300.
    Is there an option if I get super charged? If I hang on to the truck long enough, when it came time for an engine rebuild I was going to super charge it. 33’s + 5.29’s + SC + tune = rocket ship.
    reymataco and rdvm1972 like this.
  8. May 1, 2021 at 11:29 AM
    #1188
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    You got that right, :woot:
    You betcha, :thumbsup:
    Tell me about it, :amen:
    Oh yeah, oh yeah, oh yeah .... :canada:
  9. May 1, 2021 at 11:48 AM
    #1189
    Patton250
    Patton250 Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    So I just had @HCFR TACO22 do my tune in the Tampa area. And Victor is a hell of a nice guy. He went way out of his way to accommodate me and to meet me when and where I needed him to be. I have very limited time because of my travels and Saturday was the only time I could do it. Thank you so much Victor. I really appreciate it. The tuning/ flash went smooth. I’ll report back in a week or so of how I like it but the test drive was awesome.
  10. May 1, 2021 at 1:16 PM
    #1190
    PapaRee
    Kreg
    I don't have a SuperCharger tune. And their tunes are understandably locked. So, you would have to use their tune.
  11. May 1, 2021 at 2:39 PM
    #1191
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    we need custom tunes for super charger lol
    reymataco and Shellshock like this.
  12. May 1, 2021 at 10:02 PM
    #1192
    HCFR TACO22
    HCFR TACO22 Well-Known Member
    Vic
    Tampa,FL
    2019 Tacoma SR5 on 33's DCSB
    KDMax Performance Tune
    @Patton250 thank you sir it was a pleasure meeting you and helping you enjoy driving your truck again! Awesome looking truck too!! If you have any questions or concerns don't hesitate to get a hold of me.
  13. May 2, 2021 at 7:39 AM
    #1193
    DesertDuck2004
    DesertDuck2004 Well-Known Member
    AZ
    2020 TRD OR DCLB - MGM-KDMax'd
    Exact thing was happening to me on a drive from Phoenix to Yuma yesterday.
  14. May 2, 2021 at 7:48 AM
    #1194
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I've noticed this since stock 2.0, except it happens to get "stuck" in 5th when it should upshift to 6th. Little tap on the throttle finally crests me over the upshift point and I'm back in business.
  15. May 2, 2021 at 8:22 AM
    #1195
    wiljayhi
    Jim
    3G, Tuned
    Is it a “tap” or a light press?
  16. May 2, 2021 at 8:23 AM
    #1196
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Just enough to start increasing RPM's is usually all I need. I can't speak for the KDMax tune, haven't ran it yet.
  17. May 2, 2021 at 8:34 AM
    #1197
    wiljayhi
    Jim
    3G, Tuned
    Even with KDM6 there’s lots going when getting back into 6 from 5. Headwind, slight incline, won’t do it without a bit of a press and back off (normal I think).
    CC is a different animal and I haven’t tested that yet.
  18. May 2, 2021 at 6:34 PM
    #1198
    PapaRee
    Kreg
    Rainoffire likes this.
  19. May 2, 2021 at 6:49 PM
    #1199
    PapaRee
    Kreg
    There is a list and a map in the first post.
  20. May 2, 2021 at 6:51 PM
    #1200
    wiljayhi
    Jim
    3G, Tuned
    I’m not having any “issues” with KDM6 but was wondering if reseting the learned values would also reset the gas mileage computations to be the most favourable. I definitely don’t want to reset AT.
    @PapaRee ?
