Keep blowing the ECU-IGN NO 2 fuse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by morcheez26, Mar 9, 2024.
  1. Mar 9, 2024 at 5:23 PM
    morcheez26
    morcheez26 [OP] Well-Known Member
    Brian
    New Orleans
    18 trd sport
    My truck keeps blowing the ecu-ign no 2 fuse .. nothing changed recently on the truck… i do have several things that arent stock but nothing new in the last 6 months. The things i noticed that dont work when it blows is the window switches , climate control knobs and bsm. Where do i start ? Its a 2018 and out of warranty
  2. Mar 9, 2024 at 5:35 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Any of your mods affected even if it's just switch lighting. Thinking a short on a lamp tap
    Any signs of rodents in the truck, they love to chew wiring (could fall under Homeowners Ins for repair)
  3. Mar 9, 2024 at 5:55 PM
    morcheez26
    Brian
    New Orleans
    18 trd sport
    i did notice my meso puddle pods weren’t reacting to the switch as they should . For instance they wouldnt turn off when in the off position sometimes .. and i was in the smokies (in the woods parked on the street) when the first start up that blew the fuse occurred … i took a quick glance around the truck for chewed wires but im not sure what areas specifically need to be looked at
  4. Mar 9, 2024 at 5:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    How are the lights wired in?
  5. Mar 9, 2024 at 6:01 PM
    morcheez26
    Brian
    New Orleans
    18 trd sport
    they are completely plug and play
    TnShooter[QUOTED] likes this.
  6. Mar 9, 2024 at 6:05 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Start with your mods first, the wiring nearby, and any grommets they pass through.
  7. Mar 9, 2024 at 6:07 PM
    TnShooter
    Deogee
    STOCK
    Does it blow immediately, or intermittently?
  8. Mar 9, 2024 at 6:10 PM
    morcheez26
    Brian
    New Orleans
    18 trd sport
    first time it blew I changed it and it didnt blow again for like 5 days and that 5 days had alot of shutting off and starting… then it sat for 3 days and blew today… changed it and the very next start it blew… didnt change it again today as I didnt know where to start looking for the problem
  9. Mar 10, 2024 at 4:35 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Kinda sounds like a chaffed wire that touches and then vibes around and not touches. I would start at the battery and work my way to the cab.
    Big tall dave and auskip07 like this.
  10. Mar 10, 2024 at 5:46 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    FWIW, my old Lexus will blow that same fuse when occasionally adjusting the drivers side mirror. They had a bulletin for it and mine got an updated mirror but it still does it. I would maybe start looking into that area.
    morcheez26[OP] likes this.
  11. Mar 10, 2024 at 6:02 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Sounds like you have a frayed 12v rubbing metal.
    Big tall dave and morcheez26[OP] like this.
  12. Mar 10, 2024 at 6:15 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Unhook ALL aftermarket installed accessory hot connections. Replace fuse, start truck, does it blow? If so, you have more work to do, if it doesn't, check each accessory wiring run. At least you can drive truck while doing so.
    Chew, morcheez26[OP] and soundman98 like this.
  13. Mar 10, 2024 at 11:59 AM
    morcheez26
    Brian
    New Orleans
    18 trd sport
    Thanks for all of the replies .. i got some digging to do … ill post an update once i figure something out
    auskip07 likes this.
