KDMax-Pro Tuning--NOW YotaWerx Tuning
Discussion in 'Performance and Tuning' started by PapaRee, Mar 22, 2021.
  1. May 9, 2021 at 4:38 AM
    #1301
    J_Hacker
    J_Hacker Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    Thanks for the reply! I’ll see what other people say and then I’ll get back with you.
    wahoobie[QUOTED] likes this.
  2. May 9, 2021 at 5:00 AM
    #1302
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    kibo and J_Hacker[QUOTED] like this.
  3. May 9, 2021 at 5:14 AM
    #1303
    J_Hacker
    Thank you for that. The overcooling of the engine sounds right. Which would explain why it won’t reach temperature. Sounds like I will be replacing a thermostat
    wahoobie[QUOTED] and trdquoc like this.
  4. May 9, 2021 at 9:11 AM
    #1304
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    I’m interested in this as well, I’ve been running OVTune 2.0 Premium/base for the last year on 91 octane available in most places in KS. I found it just felt smoother than 87 did but so much has changed in the last year, including prices so once I’m able to flash again I’m very much considering going back to 87. But if 91 is genuinely good for some more ponies and is noticeable I’d keep it as is on 91. I know my LS1 pretty much has to have 91 but this engine having been designed for 87 or 91 depending in the model it’s thrown in is so much more flexible.
    I suppose I can just flash each and try back to back and see if the butt dyno can tell any difference. Though I’m expecting going from 91 OVTune 2.0 to 87 KDMax would still be beneficial with the adjustments done on this tune vs OV, particularly in the throttle department.
    And correct me if I’m wrong, but this is an OLE (Octane LEarning) tune right? So if I throw 87 tune on there but still have a full tank of 91 it should adjust over time to learn up to 91, yet have the ability to learn back down to 87 based on the sensors? I know with 91 set as the base point, it really doesn’t learn back down very well from what I’ve heard, best keeping it drinking 91.
  5. May 9, 2021 at 9:17 AM
    #1305
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I think the tunes are learning, but an 87 tune will not *learn up to 93*; ie the tables won't take full advantage of the possible timing available to a full 93 tune. So the final performance of an 87 tune will never peak and match a 93 tune even if you feed it 93 for extended time. Hopefully others can comment on the down learning options of the 93 tunes. I don't think they will fully *learn down* to an 87 diet, and you might be at risk for some poor performance. Hopefully the gurus will add their knowledge too.
  6. May 9, 2021 at 9:26 AM
    #1306
    BrettsMac08
    Kansas
    Thanks for that! That does sound like what I’ve heard Mat say in the past year or so regarding OLE. It’s probably good for 87 (perhaps 85 at high altitudes) up through 89. Premium tune more 90-93 though 91 is the only thing around here, never seen 93 at a station in Kansas before.
    I’ll just start at 87 with KDMax and 99% chance I’ll be more than pleased over the current 2.0 Premium base I’m on, and save some cash on gas. I got a Sams Club membership pretty much exclusively because it makes 91 about the same price discounted as standard 87 at other stations, but it also means I have to travel to that station every week to fill up, lol.
    Haven’t done much traveling in 2020/2021 but plan to very soon so I think 87 tune will make the most sense for me. I was just curious if there was much of a difference. I know there might be some 87 vs 91 dyno comparison but if it’s just a few hp and a few lb-ft, then, meh. :)
  7. May 9, 2021 at 9:34 AM
    #1307
    PapaRee
    PapaRee [OP] Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Right on @RushT
    The tunes are all Octane learning. But the Regular tune has a range of learning lower than the Premium tune.
    The computer will adjust to what is in your tank.
    The only catch is that the Premium tune cannot adjust down to the regular 87 octane.
    Here is what the ranges are
    Regular octane learning range-- 85-90
    Premium octane learning range-- 91-95
    So if you are running Premium on a Regular tune (which is what I do), You will get benefits up to 90 octane--which is an improvement.
    But if you want the FULL potential of the tune you need to run the Premium tune and Premium gas.
    I am running 93 octane on the regular tune. It learns up to 90. I have ran the 93 octane on the premium tune. The difference is unnoticeable to me.
  8. May 9, 2021 at 9:50 AM
    #1308
    BrettsMac08
    Kansas
    Shoot, that’s a post that could be pinned/linked to right there. Looks like my recall wasn’t too far off then for the octane range.
    Sounds like I’ll be best off doing the same, and running 91 on the regular tune and then not having to fear throwing in 87 or even 85 in Colorado when traveling. Currently having to use 87 or heaven forbid actual 91 way up there in the mountains is crazy expensive vs down here in flatland. I’m talking 91 here ($2.72) is cheaper than 85 is there ($2.85 in Loveland, and more the further up you go). Not to mention their 91 is $3.44.
    Thanks for the info! Now to patiently wait and check my inbox every day. :fingerscrossed:
    TacoNesian and PapaRee[OP] like this.
