Keep factory RR diff lock when regearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LardOfTheTacos, Nov 19, 2019.
  1. Nov 19, 2019 at 3:57 AM
    LardOfTheTacos
    LardOfTheTacos [OP] Member
    Diego
    2009 Tacoma TRD offroad with extra cheese and super spices!!
    285/70/17 on evo dakars GTS lift kit with adjustable control arms. ARB bumper aluminum RCI skids rockslides comeup winch
    Thank you all in advance. I have a 2nd gen 6 speed manual trans. trd offroad taco and I have ~33s (285/70/17, but I will get bigger) tires.
    I now have convinced myself I want to regear, and will likely get Nitro 5.29.
    the question is, with the regearing, do I KEEP my factory installed RR Diff lock, or do I have to get the optional ARB locker? I would prefer this not to turn into 3K+ worth of work. I have the ARB bumper and winch, and its feeling heavy.
  2. Nov 19, 2019 at 4:21 AM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I have a 11 6speed running 285/75r16s 10plys and been wanting to do the same thing.
  3. Nov 19, 2019 at 5:55 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    I've been in this same boat for a year or so. My plan is to eventually go to 35's. I'm already trimmed and have a pretty aggressive CMC. I reached out to homer taco and had a discussion as he is the only one locally I know that has 35s and 6 speed. He is running 4.56 and claims it is too low for highway speeds. I used a calculator and came up with 4.30 taking me almost back to stock in all gears with 35" tires. I'm not sure how much a 33 would effect it. 5.29 seems like it will be way too low unless you plan to trailer your truck to the trails.
    As far as keeping the e-locker, well that is why i replied. Consider this my follow dot.
  4. Nov 20, 2019 at 9:16 AM
    LardOfTheTacos
    Diego
    ok, for those following along, I have reached out Nitro,
    here is the reply:
    "So, yes the gears and install kit will work for the rear OEM locker you have in there, unless you would like to go with a ARB locker."
    so it looks like getting the "nitro With OEM e-locker gear kit" means that it will preserve the stock-lock. or lockstock?
    anyway, yes i will for sure go to 35s and I think I think with a manual trans I will go ahead with the 5.29. I mean I guess?? is it too low??
  5. Nov 20, 2019 at 9:20 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Probably too low. Depends on what you mainly drive. Most with 6spd and 35s run 4.56 and its just a hair higher than stock on the highway.
    Sna likes this.
  6. Nov 20, 2019 at 9:30 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI, i dont think ARB makes an air locker to replace the factory elocker.... and the "8.4in" 3rd members found in the non elocker axles do not drop into the elocker housing.
    Muddinfun and whatstcp like this.
  7. Nov 20, 2019 at 10:09 AM
    Noahs2015Taco
    Noahs2015Taco aka TheOverlandingDad
    Michael
    Contra Costa County
    '15 TRD Off Road - Manual w. TRD Quick Shifter
    King 2.5 25001-119A EXT with Icon Billet UCA giving a 2.5" lift in the front, Icon 2.0 w. remote resi, OME HD Dakar Leaf pack giving a 3" lift in the back. Wheelers Superbumprs paired with All-Pro U-Bolt flip kit. 17" Black 4Runner TRD Pro Rims - 32" for DD 17" Black 4Runner TRD Pro - 33" BFG KM2 255/80r17 for dedicated off road set. Dissent Offroad Bed Rack over a softopper
    My two cents. 5.29 gears on a 2nd Gen Taco with a manual is super low/over geared for someone with 33s or even 34s. To get back to stock with true 34s you only need 4.30's. However if you've added a significant amount of weight, (heavy tires, armor, gear etc.) going to 4.56 might be justified and what I'd recommend. For the 2nd Gen you also have to remember the Manuals and Auto are different. 4.56 Manual roughly equals the 4.88 Auto.
    Sna, revtune and Beretta4x4 like this.
  8. Nov 20, 2019 at 10:17 AM
    nd4spdbh
    SoCal
    Other way around... auto's have a taller OD gear vs the manuals. (and its why manuals are epa spec'd at less highway mpg)
    revtune likes this.
  9. Nov 20, 2019 at 10:21 AM
    LardOfTheTacos
    Diego
    ok so I have a bit more weight, ARB bumpers and what not, running 33s but will get 35s with a manual 6speed. maybe at the most I get like 4.88.
