keep breaxing cv axles.
Discussion in 'Suspension' started by superwhite, Jul 22, 2012.
  1. Jul 22, 2012 at 11:52 AM
    superwhite
    superwhite [OP] Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    Hey guys,
    I have an 07 4x4, 3" lift, 33's and diff drop. and almost every time I go wheeling I end up breaking a cv shaft. Yes they are cheap to replace but its getting kinda old.
    My question is do I buy the rcv shafts and an arb locker for 3 grand. Or buy a 44 and sas the thing, probably spending closer to 6k for a basic leaf sprung setup..
  2. Jul 22, 2012 at 11:56 AM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    First one was own and the second was oreilly
  3. Jul 22, 2012 at 11:59 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    How are you breaking them? What conditions? Like Whipper said what brand? What shocks?
    Throttle control is key, but I fully understand the need for speed myself being Open/LSD. I have one starting to finally go, but I have 84K on my truck and have been beating it pretty good since day 1.
    A rear locker will help take stress off the front in some conditions, but most likely youll just try harder obstacles.
  4. Jul 22, 2012 at 11:59 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    sounds more like you need to learn to drive offroad
    not being mean, but i've only broken CVs when I do something stupid...like lock the wheels one way or another with at least one bound up...and then gas it a bit too hard
  5. Jul 22, 2012 at 12:48 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Hey no offense taken I am a bit new at wheeling. First one was def my fault, crawling over a rock front end started hopping and snapped the outer joint. Last one I was turned passenger, with the wheel stuffed pretty hard, it just pulled the outer joint apart, dropping the ball bearings. I probably do need some pointers here but I'm planning on bumping up to 35's and don't want to change a shaft every time I'm on the trail.
  6. Jul 22, 2012 at 12:52 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  7. Jul 22, 2012 at 12:55 PM
    JimBeam
    JB
    2015 Tundra
    throttle control...ESPECIALLY when there is ANY binding on the front wheels and theyre turned
  8. Jul 22, 2012 at 1:06 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Gotcha, I was kinda suprised when it happened, hardly on the gas at all. I think a rear locker would have helped a lot cause once I aired down to 10 psi and got a slight tug from a buddy, I was able to get right out in 2wd.
    What do you guys think about mechanical lockers for the rear end? I have the sport axle with LSD.
  9. Jul 23, 2012 at 1:18 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Wait what 3inch lift set up are your running in front? After 2inchs I think your more inclined to break stuff if not done right.
  10. Jul 23, 2012 at 6:06 AM
    XXXX
    sKiP
    05 Prius
    ARB RD-129 - DO IT!!!!!!!
    Simple geometry. CV is the strongest when at 180*. When you droop or jack the shit out of it and at extreme angles it will bind and blow up. Same reason you can't turn your front wheels with a locker unless you want them to explode.
  11. Jul 23, 2012 at 6:22 AM
    XXXX
    sKiP
    05 Prius
    Some lifts are poorly designed and go way past the 'acceptable range'. I have seen some set ups that should have limit straps on them and at full droop actually hit the LCA shock mount. Any gears at extreme angles will bind and break.
    That's why one of my first questions was which shock does OP have.
  12. Jul 23, 2012 at 9:27 AM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    I have a 5100 lift with small spacer to correct the taxi lean. I know I need limit straps, when fully drooped, the uniball cup hits the coil. Guess that's the downside to running no sway bar.
  13. Jul 23, 2012 at 9:31 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    that sucks. I have 33s and I am super heavy on the skinny pedal going up some gnarly stuff and I'm surprised I haven't broken an axle (knock on wood). I mean seriously, I am super hard on my components with wheel hop and everything. It must be that the OEM axles are the best.
  14. Jul 23, 2012 at 9:37 AM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    From what I hear, that seems to be the case. I'm going to be working on some custom shafts here since I have the access to machining equipment.
  15. Jul 23, 2012 at 9:46 AM
    XXXX
    sKiP
    05 Prius
    your trucks almost 3-4 years newer so I'm sure you have less beatings on it
  16. Jul 23, 2012 at 10:18 AM
    JimBeam
    JB
    2015 Tundra
    Also bouncing up stuff is not as hard on CV axles as crawling into a bind and then trying to gas out while the front wheel is either stuffed into the wheel well or completely bottomed out and turned to the max...and bound up against a rock/rut/tree/etc
  17. Jul 23, 2012 at 10:28 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    If he is running "cheapo CV shafts" then he must have broke his OE shafts too... Cheapo or not, stuff breaks when you bind up components.
  18. Jul 23, 2012 at 11:00 AM
    JimBeam
    JB
    2015 Tundra
    it used to be that the aftermarket ones were stronger
    has that changed?
    Maybe it's just first gens
  19. Jul 23, 2012 at 11:02 AM
    XXXX
    sKiP
    05 Prius
    Not sure but I know a couple people including Lurry who blew out AZ cv's in about 50 yards and the OE ones last longer.
    I have no personal experience as my OE cv's are still original at 84k :D
  20. Jul 23, 2012 at 11:04 AM
    JimBeam
    JB
    2015 Tundra
    i've blown both due to my own stupidity
    i'm running aftermarket ones now (no wheeling) but they seem to be holding up to the mall curbs fine