  9. May 9, 2021 at 9:50 AM
    #1309
    Theovan22
    Theovan22 New Member
    Brad
    2018 Tacoma 4x4 Sport
    I got the KDmax 6.0 Regular LT (Light tip in) from @Uscgamecock7 yesterday & it is the best money I've spent on my truck by far!! Very smooth shifts, no more RPM flaring, great throttle response. Glad we went with the LT. Before the tune it felt like my brakes were partially locked up & the truck was fighting to go. Now it feels like it wants to go & stay going with very little throttle to it!! Love it man! Btw my mpg from what little I drove seems to have gotten better. Win win. Thanks again Nick & @PapaRee …Brad
  10. May 9, 2021 at 11:10 AM
    #1310
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    Enjoy it while you can I just paid 4.39 for 87 here in LA
  11. May 9, 2021 at 11:16 AM
    #1311
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Remember the last time I did that in Burbank for my 2500 and the next 2 days and went and bought a cobalt after the tank was drained! Good times!
  12. May 9, 2021 at 11:18 AM
    #1312
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Thanks brother! Appreciate the good review. I agree, KDMax definitely knocks it out of the park. Cheers and thanks for your service!
  13. May 9, 2021 at 12:01 PM
    #1313
    PapaRee
    Kreg
    Happy Mother's Day to all!
    Hope everyone has a great day. I am thankful for my Mom and Stepmom.
    They raised me to be the man that I am today and taught me:
    -Treat people like you would want to be treated!
    -Good things happen to good people
    -Kill your enemies with kindness
    As an ER nurse for 20+ years, I live by these words.
    I feel like God has blessed me, and my family.
    I am thankful for all the great people on this forum.
    khite100, ayalas1978, umcece and 23 others like this.
  14. May 9, 2021 at 12:30 PM
    #1314
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    I like to run non-ethanol in my equipment, and the places I travel to out of sate most frequently offer 91 non-ethanol as well as premium. If you look some other applications for our engine, you will see that it is used in the Lexus RC, ES, and other models. They are all tuned for 91/93 and report better performance numbers than the Tacoma, again having the same engine.
    My first Tacoma was a 2005 2wd prerunner TRD OR. The manual stated the following: "1GR- FE engine—Select Octane Rating 87 (Research Octane Number 91) orhigher. For improved vehicle performance, the use of premium unleaded gasoline with an Octane Rating of 91(Research Octane Number 96) or higher is recommended."
    So we know these engines are capable of running better using higher octane fuel, but the ECU needs the tune for it to take advantage of the benefits. Now what situations would you be in that you would want peak capabilities out of the engine? Towing and spirited highway driving is what comes to mind for me. If you are going to beat on the thing, higher octane is probably the way to go (if you have the tune for it).
    No doubt Toyota has been neutering their engines to meet emissions and fuel economy standards as required by the U.S. government.
    I have not put many miles on the LT 91/93 tune yet, but I can already tell you that there is no way in hell I am going back to stock. Ever. This is how this truck should drive from the factory. Period, end of story. Screw Toyota and the government for manipulating and neutering a product we pay thousands of dollars for. Thank god for this tune. I have fallen back in love with the Tacoma again.
    A more comprehensive review will follow, but that will have to wait until I put more miles on and get some off road time in.
  15. May 9, 2021 at 12:38 PM
    #1315
    DB88
    DB88 Member
    2021 TRD PRO
    Any tuners on Vancouver Island ..
  16. May 9, 2021 at 2:07 PM
    #1316
    Chunk
    2016 DCSB OR
    Baby Ruth
    Is anyone on Vancouver island?!
  17. May 9, 2021 at 3:08 PM
    #1317
    906UP
    906UP Well-Known Member
    U.P. of Michigan
    18 SR5 4WD, 17 Tundra CM-TRD
    I tuned the KDMaxx a few months ago. I just did a trip from the U.P. of Michigan to Greenville, S.C. and back for work, 2022 miles. I ran the expressway, kept the cruise between 72-80 mph. Tank MPG ranged from 23.7 to 24.7 for the trip. My MPG has improved since the tune, I don't think it's the tune itself but how much smoother the engine runs & transmission shifts that drives the improvement.
    Edit, forgot to mention. 2018 SR5, 4x4, access cab, fiberglass cap. Stock tires, no lift.
  18. May 10, 2021 at 1:59 AM
    #1318
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    wifeytip installed today:thumbsup:can't wait to try it out!:mudding:
    TacoNesian likes this.
  19. May 10, 2021 at 6:21 AM
    #1319
    ezatnova
    ezatnova Artax
    West Chester, PA
    21 DC TRD OR - Voodoo
    Wildpeak 265/75/16, Headstrong Progressive AAL, 5100's w Emu 885s
    Finished a trip up to Pine Creek PA and back, about 350 - 400 miles round trip with all of the side excursions. Main trip consisted of hills 90% of the way, with 50% of that being serious mountain climbs and valleys. Overall it did quite well on SLT Reg. At times, I was wanting more power going up the hills, wailing away at 4k rpm, but the torqueless wonder is the torqueless wonder. Truck was packed but not overly heavy, just some coolers and camping supplies.
    Shifting did pretty well, but I tend to take over in S mode and shift it to the max gear that I want for ascending and descending. At times when I left it alone there was some hunting, but not bad.
    Tip-in with SLT was just fine in 2WD on dirt and gravel. No spinning from too much tip-in.
    I have a 2" lift and 265/75/16s and overall averaged 18mpg on the trip home. Never exceeded 70 and was typically 55-65. At one point, around flat roads up there, I actually saw the gauge hit 20mpg for a short while.
  20. May 10, 2021 at 11:37 AM
    #1320
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Are there any tuners in the surrounding Mobile, AL or MS Gulf Coast area?
    Closest to me appears to be PapaRee at this point.