  10. Nov 20, 2019 at 10:25 AM
    Muddinfun
    Muddinfun Well-Known Member
    Also, to add to this, plenty of people have busted ring gear teeth on E-locker axles with the factory 3.73 ratio. When you go lower gearing(Higher numerically), the gears get even weaker due to a smaller pinion gear. So, with a scale of,
    barely strong enough------------------------->much weaker
    I wouldn't go higher numerically than needed.
    Conclusion- 35" tires, E-locker, and 5.29 gears is just asking for busted gears, if you do any serious offroading.
  11. Nov 20, 2019 at 10:27 AM
    LardOfTheTacos
    Diego
    ok, so the pinion gear issue, that is upgradable also, no?
  12. Nov 20, 2019 at 10:30 AM
    LardOfTheTacos
    Diego
    ok, sorry I should've quoted, but! if I get the Nitro OEM e-locker kit, it comes with a new pinion set, so does that help the breakage issue? or do I need to RTFM to undersand which gears we are talking about.
    thanks for the discussion, this is super helpful.
  13. Nov 20, 2019 at 10:33 AM
    Noahs2015Taco
    Michael
    Contra Costa County
    This!!
    Muddinfun[QUOTED] likes this.
  14. Nov 20, 2019 at 10:36 AM
    Muddinfun
    The smaller pinion gear with a higher numerically gear ratio is just a fact of life. It applies to all axles. If you start out with a super strong Ford 9", you can use any ratio you want. But starting out with a weak Tacoma E-locker, it's just going to get weaker.
    Noahs2015Taco likes this.
  15. Nov 20, 2019 at 10:39 AM
    Noahs2015Taco
    Michael
    Contra Costa County
    Yes, the manual epa HWY rating is lower than the auto, but that's because the Auto 5th gear is taller than the 6 speed manuals 6th gear. Personally I think the 6th gear in the manual is way to close to 5th gear, and reverse is way to high. However my point is still valid, comparing just one of the transmissions speed (6th gear in the manual vs. Auto 5th gear) doesn't paint a complete picture. Just ask Nitro or ECGS, 4.56 Manual = 4.88 Auto on the 2nd Gen.
    nudavinci64, Sna and Beretta4x4 like this.
  16. Nov 20, 2019 at 11:12 AM
    nd4spdbh
    SoCal
    Correct. Lower gears will allow the easier use of a manual, but if OP was looking to stick to close to stock rpms at highway cruising then...
  17. Nov 20, 2019 at 11:50 AM
    Noahs2015Taco
    Michael
    Contra Costa County
    Considering he's looking at 5.29 or even 4.88 it doesn't sound like he's trying to return to stock ratios and Hwy rpms with 34s or 35s. Also my earlier comment is to help him avoid a trap that I see some 2nd Gen 6 Speed manual guys fall into. Example a 2nd Gen MT owner sees another 2nd Gen Auto Taco with 35s running 4.56 where the 2nd Gen AT owner says, "I wish I went with 4.88 for blah blah reason". So the 2nd Gen MT owner then thinks oh maybe I should get 4.88 for mine to avoid buyers remorse like the AT owner has. If that 2nd Gen MT owner does that, they will be significantly over geared because again the 4.56MT = 4.88AT, so a 4.88MT is closer to 5.29AT. If the 2nd Gen MT owner were to go with 4.56, they would already be equal to a 2nd Gen AT running 4.88.
    Sna likes this.
  18. Nov 20, 2019 at 12:10 PM
    LardOfTheTacos
    Diego
    o k ok ok. I think 5.29 might be a bit aggressive, and if ANYTHING, look at the 4.88. I mean, 95% of my driving is just street (although New England roads are only sorta paved some of the time). so either 4.56 to 4.88.
  19. Nov 20, 2019 at 12:11 PM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    This is exactly why I am seriously considering the 4.30 when I go 35's. I've spoken with a couple of MT guys and they run 4.56 and wish they had 4.30 for roadtripping to trails. I've also been pretty interested in a taco box as well instead of a re-gear. I feel like on rocks it would give a far better feeling of control and save the clutch.
  20. Nov 20, 2019 at 12:16 PM
    Beretta4x4
    Josh
    Temple, TX
    When I'm completely loaded down with camping gear, my truck struggles to maintain 75 on stock gears and 35s on any kind of incline. Same goes for headwinds. Stock gears are fine on a daily driver, MT, with 35s and very little added weight. My last weigh-in without my camping gear, but all my accessories mounted, was 5300 pounds.
    I'm doing at least 4.56 because it'll take some of the stress out of the clutch wheeling over big rocks.
